Canadian GB
    April 2006
Posted by waynec on Monday, October 7, 2013 9:59 PM
sweet build
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    April 2006
Posted by jgeratic on Tuesday, October 8, 2013 1:20 AM
Colin, quaint little build you have there.  I find warships so much more interesting when they carry those broad swathes of colour camou.   Good to see a ship in the mix of this GB as well.
Hmm, well I thought building  a Shermie would go faster than the Tiffie.  I've doubts now that it will meet the deadline, but here is an update:
Staring with the hull floor, it is a bit wonky.  On one side, the center curves outwards, while the opposite is slightly curved in.   Could be just the nature of the beast, or a quality control issue.
Four main pieces glued together.  I didn't bother sanding too much of the 'yaw' shape of the floor as it won't be noticeable.  Another problem area now is one side wall comes up short, (interestingly it is on the convex side of the curved floor edge).
 Dry fitting the transmission housing, it looks it can be corrected by placing a shim in the space.   A little more sanding should close the gap, and make sure every angle is perpendicular.
Sherman Vc finally taking shape.  After cutting the floor and attaching the front piece, replaced the lost detail with a thin strip of sheet plastic.  Both upper and lower hulls had to be braced from  inside to correct the wobbly shapes to the walls.  This resin is not the type I'm use to. Very soft, and not very strong when thin - recycled product?
The back plate that over hangs the hull also had deformed edges.  To achieve crisper corners, a thin strip was glued across the bottom, filled in, and then sanded.
The port hull side wall was still misbehaving, yawning inwards.  Squadron putty to the rescue - this will take several sessions of building up and sanding.
A single thin sheet of plastic was used to cover  the hollow sponson areas, and once that was sandwiched between the upper and lower hull sections, I noticed the back plate wasn't parallel with the bottom hull.  Another shim made of sprue, was strategically placed in the suspect corner, with a clamp holding it in place while the glue dried.
Front detail is now done, just one more shackle to make.
I've reworked the major  weld lines, masking the edges off with Tamiya tape, brushing on a couple layers of surfacer, and then scouring with the sharp end of a knife before it completely cured.
The spring on the hatches was made by twisting speaker wire around a small drill bit.
regards,
Jack
    May 2005
Posted by pyrman64 on Tuesday, October 8, 2013 6:52 AM
Jack, she's looking good, so far!
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
    February 2011
Posted by gunner_chris on Tuesday, October 15, 2013 2:26 PM
Its official, the Arrow that I was building has suffered the same fate as its 1:1 model.
After fiddling with the paint, getting beyond frustrated causing me to just walk away for a period of time I have given up.
During my absence I have tried but to no avail.
But I did get the bug again, and start in on an M7 I was doing for the HGWT3 build, so that will be my new Canadian build.
I've finished most of the sub assembly thanks to dedicating today on just building.
The instructions were terrible, leaving the placement of items very vague at best.  It slowed things down because I would stop, then go on the iphone looking for walkaround photos to fix the part in question.
Its assembled enough that its ready for priming.
I will go through and get caught up on everyone's progress to date, if I miss an entry on the front page or a completed kit please send me a PM.
    February 2011
Posted by gunner_chris on Tuesday, October 15, 2013 2:43 PM
This GB is also set to end at the end of the month - does anyone need more time?
Personally I know I will be tight, but I don't want to extend it just for me but I'm open to others thoughts......
    April 2006
Posted by jgeratic on Tuesday, October 15, 2013 7:34 PM
Hi Chris,
I definitely would need an extension, probably to the end of November.  I'm in the middle of scratch building some deep wading gear for my Firefly, and still have the tracks to put together.  I had planned to already have hit it with paint last weekend, but doing research while building has put me off my intended schedule.  Hopefully this weekend.
Here's where it's at now.  There should be gun cleaning rods  located at the position in the update pic, but they are absent in particular photo I'm working off - likely have been stored in the rear bin.
regards,
Jack
    November 2003
Posted by tempestjohnny on Wednesday, October 16, 2013 2:49 PM
Yes please.  Been a crazy summer. just getting back into the swing of modeling again. John
Posted by VanceCrozier on Wednesday, October 16, 2013 7:27 PM
Chris!!! Your Arrow.... she didn't end up in Lake Ontario, did she???
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    February 2011
Posted by gunner_chris on Thursday, October 17, 2013 5:40 AM
With a swoop of the edit button, we're good until the end of December.
