so i continue on the gannet and the seabat.. also more troubles i did
the seabat is four blade copter ... find you the little incident occurred
i painted part of the gray triyng to not invade the white areas, rotor was glued and painted two days after the kit comes, but sleeping in the gannet garage i probably put it accidentaly on the rotor (and the gannet have a good weight really )
so on the gannet i found lots of pieces is again on the sprues (whitout counting scratched pieces the kit comes with 115 pieces)
the arrestinng hook comes already broken in the middle (not my fault this time), a piece of plastic rod replaced the central pieces
on the main gear doors i drilled a recess as present on the real
parts of remaining pieces passed with black ,these pieces will be in alluminium, lots of pictures says that these pieces and the wells will be in the same light sky as the bottom of the planes but lots of others says these inner parts in alluminum . Unfortunately i don't found specific pictures of the "UA 106" i chosen
then started the last scratch out of engines zones (at least if don't break more finished pieces )
the weapons bay doors;:
after consulting lots of referecnces and seen pictures of aftermarket kits i planned so:
both doors have a sort of structural box, 5 per dors located at the center of bay when closed, probably to secure the torpedos during flight
these pieces was cutted from styrene sheets, without usinsìng ready profilates, before to cut the first ten pieces i shapen one of sides to obtain an upper anle when glued
then larger pieces (10+10)
then the lateral walls to close these boxes, only a side left opened as the real
not see in pictures cables for the doors, only the actuators and the hinges from the kit need to be added, then just waiting the glue perfect dry and i'll refine the pieces with a new x-acto blade .
So other 40 pieces was added really tedious this part but the result pay this spended time
