The unOFFICIAL 2011/20012 Veteran's Group Build
    October 2005
Posted by deattilio on Sunday, March 25, 2012 10:17 AM
usmcski,  The same helicopter would have been one heck of a coincidence!  Being a modeler I click pictures that most would not bother with and made sure to grab a shot of the tail number.  She is close but is/was -209.
stikpusher,  The dry transfers look good, I will be using the same thing on my 1/72 LVTs.  That is a weird looking camouflage pattern, nice work.
kbuzz01,  The cockpit may not be accurate but it surely looks the part.
WIP:
Trying to get my hobby stuff sorted - just moved and still unpacking.
"Gator, Green Catskill....Charlie On Time"
    January 2012
Posted by usmcski on Sunday, March 25, 2012 6:38 PM
Close, but no cigar!  That would have been TOO much of a coincidence, but the two aircraft are at least close cousins.  Thanks for posting the detail photo, looking forward to seeing more of your work.
Semper,
Ski
"For the veteran, every day is Memorial Day."
    October 2005
Posted by deattilio on Sunday, April 1, 2012 8:39 PM
I have nearly finished the UGWS on my AAV.  The exhaust staining was a signature on pre-RAM/RS variants; we would keep the turret turned outboard which put the port-aft section of the turret directly in the path of the exhaust.  It was more pronounced because although tractors would go through the IROAN process at regular intervals, the UGWS turrets did not.  We would pull the turret and place a sheet of would over the position for transportation to rebuild, the turret would then be placed on the freshly painted AAV joining the unit.  We also had to remove all the EAAK and either place it in its transport boxes in the rear of the vehicle where it would be sandblasted and repainted during IROAN or it was mounted on another AAV.
I have not figured or decided on how I will paint the vision blocks as yet, that’s the current little brain teaser.
WIP:
    January 2012
Posted by usmcski on Sunday, April 1, 2012 11:17 PM
That Tuna Boat is looking GREAT!!!  As far as the vision blocks go, both AFV Club and Eduard make reflective Mylar foil stickers that look amazing in-scale.  Not sure if they are accurate for a 'Track (from what I've seen, I think the AAV's vision blocks are more blue/green, the Mylar appliques have a pinkish/blue hue depending on the light).  At any rate, YOU're the expert, not me!
Keep the pics coming!
Semper,
Ski
    July 2004
Posted by stikpusher on Tuesday, April 3, 2012 12:47 AM
That turret is looking beautiful!Yes Some serious attention to detail there.
I have been working on stowage for my duck hunter but nothing worth taking any new pics yet. Possibly tomorrow.
Okay Vets, we have just under two months left until the end date here....
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November 2006
Posted by dupes on Tuesday, April 3, 2012 8:52 AM
Alllllllrighty, the spring shows are done...can finally get back on my WIPs, including the M1037. Everything is built and primed, just need to get some time in the spray booth.
Pics to come when I've got some!
    July 2004
Posted by stikpusher on Tuesday, April 3, 2012 8:34 PM
Cool Dupes! Looking forward to your RATT Rig Wink
Today was mainly some sanding and painting little things for better fit and look on the stowage. And I made some shoulder straps out of lead foil for a couple rucks I am gonna put in the turret stowage bin.
before paint
and after
the rucks with the sleeping mats will be stowed elsewhere, the smaller ones are going on the turret.
       - Plankton
LSM
    July 2004
Posted by stikpusher on Wednesday, April 4, 2012 6:01 PM
Today was a busy day for my duck hunter. I applied a pin wash of Burnt Umber to the track, and also to most of the stowage items. Then once the wash had been cleaned up and dried it was time to start attaching stowage.
Camo net, vehicle tarp, one ruck and a couple cases of MREs on the right side
Camo net pole bag and another ruck on the front
Oil cans with lead foil tie down straps to the back of the hull
and a couple rucks in the turret stowage bin
I still need to paint the gun and vision blocks, add the antennas,and do a bit more weathering.
