Quagmyre - the amount of smoke is up to you, depending on how you want it to look. It looks like the 5A (with gear down?), so you'd have to remove the gear & use the other parts for the retracted gear (its not easy - I tried it & decided not to) to pose it on the water. If you park it on the ground, it would probably not be "wet." Just some ideas, but its up to you.
Beautiful job, obiwan ! The clear gloss on the instrument faces looks good, as do the belts. I know what you mean about scratching the belts - it was a pain making buckles for mine, too. The seatbelt sets from Eduard are great. I have U.S., Luftwaffe (bombers & fighters), and RAF. If you build a lot of Luftwaffe stuff, I'd recommend the rudder pedals, also. The set I have contains four different types. I wish they made one set with only the pedals from Me 262/ FW 190/ Bf 109F/G/K.
