Spitfire GB
    June 2010
Posted by DoogsATX on Sunday, August 21, 2011 3:10 PM
Greenshirt
One option in 48th is to use the wing of the recently released Airfix Mk XII as it's a c wing with Mk V radiators.
Tim
Tim - what a coincidence! I just picked up a Mk.XII on Thursday afternoon! I knew it was basically a V with a Griffon shoved in. Didn't realize they left the radiator details the same though. Hmm. May have to compare and see how the wing would mount onto the Tamiya fuselage.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    June 2010
Posted by DoogsATX on Sunday, August 21, 2011 3:14 PM
Jester
Im gonna try tamiya tape for masking, heard its pretty good and doesnt rip the under coat of camo off.
Does even better if you remove most of the tack by sticking it to the palm of your hand or inside of your forearm. That way when you go to peel it off, there's pretty much no chance of paint lift unless you're using one of those glass-jawed paints that lifts if you look at it the wrong way. Like Model Master Metalizers.
Also, for masking big areas (underside of the wing when you paint the top, etc), you can cut post-it notes or paper into strips and squares , then just tape the edges down with Tamiya tape. Saves tape, keeps the model safe! If you do it right, you can also remove most of your masking in like one pull!
    August 2011
Posted by Jester on Sunday, August 21, 2011 5:16 PM
Taking the extra stick off the masking tapes a good idea .. Ill have to remember that one, Chur
On the bench: 1/32 F6F-3 Hellcat
    June 2010
Posted by DoogsATX on Monday, August 22, 2011 2:31 AM
Alright, I'm sticking a fork in the Mk.VIII.
Overall, I really can't praise this kit enough. Expensive, blah blah, but it friggin' earns it. The fit, the engineering, the ambition, the obvious passion that went into it. It's a downright epic build. Hope you all like the final results:
Not sure what I'll be building next...right now I'm leaning toward either another Spit, something USN, or Academy's P-47N. But...this thing's definitely lit an enthusiasm for Spits I didn't have before! Thanks for the excellent GB!
    October 2010
Posted by Casper the Chihuahua on Monday, August 22, 2011 2:37 AM
Awesome work Doogs! YesBow DownToast
I gotta ask, how do achieve the dirty tyre look?
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    December 2009
Posted by ww2psycho on Monday, August 22, 2011 7:01 AM
DoogsATX
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-44.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-46.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-48.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-51.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-52.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-53.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Tamiya%20Spitfire%20Mk%20VIII/file-54.jpg
Um Doogs... All I can say is WOW! I cant make up my mind for which pic to put on the first page, can you choose one?
    June 2010
Posted by DoogsATX on Monday, August 22, 2011 8:10 AM
ww2psycho
How about this one?
    August 2009
Posted by JOE RIX on Monday, August 22, 2011 9:14 AM
Doogs - That is absolutely Stunning!!!!! Your skills really are top notch as well as your attention to detail. Thank you very much for sharing your build and I do hope you stay tuned while the rest of us finish up.
                                                Kudos. Joe
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    April 2010
Posted by Theuns on Monday, August 22, 2011 12:27 PM
The latest on myne.
The feathered paint edge didn't come out as I had hoped, but in 72 scale it is (for me atleast) near to imposable to get right!
Decals tonight and last clearcoat to complete a fun little build.
Maskall and white tac worms.
1/72 Airfix Spitfire Mk9
The gloss clear makes the colour look a bit darker
Theuns
    August 2011
Posted by Jester on Monday, August 22, 2011 3:28 PM
DoogsATX
WOW dude thats awesome man, srsly. (Told ya you should enter that in a show, would be great to see irl)  Thanks
Hey out of interest, how do you get your pictures to show full span here, I use photobucket but we have click to get full screen.
Again, great job mate !!!
    August 2009
Posted by JOE RIX on Monday, August 22, 2011 4:00 PM
Buckeye
I think mine is just about ready for the shelf.  I see a few spots in the pictures out in the natural light that need some minor touch-ups.