       - Plankton
LSM
    December 2006
Posted by kbuzz01 on Wednesday, April 4, 2012 7:16 PM
Wow!!  Looking good, Stik.  Lotsa great detail there and realistic stores.  Toast
Ken
animation6.gif image by kbuzz_photos
    October 2005
Posted by deattilio on Saturday, April 7, 2012 9:38 PM
stikpusher,  the good ole ALICE packs look spot on and preferred the days of hiking those over the much larger MOLLE.  The cammie net’s all folded up look good too, and clearly remember not looking forward to unrolling, much less rerolling those things!
I got the first coat onto the AAV and even managed to nearly finish the starboard track shroud.  I reverted to the plastic shrouds vice the PE because I was not sure how successful I would have been at filling in the foot step on the PE part.  The green came out a bit too dark and the brown not yellow enough for my liking but, it will do and weathering should tone it down a bit.  I used Archer transfers for “LOWRIDER” and worked without any fuss.  I did not bother painting the hog’s slab sides because they will be getting covered with EAAK.
WIP:
    July 2004
Posted by stikpusher on Tuesday, April 17, 2012 8:17 PM
Kbuzz and Deattilio, I am glad you guys like the stowage so far. I was working on painting up the last few detail stowage items today. Last night I scratchbuilt a couple TA-1 phone cases from sprue and strip styrene, and sanded an ammo can to be a TA-312 phone in its carry bag. I then added some thread to a empty wire spool and super glued that in place. Then it was a case of painting up a M-16A1 for the turret, some cots, and a set of binos. I also did detail painting on the fire control equipment in the turret and painted the Vulcan barrels Humbrol Gun Metal.
final bitsof stowage to be added
rear of turret fire control electronics
rear of gun fire control electronics
painted gun in place in turret
Deattilio, I never had the MOLLE pack. I did try the CFP-90 pack, but after a very hairy jump with one I went back to the large ruck. I still own one.Wink Your Amtrack is looking great and I look forward to the next set of pics.
       - Plankton
LSM
    November 2006
Posted by dupes on Sunday, April 22, 2012 2:58 PM
Howdy! Almost done with my M1037...haven't been very good about taking pics. It's so close now I think I'll just wait until I'm done. Whistling
Had a couple of (over) weathering snafus, but I think it looks halfway decent. Update soon!
    December 2006
Posted by kbuzz01 on Monday, April 23, 2012 4:27 PM
Have made a little progress on the TF-102.  Added some reinforcement and alignment bars to join the resin piece to the aft fuselage.
DSC01877.jpg 1877
DSC01885.jpg 1885
The pit's in and the inlets  are attached.  Not glued together yet, but it's starting to resemble an aircraft.
DSC01886.jpg 1886
Ken
    July 2004
Posted by stikpusher on Monday, April 23, 2012 4:53 PM
Dupes, whats teh maximum effective range of an excuse? C'mon troop, let's get some pics posted!  I am just looking forward to seeing a 1/35 1037 with a shelter...Stick out tongue
Ken, nice progress work on the TF! But boy does that conversion make a sleek beautiful bird look kinda homely...Surprise
       - Plankton
LSM
    December 2006
Posted by kbuzz01 on Monday, April 23, 2012 5:00 PM
stikpusher
Homely indeed - I just hope my model turns out to be half as ugly as the real thing.  Whistling
Ken
    July 2004
Posted by stikpusher on Wednesday, April 25, 2012 12:00 AM
Ken you're well on your way to an ugly bird... not quite X-32 JSF ugly, but still ugly...Ick!
Well today I got the last things attached that are gonne be attached: antennas on their bases, folded cots tied down on the top deck, a rifle and some binos (fairly hidden) in the turret, and the gun optics and drivers periscopes painted. Just some final weathering and I will call this one done. I was thinking of adding some figures, but if I do, they will hide turret interior detail...
       - Plankton
LSM
    November 2006
Posted by dupes on Wednesday, April 25, 2012 10:00 AM
Great looking Vulcan, Stik! Toast
Succumbing to peer pressure...felt I HAD to throw up a pic of some sort! I'm way beyond this stage right now, but at least it'll give you guys something to look at. Hope to have the M1037 wrapped up this weekend. Yes
    July 2004
Posted by stikpusher on Wednesday, April 25, 2012 5:47 PM
Your 1037 looks great so far dupes!Stick out tongue I have spent more hours/days/weeks in those things than easily counted...Indifferent
Well, I am calling my duck hunter finished. Dedicated to the men of 1st Battalion, 55th Air Defense Artillery, 5th Infantry Division (Mech).They always provided a great light show after dark on live fires Toast
       - Plankton
LSM
    October 2005
Posted by deattilio on Wednesday, April 25, 2012 11:01 PM
That M1037 is looking good, I too hope to get some quality time on my build this weekend.
