I"ll start here with building the USS Wisconsin, BB-64, as she appeared in 1944 and 1945. The Wisky only carried one camouflage measure for her entire career during WWII. The kit is 1/700 Fujimi, and is actually marketed as USS Iowa, but the castings and parts are incorrect for either Iowa or New Jersey, and more closely resemble either Wisky or Missouri. One of the main visible differences was the radar array on the foremast, otherwise armament seems to be nearly identical.
I have all the parts separated from the sprues, mold-lines cleaned up, sanded, smoothed and prepared for painting.
After studying the construction steps and parts, I decided I would need to finish the deck and hull component, attach the three 16-inch gun turrents and add the waterline plate early. The main batteries are attached to the deck with holding pins from underneath (so they swivel), and the deck comes molded to the hull, except for the forward section. I decided all this needed to be done first, so the deck could be painted before the hull. This is only the fourth ship I've built, and it seems a lot of ship assembly consists of deciding what to put together first, and when, in order to make painting easier.
The first photo shows initial masking amidship. The deck and molded-on superstructure has already been painted with WEM Colourcoat's Haze Gray. I used regular paint masking tape from Walmart (a 3-M product), but noticed that the gummy adhesive tended to pull off the tape and leave residue on the surface. I haven't had this happen before with this brand of tape.
The second photo shows the locations for the two aft-most main batteries, and visible in the upper left corner is the opening where the forward section of the main deck will fit.
The third photo shows more of the fore section of the deck. The kit shows its age. I'm guessing it might have originated in the 1970's. The liferafts are cast into the deck and there are no details like portholes, windows or doors molded into the superstructure--just plain, blank walls. It's kind of stark.
The last photo shows the fully masked deck and hull, with the foredeck in place. Gunshields for the 20mms and some of the tubs for the 40mms were molded on, so they had to be masked both front and back. This can be a challenge with strips of tape cut so small and narrow. That's the other part of ship building--mask, mask, mask. The deck will be painted standard 20-B Deck Blue.
Now the next steps will be painting the deck, then assembling, painting and attaching the 16-inch guns. I've got a start on these, and plan to post photos of those steps soon.
Thanks for looking.
