Things started out great tonight. Date night with the wife, finally got to try a donut from Gourdough's (the Flying Pig, topped with bacon and maple icing!), toddler went to bed without incident, so I got an early start masking the Yak...
![](http://i780.photobucket.com/albums/yy86/doogsatx/Yak-3/2b2f1ae9.jpg)
Once again, the WEM enamels (this time AMT-12 Soviet Dark Grey) sprayed amazingly well.
![](http://i780.photobucket.com/albums/yy86/doogsatx/Yak-3/0db6df5a.jpg)
Of course, this being a Doogs build, SOMETHING has to go catastrophically wrong...
![](http://i780.photobucket.com/albums/yy86/doogsatx/Yak-3/988e90ef.jpg)
You know how play-doh picks up other play-doh? Yeah, not this time.
After much swearing, and various attempts to remove the play-doh (rubbing kinda worked, goo-gone ate through the enamel), the stuff started to harden. I couldn't get it off. I started wet sanding and that worked, but then I noticed that the play-doh softened under water, so I just started brushing on water and wiping up with paper towels. Finally managed to get oh, 95% of it off.
Took up the airbrush again and just freehanded the camo outlines.
![](http://i780.photobucket.com/albums/yy86/doogsatx/Yak-3/99c9e47b.jpg)
![](http://i780.photobucket.com/albums/yy86/doogsatx/Yak-3/407b2e4a.jpg)
Suffice to say, I will NOT be using play-doh to mask the La-5.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck: 1/350 HMS Dreadnought
