scrap the scratchbuilt 1/32 star fury idea iv got 2 more instead :)
1 is a scratchbuilt 1/700 habakuk style nuclear powered 1970s era carrier im probably going for around 4 feet long which would make it 2800 feet long and around 400 wide!! il also try to build some 1/700 vulcans victors and tsr 2s for it
plan number 2 is slightly less ambitious but only slightly more plausable lol
it consists of 2 1/48 scale tsr2s 1 will be raspberry ripple scheme and will be a tech demo and will have features including canards lerx wing roots leading edge slats massively blown wings/flaps much longer and probably different air intakes fly by wire controls and hugely powerful thrust vectoring versions of the olympus engines (circa 55-60,000 lb of thrust)
sounds ridiculous BUT iv not plucked anything out of thin air eg apparantly an engineer told somebody they had an olympus engine running at 68,000 lb of thrust in the 60s! etc etc
version 2 will be the in service version of that probably with an rwr tube out the back like a flanker and probably with an f15 style bubble canopy because it will be a fighter bomber like the strike eagle
1 thing id need to do is move the canopy back which would require me to lengthen the fuselage to keep the cockpit the same distance from the wings
the tech demo (and record breaker) will look something like this
