The Official F-4 Phantom II Group Build 2011
    June 2009
Posted by jimbot58 on Wednesday, September 7, 2011 11:42 AM
Casper the Chihuahua
Grrrr........decals!!!! Crying
My woes on this build continue. I have used up both port side rear fin decals as they tore badly. The colourful stripes crumbled and broke, I even tried segmenting the second attempt into 3 parts but no.
So I'll have to re-mask and paint black over the damaged section. I've ordered some Phancy Phantom decals to replace the artwork. They won't exactly be correct for VF-161 but anything is better than what I haven't got! The decals in this Hasegawa kit are terrible. They take up to 5 minutes to detach from the backing sheet!
I held the Tamiya 1/32 Phantom F4-C/D today. Too expensive and nowhere to put it! comes in at a massive 2 foot length. I put it back on the shelf.
Cheers
Wow! That really sucks big time! It always seems something goes wrong when you have invested so much time in it. I'm surprised at this as I have always had decent luck with Hasegawa decals. Hope you have better luck with the AM decals!
Berny: I spotted a Hasegawa F-4E for around 13 bucks at Internet Hobbies and I was a bit wary of the price! I am willing to bet it is an early version.
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    August 2009
Posted by Sparrowhyperion on Wednesday, September 7, 2011 11:49 AM
I've had good and bad luck with Hasegawa decals, which holds true for any brand.  Too many environmental factors affect them in different ways.  I generally put on a coat of Microscale Liquid Decal Film before I use any decals nowadays.  It's an extra step, but it works well, and makes them a lot more predictable.  I do a lot of older kits, so I really need to take that precaution.
Rich
jimbot58
 Casper the Chihuahua:
Cheers
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    February 2010
Posted by Bockscar on Wednesday, September 7, 2011 6:54 PM
Uhhhh....duuuuhhh.....decals??????
duuuuhhhhcallllsssss?////wazzzuppwiiiidatttt????Dunce
    June 2009
Posted by jimbot58 on Wednesday, September 7, 2011 9:17 PM
I gave into fear today: I decided it was too risky to try the chrome silver, so I went with a few references I found suggesting FS36320 Dark Ghost Gray. I read that most of the planes in the field quickly faded anyway to the gray anyway. Right or wrong, it is what it is now. Paint has been applied!
Plus some aggravation tonight as well, aside from the fact that this forum seems to be having a little trouble with their servers today and I keep having troubles getting it to load!
I went to mix those colors for the F and first needed a black/green mixture. Opened the green and it was goo in the bottom of the bottle. I knew I had a new bottle, only where did I put it? Finally found it. Then came the black-opened it and....you guessed it! It was a mass of rubber at the bottom of the bottle. Again a search for a back-up bottle I knew I had, which I found. (I keep a list of spare paints so I prevent buying extra.
Now on to the dark gray need: I had the black, so I opened the bottle of Gunship Gray my mix calls for and this time, there was only a small amount in the bottle and very thick! I check my list and yes I have a spare! Only the list was wrong and I can't find it in my storage area! I quit for tonight, and will go watch some of the b**b-tube!
Posted by berny13 on Thursday, September 8, 2011 8:48 AM
Sparrowhyperion
Even if it is the early version it is still a bargen.  If it was me I would go ahead and get it.
Berny
 Phormer Phantom Phixer
On the bench
    June 2009
Posted by jimbot58 on Friday, September 9, 2011 2:43 AM
So far:
I know some references have the green more of an olive color, but I found a larger number of photos with this dark green. There is a difference in the sheens of the two paints because of the mixtures I followed, but that ain't gonna matter when it comes time for a gloss coat!
    November 2010
Posted by Son Of Medicine Man on Friday, September 9, 2011 6:02 AM
jimbot58
So far:
http://img155.imageshack.us/img155/2825/0909110130a.jpg
Hi Jim,
Looking good!  Yes  Yes
Ken
    November 2010
Posted by Son Of Medicine Man on Saturday, September 10, 2011 9:53 PM
Greetings everyone!
I am finally back to working on my Phantom.  I had given a lot of thought on how to duplicate the seat belts as shown in this picture:
Then I came up with an idea.  First, I took the Eduard photo-etch seat belts pictured here:
I snipped off one of the long seat belts (number 1 on the sheet) pictured here:
Then I took two drill bits from my pin vise set pictured here:
I taped these together as shown here:
Then I took the seat belt and wound it around the drill bits to form the loop shown in the picture of the ejection seat:
Then I removed the tape from one end of the drill bits and slide the seat belt off:
Everything was going fine until I realized that the seat belt was only painted on one side.  Here is a picture of the photo-etch set turned over.  As you can see some of the photo-etch is painted on the back side while some is not.  The seat belts are not.
