I'm in with a P-47 Thunderbolt with german markings:
I'll use Tamiya's 1:48 Razorback kit with a little bit of AM stuff (seatbelts, gun barrels, engine and decals)
This will be a crossover with the Reich Defenders GB.
Clemens
I finally got started on my build of the Warhammer 40k Whirlwind.....
two shots of the uncompleted chassis
the rocket launcher base, minus the radar
the rocket launcher pods
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
Looks nice, Greg!
I am thinking of converting one of them to a SPG at some point...
SchattenSpartan Looks nice, Greg! I am thinking of converting one of them to a SPG at some point... Clemens
Thank you, Clemens! IIRC, they have an SPG called a Basilisk(?) but on a different chassis.
Here's the built chassis. Still needs a bit of putty before paint.
Yes, they do have a SPG, but I think it looks awful...
Hi Owl,
I entered with an Academy 1/72 Tempest, but I would like to do an Academy 1/72 Typhoon instead please. Starting now.
Cheers
Tony
I'm just taking it one GB at a time.
Tony, I would just go ahead. I am not sure if OWL will be back for a while. Look forward to seeing it.
Thanks Bish, well, here's the start of it.
Here's what you get, including the CMK cockpit set for it.:
I've also bought this kit, to use the D-Day scheme from it. The rest of it will feature in a later build.
The scheme I want is the one on the left.
And a little bit of progress, in between building and painting my Draken. I've drilled out the spent shell ejection chutes, which were molded as shallow depressions, and flattened the tyres.
So far, so good! Nice work on the wheels.
Alright now folks....time to don your favorite sunglasses as this one's pretty bright! My Household-6 asked it it came with a dimmer switch?!
I finally got some time to work on the Whirlwind and managed a basecoat of.....MM SUBLIME! from their Custom Lacquer System
Detail painting and markings to follow - hopefully tonight.
Electrifying!! Looks good, Greg.
Nice work here, guys! I totally forgot about my entry in here... I'll post some pics tomorrow...
Bit more progress on the Tiffie, it's ready for a wash and some paint now. I cut out the kit exhausts, which were ordinary, and inserted some Quickboost ones. You can see how I had to add some plastic strip to fix where I butchered it in the close up.
It's got a CMK cockpit set. It's didn't fit to owell, as it was too bulky to fit between the wheel wells and prevented the wing from joining to the fuselage. I used my Dremel to grind quite abit of resin of the set, and some plastic off the inside of the wheel wells.
Nice build, Tony!
Thanks CMK
Primed it. Needs a small amount of tidying up only. This is my first time with Mr Surfacer 1000, love it.
