Carl,,, Nah,,, he is not PO'd,, he is actually smiling,, and I cannot believe that my post of s h i r t pocket got squelched... unless I spelled it wrong,,, which I doubt ,,, I will now desgniate it as a blouse,, sheesh...
Thanks Andy,, yeah, I agree,, the original heads / faces are a bit much ( but I do like the show,, The Walking Dead )
The next figure needed a bit more help.... It is a stand up figure and my original idea is to have him pushing the jeep.... I needed to bend the knees more and alter the feet into a pushing position.
First cut a wedge out of the leg(s) and heat it / them up and bend into place. (cargo pockets will be removed)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemperFi12812001.jpg)
The feet too....
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemperFi12812005.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemperFi12812008.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemperFi12812010.jpg)
Didn't like his head either,,, OFF WITH IT,,,,,
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/Jeeppics23011.jpg)
I chose a Jaguar head for this figure....
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/Jeeppics23013.jpg)
So,, some torso repositioning, legwork, footwork, head adjustment,,, - -
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/Jeeppics23020.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/Jeeppics23021.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/Jeeppics23022.jpg)
Cargo pockets removed and repaired...
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP002.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP001.jpg)
All the gaps / holes and cuts were filled, sanded, filled, buffed, inspected and primed with Mr Surfacer just to make sure.
I also changed out the arms and one of the hands,,,, anticipating how I wanted this figure posed....
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP009.jpg)
I found an appropriate hand,, and whacked off the original, replacing it...
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP010.jpg)
I attached and went through the filling, sanding, filling method.....
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP012.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP013.jpg)
With these conversions being made, I began painting. I used a custom mix for the uniform color(s) and began the process - - base coat, repeat, wash, lowlights, highlights, etc.
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP015.jpg)
You can see the right blouse pocket has been removed....
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP016.jpg)
Still a bit rough, but the blending will make the uniform look much better. Also painted the belts and straps..
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP017.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP019.jpg)
"Flesh" toning is coming.......
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP020.jpg)
Still pretty basic,, but fine tuning is on its way........
I decided to do some work on the heads.... As these heads are bald, I used some putty to sculpt some hair. I wanted to go for a Marine type haircut,,, here is what I came up with.
The Hornet head is much more clean / detailed than the Jaguar head.... both are nicer than the originals however...
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP025.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP022.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP027.jpg)
The Jaguar head,, not as clean as the Hornet,,, but the figure position will help camo the faults...
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP029.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/220SEMP031.jpg)
To be honest, both heads look better than my crappy desk photography shows.....
I have another good idea for the scene,,, will let you know if it works out.
As always,,, comments, suggestions welcome.....
Thanks for viewing