Vance that would be an epic end for my model, strap some model rockets to her and test those aerodynamics.  Of course my luck one of those hopefuls trying to find the original test planes will find mine and think they scored.
Posted by VanceCrozier on Thursday, October 17, 2013 7:19 AM
Good stuff on the extension, I'll need that long to get caught up on the stuff I've missed!!
    February 2011
Posted by gunner_chris on Tuesday, October 22, 2013 10:43 PM
Ever get that horrible feeling when after you apply the second coat of paint, following a coat of primer........you forgot to fill in some gaps and seams.
Oops.
I also posted a question in the armoured area but maybe the fellow Canucks or Canuck followers nights know.  Before dday the US loaned Canada M7's, and they were for the most part returned in August following the landing for their towed 24 pdrs.  Would Canada have marked them for the 3rd Division or left them marked as US Army artillery?
    April 2005
Posted by taxtp on Tuesday, October 22, 2013 11:18 PM
Excellent work on the extension Chris. I was about to do a 1 week rush job on my Chipmunk. A little more time allows me to try and plan better this time around. BTW, does anyone have a good photo of what a Chipmunk seat should look like ?
Cheers
Tony
I'm just taking it one GB at a time.
    April 2005
Posted by taxtp on Tuesday, October 22, 2013 11:26 PM
Hi Jack,
I just caught up with your Sherman, looks fantastic.
Cheers
Tony
    April 2006
Posted by jgeratic on Wednesday, October 23, 2013 1:21 AM
Chris, here's a great pdf file from the AmouredAcorn site showing markings:
www.armouredacorn.com/.../CVM%20Part%206%20%28Priests%29.pdf
... and these photos appear to confirm the use of markings:
regards,
Jack
    April 2006
Posted by jgeratic on Wednesday, October 23, 2013 1:31 AM
Hi Tony,  thanks for commenting on the Firefly.
I've airbrushed a coat of primer on her and am in the middle of applying texture to the turret and transmission cover.
Here's the last update photo with the shiny bits:
regards,
Jack
    February 2011
Posted by gunner_chris on Wednesday, October 23, 2013 10:45 AM
Jack - thanks for the reminder on that site, can't believe I forgot to check there.
Especially in the case of the pictures depicting the guns from the 13th RCA, I'm assuming those bags at the front and rear are probably cam nets, especially from the bottom picture you provided.
    April 2006
Posted by jgeratic on Wednesday, October 23, 2013 6:14 PM
Chris - hessian tape camou netting, yes that is in one of the photos.  As for the ArmouredAcorn artwork, can't say for certain what the artist intended to depict here - could be netting, maybe a  tarp thrown over gear, or just a simplified rendering of what could be stowed on these vehicles.
regards,
Jack
    April 2006
Posted by jgeratic on Tuesday, October 29, 2013 1:34 AM
Just a quick update, added some extra surfacer to the turret and transmission cover to create that cast look.  Main colour is now on, some weathering on the bottom, and markings in place, all home made decals.  Still thinking about the air recognition star...
regards,
Jack
    February 2011
Posted by gunner_chris on Tuesday, October 29, 2013 2:50 PM
Looking good Jack
I'm still slowly slugging along weathering my track
    April 2006
Posted by waynec on Friday, November 1, 2013 4:42 PM
have you given any thought to a canadian 2 GB? i have a few more warwheels in the stash.
Posted by shivinigh on Friday, November 1, 2013 10:01 PM
I would be interested in doing a Canadian 2 GB. I have a couple kits in the stash still that would work
    February 2011
Posted by gunner_chris on Monday, November 4, 2013 10:54 AM
I think a Canadian 2 GB wouldn't be out of the question.  I too have a couple things I could do, or others I could buy and build......I would say in the new year.
As I slug along with this M7 I've added some track, had to fill some seams so primed them and its back into the spray booth (cardboard box) for OD round 2.
    February 2011
Posted by gunner_chris on Saturday, November 9, 2013 2:14 PM
I drove by the Canadian Warplane Heritage museum today, saw a black CF100 outside in a shiny black finish.
I think I know what my Canadian GB 2 kit will be.......
    April 2006
Posted by waynec on Saturday, November 9, 2013 3:38 PM
i will be doing a warwheel, probably a modern 6x6 but maybe a WW2 chevy truck
    February 2011
Posted by gunner_chris on Sunday, November 10, 2013 10:12 PM
I know I need to finish this one first!
