Rommel vs Monty (North African GB 1941-43) Jan. 1 - Aug. 31 2014
    May 2011
Posted by armor86 on Saturday, March 1, 2014 11:09 PM
AlanF the Scout looks great - Mike the British aircraft is coming along - 232 RAD 8 - next step was to apply a filter to the German Grey finish - Blue Filter for Panzer Grey - brush it straight from the bottle, however I went back over with thinner to vary the finish. Use AK Interactive 071 an enamel base paint. Photos after it dried
Right after applying it -
The next step is to apply the Heavy Chipping (AK) acrylic paint - is a fluid to create big chip surfaces and scratches in a scale. Apply using a brush. Natural I will be applying an acrylic paint over it. Reviewing what I have on hand - either will use AK Interactive RAL8000 Gelbbraun (AK 702) or Vallejo Acrylic Surface Primer RAL 8000 German Green Brown using an airbrush. Reviewing B/W photos and reference books with color plates it seems a bit dark. After applying it I will go back over with lighter color to get a faded look. Armor86
Dan
Posted by Bish on Sunday, March 2, 2014 11:19 AM
Alan, now that is very nice, I like it a lot. Great build
Posted by Bish on Sunday, March 2, 2014 11:21 AM
Looking good Dan. So does the chipping fluid only work with an acrylic paint on top of it.
    April 2006
Posted by jgeratic on Sunday, March 2, 2014 11:09 PM
Dan, that Scout Car turned out real nice. Yes
It's very different seeing an American scheme in three colours.
regards,
Jack
    April 2005
Posted by Thunderbolt379 on Monday, March 3, 2014 12:55 AM
Hi all -- quick update. My Plastruct order has arrived, so I can get on with the conversions to the Pz. IV -- expressly the hex rod to serve as bolt heads on the extra armour and missing details inside the fenders. Also, I'm not far off done with the masking for the final camo colour on the Spit, that might be done tomorrow. If so. I'll press on and apply the last shade, then it should be downhill to the finish, more or less.
M/TB379
http://worldinminiature.blogspot.com/
Posted by Gamera on Monday, March 3, 2014 8:05 AM
Alan: That's a terrific looking scout car, well done sir!  Yeah, it's neat to see something US in other than olive drab for a change!
Dan: The armoured car is coming along great, looking forward to seeing her with the sand camo on and chipped up.
Bish: If I may 'chip-in' here (sorry) I've only used the fluid on acrylic paint, I'm not sure it would work for enamels or other types or not. You can get pretty much the same results with hairspray, though the fluid is more concentrated and since you're spraying it with an airbrush easier to do a controlled spray. You could always take a scrap model, hit it with two-three runs of hair spray, then spray it with the paint of your choice, and then chip it off with an old toothbrush. Anyway that's how I experimented with it, fairly cheap way to see what works and what doesn't.
    May 2011
Posted by armor86 on Tuesday, March 4, 2014 10:17 PM
DAK 1941 Sand Camo - Put two coats of Heavy Chipping - use a Tamiya mix of XF-60, XF-49, and XF-2. Lighten the mix some to highlight surface panels. Let it set overnight before chipping. Armor86
Dan
    January 2013
Posted by jibber on Wednesday, March 5, 2014 6:02 PM
Looking really good Armor, coming along nicely.
Posted by Gamera on Thursday, March 6, 2014 9:04 AM
Dan: Nice!!! Looking forward to the chipping and scraping!
    January 2013
Posted by jibber on Thursday, March 6, 2014 4:57 PM
Armor, how about the suspension on that Rad 8. I thought it was some of the most intricate I've assembled. That isn't the AFV kit is it?
    May 2011
Posted by armor86 on Friday, March 7, 2014 12:50 AM
Jibber - No it's not AFV - older Tamiya kit - DAK version - the kit comes together easy just needs some up dating ... the under side is somewhat lacking when compared to the AFV ...  spent a hour and half chipping and scratching it up ... post photos Friday night. Armor86
Dan
    April 2006
Posted by waynec on Friday, March 7, 2014 9:58 PM
jibber
you should check out the suspension system on the revellgermany bundeswehr FUCHS 6x6. and it isn't as intricate as any truck, military or commercial. half the build on the UNIMOG 4x4 is suspension system. and my BEDFORD isn't much different. BTW I NEED SOME SUGGESTIONS on the best wat to do a cargo bed canvas top or camo net. i have the ribs.
UNIMOG
BEDFORD
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    July 2004
Posted by stikpusher on Friday, March 7, 2014 11:42 PM
Ribs are best done over a low open flame with lots of basting...  ;-)
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2011
Posted by armor86 on Saturday, March 8, 2014 1:44 AM
Nice  looking Bedford truck - RAD 8 232 looks chipped and has that scratched look - photos - Armor86
Dan
    April 2005
Posted by Thunderbolt379 on Saturday, March 8, 2014 4:11 AM
Armor86, she's really coming along!
