Aaron,
There will be quite a bit visible. The detail that you can see now will still be visible. I got the upper portion of the fuselage over the cockpit and gunner's office and, everything is still fairly visible. Yes, you have to get a bit closer to view the same details but, it is not obscured. The rear panel that has the radio (at least I think thats what it is) has no detail on the back side. The only portion that is visible from the cockpit is the upper area and that I painted to represent wood, just because grey styrene would have looked rather silly.
Bob,
Brother, thank you so much for the compliment and following along on this one. I've had to do some filling in some areas. Nothing horrendous but, in some areas that had some very delicate detail that was very visible. The details were the kind that I in no way wanted to recreate should I sand them off.
Here she is with the cockpit properly fitted.
This kind of gives an idea of just how much detail is still visible.
The grab handles were exquisitely molded. With my armor builds I've had to resort to using brass wire to get handles this clean.
This will give one an idea of some of the detail that had to be protected while sanding. The rearmost area has yet to be sanded
A mock up of the engine. Still a lot of painting yet to be done.
A couple detail shot of the right side of the landing gear.
Cheers
Dave
