ok all, this post has good and bad...the tale of the tape below:
The Good- had a pretty fair base coat on already and decided to paint the rudder, stabilizers and wing sections as a breather before final gloss coat.
Also did the cowlings in Silver Plate-Buffing Metalizer.
and a cowling close up...
The bad...back to that fair coat of base. I let the silver plate dry for 48 hrs, removed the masking and plastic and tamiya taped it off in preparation for a final gloss coat of black with Testors. Below were the results to my chagrin. It should be noted that my previous posts did not indicate that this issue of "to strip or not" is contained to only the top side of the right wing (approx 3" x 6" of surface area). I could opt for sand and repolish...just considering the best option with your input.
I'll go a bit larger for the next images
the rest of the final coat went pretty well...it was just this section of the top right wing. This is certainly fixable and just a small "bump in the road" (or should I say wing?)
I'll defer to the quote in kermit's signature...and proceed with the usual bulldog mentality
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
I'll have to post a before and after once repairs have been completed. LOL
...or there is always the option to morph this build into a "crash and burn" complete with diorama. I could snap off the tail section, heat and de-shape. WAIT...not a good option as the diorama would be the size of a pool table!
I'm leaning toward a sand and polish and then using a thinner to clean out the edge details...