Kit is the 1/48 Tamiya Spitfire Mk. Vb built straight out of the box, painted with Model Master enamels and finished with a black oil pin wash.  As noted earlier the decals gave me the most trouble of any kit I've ever built.  Over all I'm pretty happy with how it came out.
http://img.photobucket.com/albums/v397/Xondi/001.jpg
http://img.photobucket.com/albums/v397/Xondi/002.jpg
http://img.photobucket.com/albums/v397/Xondi/003.jpg
http://img.photobucket.com/albums/v397/Xondi/006.jpg
http://img.photobucket.com/albums/v397/Xondi/012.jpg
http://img.photobucket.com/albums/v397/Xondi/013.jpg
Hey Buckeye,  Your Spifire turned out really Sweet! You did a great job considering the decals. I encountered the same problem with the decals on my Tamiya 1/48 A6M3 Zero. Although I absolutely love Tamiya kits I now order AM decals just to avoid the hassle plus build more interesting aircraft. Did you use the kit decals for your yellow leading?
I painted the ID band on mine yesterday using a new brand of paint that my nearest LHS has started carrying in lieu of the difficulty in getting Tamiya paints. It is called Lifecolor. It is an acrylic and they have a rather nice color selection. So, I figured what the heck.  I tried out the sky color as it is the closest match to the decal set lettering I am using. At first I thinned the paint with their thinner and it was too runny. I then reshot the paint straight out the bottle with rather nice results. It is though a bit "fragile" as it scratches off easily and will pull off slightly wit masking tape. I solved that problem though with a coat of flat.
                                                              Joe
    June 2010
Posted by DoogsATX on Monday, August 22, 2011 4:15 PM
Joe - I tried Lifecolor last year and had endless problems with it spraying runny.
Then this summer I tried, on a whim, thinning it with Testors acrylic thinner. Worked like a friggin' charm. The Testors stuff works really well on Vallejo, too.
You can also use Future as a thinning medium for both. A bit thicker than water, so it doesn't go all runny. That and it dries ROCK SOLID and shiny.
Haven't tried Lifecolor as a main exterior paint yet, but I'm about to with my Panzer III. Hoping I like the stuff - it brushes really well, and I'm a lot happier with their color accuracy than Vallejo (outside of their Panzer Aces and Model Air lines, which are quite good).
    August 2009
Posted by JOE RIX on Monday, August 22, 2011 4:31 PM
Thanks for the tips there Doogs. The owner of the LHS said it also will cut well with Tamiya Acryl thinner. Yeah I was pretty impressed with their selection as well as including the FS# on the bottle.
    February 2007
Posted by Buckeye on Tuesday, August 23, 2011 6:10 AM
Thanks Joe.  Yes, I used the kit decals for the leading edge yellow ID stripes.  That's the last time I will do that and would highly recommend painting them on. LOL
I used a black oil pin wash on the major panel lines but it didn't come out well in the photos except on the elevator line.
    August 2011
Posted by Jester on Tuesday, August 23, 2011 3:38 PM
SPITFIRE exhausts:   I think Im getting stuffed at this little speed bump.. the colour of the Spits exhaust of all things..
I have painted mine a cross between red-brown and dark bronze but meh, dont look right. Ive gone onto youtube and studied a few pictures (in colour) of the IX exhausts.. they were in fact more light grey than anything!!  SHOCK HORROR!  They did have a small bit of red/brown at the very base-
So on that I will keep the base red/brown and thin right down another coat of red brown but adding metallic grey, finger xrossd this will look better >_<
    August 2011
Posted by Jester on Tuesday, August 23, 2011 8:53 PM
.CONT-
These here
    June 2010
Posted by DoogsATX on Wednesday, August 24, 2011 2:22 AM
Well the exhaust condition depends on a few other factors, too - where the Spit was operating, how well the ground crew could care for it, etc. Just like a car - if you wipe down the exhaust, it stays cleaner.
The Spit I built - the one reference photo of it shows far dirtier exhausts:
I painted mine with a 50/50 mix of Alclad Steel (dark-ish metallic gray) and Exhaust Manifold (bronzish) and was happy with the result. For the ones you posted, if I were going after that look, I'd just go with Steel with maybe a touch (10-20%) of Exhaust Manifold, then hit them with some MIG pigments - blue burnt metal in particular.
    August 2011
Posted by Jester on Wednesday, August 24, 2011 5:38 PM
Nice one Dowg.. will try :)
Got my engine totally finished last night, was a bit of a pain as my work base needs to be mobile so setting up the good lighting (lamps etc) gets annoying.. but arh well. Thanks again.
Posted by jeaton01 on Wednesday, August 24, 2011 6:31 PM
Jester, those photos show the round exhausts that look like they have been all cleaned up.  In service they are a lot more burned looking.  The light grey is most probably lead deposits and the degree to which it is there can depend on the octane of the fuel used, and also whether the airplane has been flying at high or low altitudes.  At night those stubs can be seen to be red hot, if you can see them through the flame.  Reddish tints are usually oxidation (rust).  No two airplanes will look the same.