Some progress on the Spit: since I last posted, I've kept plugging away, first the extensive masking to define the camouflage pattern:
I reused some pieces of tape from the recent Bf 109 project, plus new stuff. I corrected some curves with rubber solution, then applied the last shade, a 1:1 mix of XF-52 Flat Earth and XF-49 Khaki, which I found visually preferable to other mixes I researched online. Then the masking all came off, and the three shades were used to do some minor touch-ups, and an oilpaint filtre was used to create the common oil streaking on the underside and staining behind hinges and shell ports. The first clear coat went on, followed by the Flory wash (Dark Dirt overall):
Here's the underside, showing the oil wash:
Next up will be another coat of clear to seal the panel wash, followed by decals tomorrow, then they get sealed and it's downhill to the finish, with final assembly and detail painting.
Cheers, Mike/TB379
    April 2013
Posted by SchattenSpartan on Saturday, March 8, 2014 9:43 AM
Awesome work guys!
I just came back home from a model show and I got me some AK stuff there:
  • Africa dust effects
  • Dust effects
  • Streaking´grime
  • DAK wash
I never used AK products before but I see a lot of people getting great results with them, so I decided to give them a try on my Tiger and Pz IV.
    April 2006
Posted by waynec on Saturday, March 8, 2014 3:09 PM
ha!. doing a pork tenderloin tonight. your ribs comment reminded me of the brotosaurus ribs fred flinstone would get.
BEDFORD WIP pics. broke a side mirror sanding and couldn't find it in the carpet. wrote it off and 2 hours later i sat down to work on it and it was on the work table so i CYAed together.. added decals, water cans, spare tire, chains, doors. not sure if i like the "straps" for the spare tire and may replace them with rope. (COMMENTS WELCOME) will have winshield folded down and wrapped in a tarp and cab top rolled and syuffed behind the frame. i know what i want to do with the canves for the back but not sure if i can pull it off in which case it will be rolled and attached to the left side. the weathering is oil washes except for a little bit of powder for rust beacuse i was too lazy to mix some "rust oils"
this is the smallest base unless i jyst do a straight shot with some grouns all my towed guns. the soon to be new IPMS rules on bases in non vingette/diorama categories means not doing a fancy base or doing one with a story and possibly figures.
    May 2005
Posted by pyrman64 on Saturday, March 8, 2014 4:57 PM
Wayne: it looks good.
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
    January 2011
Posted by Chazzer on Saturday, March 8, 2014 11:07 PM
Hey guys, I need a bit of help. I posted picts of my tiger in the wrong spot. Is there any way I can transfer the post to our group build?
ChazzerBlack Eye
    May 2005
Posted by pyrman64 on Sunday, March 9, 2014 1:29 AM
just copy & Paste it here.
Don't forget to delete the other post.
Greg H
    July 2004
Posted by stikpusher on Sunday, March 9, 2014 1:56 AM
waynec
Had Japanese food tonite myself... my son had his Eagle Scout Court of Honor and that was what he wanted for dinner...Eats Banzai!
       - Plankton
LSM
    April 2005
Posted by Thunderbolt379 on Sunday, March 9, 2014 7:54 AM
WayneC -- fantastic truck, that undercarriage is amazingly textured!
I've been decaling all day, just a few to go on Gleed's Spit. I'm hoping to seal them tomorrow, and get into final assembly.
Cheers, M/TB379
Posted by Gamera on Sunday, March 9, 2014 1:16 PM
Wayne: Looks great! Very nice weathered look and love all the extra details you stuffed in there. Only thing I'd change is to sprinkle a little sand on the base there for the photo!
Dan: The chipping looks great, very cool.
Mike: Beautiful work there, looking forward to seeing her with the decals in place.
    April 2006
Posted by waynec on Sunday, March 9, 2014 1:48 PM
Gamera
thanks to all
oh it's not done yet. i still have windshield, mirrors, and tarps and/or camp net to put on. and i haven't decided if i am putting it on a nondsecript sand base or tey to tell a story and even add some figures.
taking a break and working onJGSDF SPAA tracks. what joy. it's why i do wheels ans may have gotten the nickname WHEELS at my denver club.
Posted by Bish on Sunday, March 9, 2014 2:10 PM
wayne, now that is sweet. Love it.
    January 2011
Posted by Chazzer on Sunday, March 9, 2014 7:56 PM
guys
I need a bit of help. I accidentally posted my build photos in group builds under its own heading "Tiger I initial". Is there any way I can move this post into our build?
Thanks
Scott
ChazzerBlack Eye
Posted by Bish on Monday, March 10, 2014 7:26 AM
Scott, the only way to do it is to just copy and paiste into here.
    January 2013
Posted by jibber on Monday, March 10, 2014 12:31 PM
Very cool Wayne, a different type of model theme and just awesome work.
    April 2013
Posted by SchattenSpartan on Tuesday, March 11, 2014 8:17 AM
Great looking work, wayne!
    January 2003
Posted by dogzilla17 on Tuesday, March 11, 2014 3:54 PM
Hi Tigerman - I'd like to submit a late entry -- just started the older Dragon Pz IV F1(9044) -- not entirely accurate but goes together quickly-
Regards,
Dog
