here's a little more in depth look at my 77x car.
i began the rebuild by scrubbing my previous attempt at weathering away to reveal the paint: thick, semi-gloss black. i knew that the paint was going to keep me from "denting" the body with the lighter method anymore, so i sat back, started thinking as i began to strip paint. i was thinking of photoetch for some reason,and i thought "i can made my own photoetch... with aluminum".
i experimented with the other car first, with promising results. so i sprayed some primer, and made more body panels. i bent the frame up more, and tailored the panels to fit by bending them with the frame
this was the original motor i was going to use, the 383 stroker that comes in the revell special edition 69 nova. i was going to use it with upright headers, but felt i needed something with a little more kick.
ill post more later, having trouble with photobucket at the moment.
Regards, Logan
1/35 XM77 "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