John
    August 2011
Posted by Jester on Wednesday, August 24, 2011 10:13 PM
jeaton01
  True but only to a certain degree they would. I guess the pictures I put up are -peacetime well looked after in every detail- Spits
    December 2009
Posted by ww2psycho on Thursday, August 25, 2011 6:40 PM
Hey everyone, just so you all know, I wont be living at my place for about a week and wont have a computer very often during that time so I wont be able to reply while Im gone.
    August 2011
Posted by Jester on Friday, August 26, 2011 4:30 AM
My completed Spit IX engine. Nowhere near your end product Doogs, I kneel before your mastery of the topic. I need to re-file as I can see the exhaust mould lines here but strangely not in real life when I look at it even up close, hmm?  But with my limited equipment and no dedicated space I reckon not too bad for a noob...  Tongue Tied
    August 2011
Posted by Jester on Saturday, August 27, 2011 4:45 AM
GUYS!!!  Anyone else building? Plse dont be shy Confused
Im wanting to get the rivets to show ok on mine, and must say Im a bit apprehensive when it comes to this. Went to my local model shop and we through a round a few suggestions and came up with using Tamiyas (amour) weathering!  It looks ok too.
Got home and though the instructions say use the brush dry for the "powered" effect.. I wet a small rag and tested on the base wing of the Spit.. loved the result and its clean and so easy..
Shows the soot as black on the recessed join sections of the wing ok
Tried a brown rust type the same way, not too bad (both maybe hard to define here but you can imagine when the final coat of paint is applied I guess.....)
Posted by jeaton01 on Saturday, August 27, 2011 9:27 PM
Jester
Don't sand off those lines, they represent weld seams.
John
    September 2009
Posted by satch_ip on Sunday, August 28, 2011 8:07 AM
Once again I have a knack for picking the right categories.  My Spit Mk IX took 1st in Aircraft at the San Antonio Hobbytown USA Quarterly contest.  My F6F-3N took a second.  The other guy took third.
Doogs, that Spit is AWESOME!  You have got to bring it to the Austin show next month.  Can't wait to see it in person.
Satch
    June 2010
Posted by DoogsATX on Sunday, August 28, 2011 12:57 PM
jester - Looking good! One thing about the Tamiya weathering set - I've never used it so I can't say for certain - but be sure to test how it goes down (or more importantly, comes off) over paint.
satch - Thanks! I'm increasingly leaning toward trying to bring a kit or two to the Austin show. The wife seems to be supportive enough of it. The Spit and maybe the 109. Need to figure out how to transport them....
    August 2009
Posted by JOE RIX on Sunday, August 28, 2011 3:53 PM
Satch - Good Show and congrats!!
Jester- I am still building very very slowly. I use the Tamiya kits, yet never tried highlighting panel lines with them. I prefer an oil or sludge wash for that myself. In fact I just finished weathering the tires on my Spit with the Tamiya sand color. Your doing some excellent work ther and i'm certainly enjoying your sharing.
        Joe
    September 2009
Posted by satch_ip on Sunday, August 28, 2011 4:44 PM
The latest IPMS USA Journal has an article about how to transport models.  Do you get the Journal?  If not let me know and we can work something out.  Wink
    August 2011
Posted by Jester on Sunday, August 28, 2011 6:27 PM
jeaton01
Argh really!  Wow thanks for that Jeaton, Though I thought I saw something similar on a real Spit I couldn't quite get close enough and thought that Tamiya has just left construction lines. Thanks good to know Yes
-Doogs: Yeah for sure man, this is what Im hoping it will do too >_<  ...  might test it tonight actually. Thanks
    August 2011
Posted by Jester on Monday, August 29, 2011 6:05 PM
A couple of wee niggles about the kit so far, plse dont get me wrong though, its a great build, the parts are so well made to fit together is amazing... BUT
whats with having no detailed armament and ammo!! Argh cant believe this, such a detailed model and the .303 Browning's and 20mm cannon are external view only Tongue Tied
One more thing is this kit basically being a static display model, WHY oh why did Tamiya ask us to cut off the tail rudder cable!!??  I know its to move the rudder back and forth but meh.. Im going to make another one. Will check ahead in the instructions in future Hmm