The duck hunter looks sweet.  Never had the opportunity to see one of these in action, only the basic M113 locally and abroad along on rare occasions the M901 and the square-backed Med-Evac and command vehicles.
I finally attained the last kit to start a long wanted project.  In the 80’s a low-velocity 105mm cannon was mounted into an M551 Sheridan turret and placed atop an LVTP7 — with considerable modifications.  I am using the barrel from an Esci M-60, turret from Airfix’s M551 and Dragon’s AAVP7A1.
The first challenge is backdating the hull to an LVTP7 which includes major surgery to the exhaust plenum’s upper deck, reshaping the pontoons, cutting down the troop commander’s cupola, repositioning the cargo hatch supports along with a laundry list of other tids and bits.  Oh yeah, once again all in 1/72.  I am using Hobby Boss’ 1/35 LVTP7 and AAVP7A1 RAM/RS for measurements to scale various components and their placement to 1/72.
There is limited data/information readily available on the LVTEX-3.  I have a couple shots of the vehicle running around Camp Pendleton, sans turret, I snapped while at AmTrac school in ’92, couple pictures sourced from ebay and pictures I took of another LVTEX at Barstow more recently.
WIP:
    July 2004
Posted by stikpusher on Wednesday, April 25, 2012 11:36 PM
deattilio, that is gonna be one wild looking Amtrack after the conversion is all done. I had never heard of that before. I presume this was an attempt to give some direct fire firepower able to swim ashore on its own with the other Amtracks?
and I'll tell you what, laser light show has nothing on a 20mm Vulcan at night... Headphones If only I had known how to hook my walkman into the vehicle intercom system back then....Wink
       - Plankton
LSM
    October 2005
Posted by deattilio on Friday, April 27, 2012 9:09 PM
From what I have read it was an experiment for the Navy who was investigating the low-velocity 105mm canon and the LVT wound up as the platform.  I imagine it wreaked havoc on the vehicle’s CG, especially for waterborne operations – to the extent I have yet to find any photos or reports of it entering/operating in the water.  Of course that is not to say that it did not conduct waterborne tests/operations, I just have not come across any documentation.  Fortunately, I have a buddy that works at Barstow who volunteered his services to attain measurements/dimensions of the LVTEX there so that I will not have to guesstimate the modified bow/nose of the vehicle.  This will be a slow project to fill times when I am waiting on paint/glue/putty to dry on other projects as I foresee mandatory breaks to avoid frustration backdating in 1/72.
More recently, several years back an Elbit remote turret was mounted atop an AAV.  It was an impressive set-up and I had the opportunity to observe the turret on the range while mounted atop a 6x6 LAV — most impressive!  I must admit it was not as impressive as watching AC-130s unleash on Fallujah though, thus vulcans and bofors are thoroughly entertaining when afforded the opportunity to appreciate their effectiveness.
WIP:
    July 2004
Posted by stikpusher on Saturday, April 28, 2012 3:43 AM
Just curious, but do you have any info on the mesh applique armor that was used on Amtracks during ODS?
       - Plankton
LSM
    October 2005
Posted by deattilio on Saturday, April 28, 2012 6:48 PM
I never had to deal with the mesh appliqué armor — mounted on tractors anyway.  From stories from those that did deal with it said it was two-points shy of total uselessness.  I was told that the Marine Corps purchased the modification against the recommendation/advice of the test branch who recommended solely purchasing EAAK.  When I got onto Tracs, modifications were still ongoing to install EAAK and bowplanes, which resulted in zebra-striped tractors for welding the EAAK mounting bosses.  The old mesh mounting bosses were removed without finesse and the scars of grinding wheels are still apparent on the hulls today.