I fixed the track, found out through the Have Gun Will Travel 3 GB that one of the tracks were backwards.  Oops.
Working on some of the detail painting now.
    April 2005
Posted by taxtp on Monday, November 11, 2013 8:38 PM
I've finally made a start on my little Airfix Chipmunk for this GB. Luckily, it's a fast start as I have a few to get done by year's end.
It's a pretty old boxing, I think:
But it comes with a really good decal sheet with three options, and I'd like to do all of them. There's the Cambridge squadron option on the box top, an RAf 'raspberry ripple' trainer, and the Canadian option that I'm doing for this GB. I also have the current boxing of this kit with the black version, but that's for another time too.
The only aftermarket I could find is this interesting sheet of instrument panels and harnesses. The idea is that they are self adhesive, and you use the belts directly onto the seats, but stick the panels to some plastic card before affixing it into the fuselage. Interesting, not sure that I am too convinced, but the thick Airfix canopy distorts everything anyway, so it will at least create an impression of some cockpit detail. The kit gives you basic seats only, no side wall, instrument panel or joystick, it's strictly old school.
I brush painted the interior, black hides any sins, and got the early construction done. I haven't used the cockpit details yet n this photo.
I filled the gaps in the fuselage using CA, run thinly into the joins then zapped and sanded. BTW, the Airfix rivetter had a great time with this one, but I'm not going to do much about it. Then attached the wings. The fit is Ok with some small gaps to deal with.
Completed the main construction, using Tamiya putty tidied up with a Q-tip dipped in Tamiya lacquer thinner to clean it up. This took an hour or two, but all done now.
I'll paint the cockpit surround flat black as the next step and attach the canopy and undercarriage struts. It's blowing a gale today, so it stirs up any dust in the garage where I spray, so I probably won't prime it until the wind settles.
Cheers
Tony
    February 2011
Posted by gunner_chris on Tuesday, November 12, 2013 8:47 PM
Nice progress - looking good Tony
    April 2005
Posted by taxtp on Monday, November 18, 2013 1:43 AM
Thanks Chris, here's the first primer coat, needs a little more work before I proceed. I used a mix of Tamiya acrylic gloss and flat white.
Cheers
Tony
    April 2005
Posted by taxtp on Friday, November 22, 2013 1:35 PM
Last night I got the 2nd primer coat down on the Chipmunk, then sprayed it all yellow. Maybe we should call it a canary. I'll let it dry for a day or two, then mask off the day glow red panels.
Cheers
Tony
    August 2012
Posted by AndrewW on Saturday, November 23, 2013 11:42 AM
 Well, I've reached a point where I can call my Spitfire Vb Trop (marked out for Canadian George 'Buzz' Buerling in Malta) about finished.  The only thing left to do is buy a new (not dried up) bottle of super glue, attach some e z line for an antenna and glue the plane to the base (still debating building a set of wheel chocks).  Not exactly how I wanted it to turn out, a had a layer of gloss go all orange peel on me which really threw a wrench into things.
 I had to walk away from it for a while, but on coming back into it, I was a little less angry with the result.  Not the very best I could have done, sadly, but I don't think it's my worst either.
 I'm hoping this will live on the desk of one of my work associates (he is from Malta, and apparently a bit of a fan of Buerling's) and pass for reasonably good looking.
I went with the decal kit's recommendation of Malta Blue Grey for the time period, and a few references I've seen show the plane in either the blue grey or middle stone / earth / azure.  I figure I've already done a Tiffy in the three tone, I would do the Spit in the single colour topside.  The bottom is of course Sky Blue.  The Malta Blue Grey in this case is a mix that came pretty close to colour chips that I've seen (at least to my eye).  The entire aircraft was painted using Vallejo's model air acrylics, pin washes were done at first with Flory's Dark Dirt, but as I mentioned with the gloss going south, I finished by using a combination of oil wash and dot filtering (as I felt I could control these a little better).
All in all, a lot of fun, the first group build I've entered and posted finished work in, though mine does not come close to some of what's posted up here.  Excellent work, gents.  Chris, thank you for the opportunity, much appreciated.  Cheers Beer
I think in the end, I was most impressed by how much of the airframe is power plant, really puts into perspective just how much of a meat and potatoes approach this airplane was.
Life is hard, it's even harder when you're stupid - John Wayne.
