Son Of Medicine Man:
berny13:
Here is how the two pods will look. The top picture is of the AN/ALQ-87 ECM pods and the second is the AN/ALQ101 ECM pod.
Hi Berny,
I had already ordered the AN/ALQ-101 pod from Flightpath (David J. Parkins) when you posted this. But there was no real way of knowing what version I was going to receive since there were no pictures on his website. It finally arrived today and here is what it looks like:
After seeing your reply to Rich about the version I know that this is a newer version than what you used. In fact from what information I could find, I am assuming that the AN/ALQ-101 you were using at the time in Vietnam was a prototype.
Anyway, you had offered to send me the correct one. I know you sent one to Rich so I don't know if that offer is still good. Anyway, if it is, I would appreciate it.
Ken
This is the type you need. The AN/ALQ-101 ECM pod was just entering the Air Force inventory. They were not a prototype but the first generation ALQ-101 pods put in production. Later ALQ-101 pods were improved by adding more receivers, transmitters and processors which resulted in the pod growing in size and having more gondolas added.
A lot of talking heads and experts will tell you the AN/ALQ-119 ECM pod is an AN/ALQ-101 ECM pod with additional space in a larger gondola. The truth is the AN/ALQ-101 ECM pod was air cooled with air ducts added on later versions. The AN/ALQ-119 ECM pod was a complete redesigned pod which was much larger, lighter, and was cooled by freon gas. There were four radaiators built on the side with two having the intake facing forward and the two back ones had the discharge facing aft. The AN/ALQ-101 pod was a deception pod and the AN/ALQ-119 pod was a programmable noise and deception pod able to operate in both the training mode and combat mode with just a flip of a switch.
Give me a couple of days to get the pod packaged up and in the mail.
