Aaron,
Thank you for the compliments.
It depends on whether you are using enamals or acrylics. With enamals, you must clear coat it first. Future works well. If you are using acrylics, you do not have to clear coat it.
First, relax. Breath. Initally, it's going to appear overdone. Just brush on the oil color of your choice. Myself I use Windsor & Newton Burnt Umber (most of the time). Here's one of the beauties of this technique: You don't have to wait for anything to dry (at least not for the first part). Next, take a brush dipped in mineral spirits. Touch the side of a brush to a paper towel, or rag of your choosing. This will keep the area you are working in from getting flooded with mineral spirits and removing too much of the oil paint giving you more control. The type of brush you use (i.e. round. angled, flat, etc) depends on the area and surface you are working. There are no hard set rules there. Experiment and find out what works for you.
Once you get the effect you want, then, it's time to seal it. I seal mine with Model Master lacquer. You can use flat, semi-gloss, gloss. Use what you want to achieve the effect you want..
Check your PM. You will have an inbound message.
Konigwolf13,
Thank you for the complient on the kite. From what I see so far on your stringbag, you are certainly headed in the right direction for a fine looking finished kit! Thank you for the scale items. Holy smoke! That Beast is BIG! Say Hello to Sackboy. How are things on Little Big Planet?
Cheers
Dave