So now the next move was to mask off the pieces that are painted and paint the back side of the seat belts:
I also painted the back side of the seat belt that I had already snipped off:
So now I will wait for the paint to dry and try again.  But I think it is going to come out pretty good when I am finished.
Ken
    October 2010
Posted by Casper the Chihuahua on Sunday, September 11, 2011 1:46 AM
Ok, almost done. Just painting up the seats (thanks for your timely post with MB seat pic, Medicine Man) then the canopies can go on.
I've also repainted the tail and will have to wait the month or so for the replacement decals to arrive. I'll post her as done when they are in place.
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    November 2010
Posted by Son Of Medicine Man on Sunday, September 11, 2011 9:57 AM
http://i1093.photobucket.com/albums/i438/smcintyre11/Phantom%20II/c8ff3688.jpg
Cheers
Hi Casper,
Very nice job on your Phantom!!  You did a great job!  Yes  Yes
That picture of the ejection seat was courtesy of Berny that he had posted towards the beginning of this group build.
Ken
Posted by berny13 on Sunday, September 11, 2011 1:26 PM
Sorry it took so long to post the pictures I promised you Ken.  The first picture is my helmet bag.  The second is my skull cap.  I am sure HVH could explain why we had to wear them.  The third is my helmet.  That is not my helmet I used when I was on flight status.  My oldest son collects helmets for a hobby so I gave him my old one and he gave my an updated type worn at that time.  The visor cover comes off for the tented visor to protect against ther bright sun.  Very seldom did we use the sun visor as we wore sun glasses.
I still have three good flight suits and two not so good that I use when I worked on the car or truck.  I have my flight jacket, G suit, chute harness that my son gave to me.  We didn't use the harness as the T-33A had fanny chutes and the TF-102A used back pack chutes. Most of the time we didn't even wear the G suits except when we were the target on DACT.
I used to wear a flight suit whenever I flew the C-150 type of aircraft.  It has so many pockets it is great for flying.  You have plenty of room for maps, check lists, and anything you happen to have with you for the flight.  Yes Dom, you can even carry your lunch.    Smile Burger
Berny
On the bench
    November 2010
Posted by Son Of Medicine Man on Sunday, September 11, 2011 4:17 PM
berny13
http://i22.photobucket.com/albums/b309/berny13/IMG_0197.jpg
Hi Berny,
I really like that last one.  Phantom Driver.  Way cool!!  Very good to hear from you again!
Ken
    November 2010
Posted by Son Of Medicine Man on Sunday, September 11, 2011 4:51 PM
Hi Everyone,
I finally figured out what is going on with those seat belts!  Berny please correct me if I am wrong, but I found a picture in my "The Modern Phantom Guide" with the belts lying flat against the back seat.  I wish I could post that picture but I am sure it is copyrighted.  Anyway, in that picture you can see the small loop that fastens with a button snap.  That is what holds those belts up in the picture shown below (I circled it in yellow):
So I believe what Berny was talking about was that before the pilot arrived, these belts would be held up using these small loops so that when the pilot sat in the seat, he would not have to hunt for the belts.  I am sure that with the parachute and survival gear on it would have made it a chore if the belts were laying flat on the back of the seat and he had to fish them out.  Berny, I am sure that you knew this and it was such a common bit of knowledge about those loops for you that when looking at this picture it was very obvious to you.  I just now understand.  Eureka!!  Geeked
Ken
Posted by berny13 on Sunday, September 11, 2011 7:51 PM
Son Of Medicine Man
Hi Everyone,
http://i1143.photobucket.com/albums/n625/Fooser_Ken/seatd-Copy.jpg
Ken
They are held up by wide elastic bands.  The belts are so long they would get in the pilots way when strapped in the seat.  They are part of the harness assembly and it is a pre flight item to make sure they are tacked up.  The pilots get very irritated if they are not tacked up.  The harness on the right you can see a better picture of the elastic bands.
Berny
On the bench
    November 2010
Posted by Son Of Medicine Man on Sunday, September 11, 2011 8:24 PM
berny13
 Son Of Medicine Man:
Hi Everyone,
Ken
Hi Berny!
Thank you for clarifying that!  From the picture that I saw in my book you can't tell that they are elastic.  But by seeing that picture and then take a look at this one, I now understand what is going on.  It will make duplicating it much easier now that I have your input!
Ken
    August 2011
Posted by 26carlos on Monday, September 12, 2011 8:23 AM
Hi fellows:
Now decaling, oil wash and  overall satin coat finished.
