It must be hurricane season. If I might, I'd like to add a couple of Hurricanes to the GB. The first will be from Revell Germany's Battle of Britain set. The set comes with the aircraft shown. They are all in 1/72.
I finished the Spitfire during the summer, using DP Casper's Dunkirk-era decal sheet. It was a very challening kit, pretty crudely designed and moulded, with rather ill-fitting parts. The Hurricane was better--but not by much. I also used the Dunkirk decal sheet for the Hurricane.
First off, I attached the horizontal stabilizers to the fuselage from the inside, then set the proper angle with a protracter.
Once the fuselage was glued together, they looked OK.
There was a huge gap behind the pilot's seat. Maybe Revell figured it was OK, because there was no pilot seat included--well, just a pilot figure (wearing a modern jet-type helmet!) moulded into the seat. More about that later.
Anyway, I glued some styrene over the gap, then sanded it smooth and to shape.
I'll take a break here, since sometimes Photobucket gets ornery if I try to put too many pictures in a thread. It's been ornery enough since they reformatted.
Thanks for looking.
