Charles- Excellent work on that Tamiya kit, great to see you're making progress!
Mo- Oh, man! I have had those days, and would not wish them on anyone. Glad to hear you're getting things fixed up, as I am looking forward to seeing this one.
Fred- Sounds like there may be some crud in the nozzle causing those issues. Have you disassembled it and given it a really good cleaning? I always clean mine after every session, but every once in a while I take the entire AB apart and soak the parts in solvent to remove any residual crud. Be careful with any teflon bushings (don't know about those AB's, but my Badgers have 'em) as solvents can wreak havoc on them. Could also be a bent needle or damaged tip, have you checked those?
I made some more progress on the 262, modifying some kit parts on the IP. The gunsight on the 262 was retractable and fold able, and could be moved out of the way when needed. Trumpeter has the bar atop the IP broken where the gunsight goes, and the sight itself fits into the slot. The fit was not so good, and it looked like exactly like what it was- the gunsight retraction tube with part of the IP and bar attached to it instead of the retraction tube going through a space between the IP and bar. I wish I had taken a photo before to show what I mean. But, I cut the gunsight apart to separate it from the retraction tube. I fitted a section of .040 styrene rod into the gap, and smoothed it down. Then, took a piece of brass tube and inserted it, and made a bracket out of strip stock. I took a piece of brass wire the fit into the tube, and drilled a hole in the gunsight mount to insert. Now, the assembly retracts just like the real one, and looks much better IMHO. I also modified the left console part, drilling out the bottom gauge and enlarging the upper one. I punched out two .040 discs from styrene, and inserted them from behind as there is a large gap behind the gauges between the clear piece and the gray plastic underneath. Now, I can paint some gauge detail onto those discs, and add a clear lens over the top to replicate the gauges there. Hope all of that made some sense!
Gunsight extended:
Gunsight retracted:
You can see the console piece with the discs in the foreground along with the kit-supplied gunsight retraction tube and mount, but it is so tiny it is hard to see what I did to it!