I think this week it will be finished. I hope so Stick out tongue
    February 2010
Posted by Bockscar on Monday, September 12, 2011 6:09 PM
berny13
http://i22.photobucket.com/albums/b309/berny13/IMG_0194.jpg
http://i22.photobucket.com/albums/b309/berny13/IMG_0199.jpg
Nice kit Berny:
You ever need lunch man, let me know where and when.....ummmm.....that OC was nice though.....in-spite of the Bloody Marys.....lol.....Eats
    August 2011
Posted by 26carlos on Tuesday, September 13, 2011 7:40 PM
Hi fellows:
Today I worked with the armament, Sidwinders & Sparrows.
It was really a pita Crying,  but they look ok (I believe so). I´ll have to paint some minor details and apply a satin coat. Then I´ll will try to make a good attachment. Opinions will be welcome Stick out tongue
Posted by berny13 on Thursday, September 15, 2011 2:31 PM
Dom, let me know if these are OK
Berny
On the bench
    August 2009
Posted by Sparrowhyperion on Thursday, September 15, 2011 2:42 PM
Great images Berny, Thanks!   I wish I could find one of those helmets surplus.  lol.
Rich
BTW.  You never got back to me about the F4 Stabilators you needed.  If you can tell me what I need to get to make them for you, I will.  I have never used resin for this sort of casting.
    November 2010
Posted by Son Of Medicine Man on Thursday, September 15, 2011 8:06 PM
Hi Everyone,
Berny, I sent the email yesterday about your stabilators but have not heard back yet.
Here is the result of my second battle with the seat belts.  It will require some touch up paint but I am going to let the CA set overnight before I touch it.  Berny, please tell me what you think of it.
Ken
Posted by berny13 on Thursday, September 15, 2011 8:16 PM
Dom, here is my old helmet that I wore when I flew.
Berny
On the bench
Posted by berny13 on Thursday, September 15, 2011 8:21 PM
Son Of Medicine Man
Hi Everyone,
http://i1143.photobucket.com/albums/n625/Fooser_Ken/100_5258.jpg
Ken
I didn't get the e-mail.  Seat harness looks real good.  Don't make them all look the same as each one would hang differently from the chute.
Berny
On the bench
    November 2010
Posted by Son Of Medicine Man on Thursday, September 15, 2011 8:32 PM
berny13
http://i22.photobucket.com/albums/b309/berny13/DSCN4131.jpg
http://i22.photobucket.com/albums/b309/berny13/DSCN4134.jpg
Berny, that is just too cool!  That had to be a very wild feeling flying an F-4 Phantom!
Ken
    November 2010
Posted by Son Of Medicine Man on Thursday, September 15, 2011 8:36 PM
berny13
Hi Everyone,
Ken
Thank you Berny for the compliment!  I don't think I will have a problem with making them look different since I am making each one from scratch.  Smile
I wasn't clear when I mentioned the email.  What I meant was that I sent the email to the person I have purchased resin from in the past to see if he could make some replacement stabilators for you.
Ken
    February 2010
Posted by Bockscar on Thursday, September 15, 2011 9:22 PM
Berny, those shots look real great!
Ummm....that Spook seems to be telling us how to "read between the lines"...."turn the page sideways"......LOL
Nice Helmet, can almost make you out in the reflection....
Thanks man....saving those......
    February 2010
Posted by Bockscar on Thursday, September 15, 2011 9:37 PM
berny13
Berny that's a nice bit of kit. Those sensor wires wrapped around the air hose is interesting, might give us a bit to reflect on meeting the modelling challenge.
So you had the clear lens, the dark sunglass lens, and the final blast lens from the look of it. Just replicating the webbing as it wraps around the mask would be a challenge......
Thanks for sending that along, very cool item.
I am still getting a big kick out of Spooky telling us how to "read!"
    October 2010
Posted by Casper the Chihuahua on Friday, September 16, 2011 2:45 AM
Ok, got my seats done. Still a bit damp from the light oil wash but these should dry out well.
Nothing left but to fix them into the cockpit and tack on the canopies. Then I need to wait for my Phancy Phantom decals so I can replace the damaged tail fin artwork.
Cheers
    February 2010
Posted by Bockscar on Friday, September 16, 2011 1:17 PM
I called those sensor wires, but I realize on second thought I should have said radio cables/wires.
Posted by berny13 on Friday, September 16, 2011 6:49 PM
Bockscar
I called those sensor wires, but I realize on second thought I should have said radio cables/wires. http://i22.photobucket.com/albums/b309/berny13/DSCN4134.jpg " alt=" " onload="resizeImage(this);" />" alt=" " alt=" " onload="resizeImage(this);" />" onload="resizeImage(this);" />
It is string to hold back the ear phone cups.  You would release them to let them spring tight against the ear .
Berny
On the bench