My interaction with the mesh armor were in roles that was never intended to fill.  There are cement ditches, which were probably drain ditches in less-environmentally aware times.  These ditches were covered by cut sections of the mesh armor.  Every Thursday we had to move the mesh and sweep/clean the ditches, and even in cut sections they were quite heavy.  The second use they were commonly employed as — BBQ grill screens.  The units use to cut old 55-gallon drums and the mesh screens for use as homemade BBQ-pits.  I will be putting that on my VA paperwork, I ate quite a few burgers from these grills over the years.
The pictures I have of mesh-armored tractors were saved from the archives of the test branch.  A person that did not appreciate maintaining old documents for history, and still does not, was purging the unit of old items and managed to force a paperless archive.  Few items were saved, many photos, manuals, reports and original videos that were considered useless were destroyed.  One photo is with armor and the other without that shows the mounting bosses.  The weight and its effect on the stance of the AAV shows how absurd this idea was, she probably couldn’t of made it over a speed bump without “kissing” the steering wheel.
The last couple pictures are of the project in ‘92/93.  Although the turret was no longer mounted, the ring was still mounted.  It also still wears some of the mounting bosses for the mesh armor, while some have been removed.  A major upgrade it underwent post-turret was installation of the Bradley suspension which finally made it to production/modification on the AAV in 1999 with full fielding in approximately 2006.
WIP:
    July 2004
Posted by stikpusher on Monday, April 30, 2012 1:48 PM
I wondered why you did not see much of that stuff. And now that you mention it, I vaguely recall seeing the mesh over drainage ditches at Pendleton when I was visiting down there a couple years back. You guys are like Eskimos, nothing off the carcass goes to waste!Wink
I was thinking of attempting to scratch the stuff somehow for a Desert Storm Amtrack, but I have very few photos of the stuff. But then again it took me almost 20 years to finally get all the info and stuff I need for a  DD Sherman- the only thing holding me back now is I just know that if I start that project, somebody will announce that as a new kit as soon as mine is almost done. That always happens to me.Super Angry
OK Vets, we have four weeks to the cutoff date of Memorial Day... the finish line is just over that hill Wink
Ruck up!
       - Plankton
LSM
    October 2005
Posted by deattilio on Monday, April 30, 2012 10:33 PM
If you do tackle the mesh armor at least it is a fairly simple affair and given the lack of wide spread and readily available data/information it is unlikely to run into a rivet counter that would challenge any measurements or its looks.  Plus as soon as you start I’ll keep an anxious eye open for it in kit, resin or PE form.
I will be in Chino this weekend for the Planes of Fame air show but will double down on my AAV after that.
WIP:
    July 2004
Posted by stikpusher on Tuesday, May 1, 2012 12:13 AM
Brother, with my luck it will be a Dragon kit... they did the last few...Wink
       - Plankton
LSM
    December 2006
Posted by kbuzz01 on Monday, May 14, 2012 11:23 PM
Sad to say that this is about as far as I'm gonna get before the deadline.  Crying   The resin and plastic came together quite nicely and have a coat of Tamiya liquid surface primer applied.  Just received the final topcoat paint in the mail today and am leaving on a two week trip, so this puppy isn't gonna be completed until sometime in June.  Any chance of an extension on the build?  Confused  If not, I'll post the final stuff in the Berny Memorial GB later.
Thanks for a nice GB Stik,
Ken
DSC01897.jpg 1897
    July 2004
Posted by stikpusher on Tuesday, May 15, 2012 3:31 AM
No worries there Ken. Take your trip, have fun then come home and finish up that buzzard for us here. Wink
       - Plankton
LSM
    July 2004
Posted by stikpusher on Wednesday, May 16, 2012 1:18 PM
Ok Vets, two weeks left here. Does anyone else need more time?
       - Plankton
LSM
    October 2005
The unOFFICIAL 2011/2012 Veteran's Group Build
Posted by deattilio on Wednesday, May 16, 2012 6:29 PM
I definitely will need more time as preparing wedding and retirement has taken precedence over time at the hobby desk.  Sitting in waiting alongside my B-36 LOWRIDER has made little progress since my last posting.
WIP:
