100th Anniversary of WWI GB
Posted by Bish on Sunday, September 28, 2014 3:48 AM
docidle
Bish,
Actually, I think every ship builder paints and builds a bit differently.  In this case, I am going to paint the decks first and then paint the structures on the deck next since it is easier to mask a horizontal surface than a vertical.
Once those are painted then the hull colors will be painted on the lower hull and the flying deck.  After those dry then I'll add weathering to everything.  After this I'll go ahead and glue the flying deck to the main deck.  At this point, all the superstructure and turrets will be built and glued on.  I plan on replacing the masts with brass rod since the plastic masts won't take a strain, even with EZ line.
Since I normally rig sailing ships, this will be rather mundane except that I have never used EZ line before.
Steve
Ye, I guess its like any other model and working out what's best for you. I just look at some of these ship models and my first thought is, where do you start. But I guess coming from sailing ships, the modern ones are rather un cluttered.
    November 2008
Posted by plasticjunkie on Sunday, September 28, 2014 7:25 PM
Shot some Testors flat lacquer to kill the Future gloss for the Jasta 29 fuselage markings. The Lozenge was a bit of a challenge cause those decals are over 25 years old and were very delicate. I had to use several craft acrylic colors to custom blend matching shades to touch up some decal parts that were either too short  or just flaked after applying.
The bottom 1/8th trailing edge had to be painted to complete the pattern.
The scratch built cockpit improves the looks of this old Aurora/Monogram kit.
This one is done and will probably jump in again with something else.
 GIFMaker.org_jy_Ayj_O
    January 2014
Posted by Rob S. on Sunday, September 28, 2014 7:46 PM
Right on plasticj...she turned out great. Well done man!! Your attention to detail is incredible YesYes
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    June 2010
Posted by rocker286 on Monday, September 29, 2014 12:17 AM
Rob and Bish - Thanks for the kind words and help with the badge!
Plasticjunkie- you did a heck of a job on that Fokker! Looks Great!
4badges
    September 2013
Posted by Marcus McBean on Monday, September 29, 2014 5:53 AM
Plastic,
Great looking fighter, I really love the green and yellow colors.  I would like to see a F16 painted in that detail sitting on the tarmac at Lackland AFB.
Marcus
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 6:31 AM
Thanks guys. There are so many schemes that it's hard to pick one.
    April 2005
Posted by wing_nut on Monday, September 29, 2014 8:35 AM
Rocker you really rocked on that one.  May have been your 1st bipe but I'm gonna bet this won't be your last.  Nice.
Plasticjunkie, that is  soooo far away from plastic junk.  Excellent.  Nice touch ups on the lozenge.  great build.
Marc
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 9:05 AM
Thanks Wnut!
    April 2005
Posted by wing_nut on Monday, September 29, 2014 10:17 AM
Getting' tough to keep up with you guys.
A bit more done.  I don't see how glue would ever hold the control surfaces in place so I drilled and pinned them and they are nice and secure.  The bottom wing has the cockpit floor panted as wood but it is barely visible.
There are 2 options for the center section of the upper wings.  Some “Harry's” had clear cellon over the center.  And some of these where painted over. The kits come with types of center sections, 1 in gray plastic and the other in clear.  I am wondering if here was a version of the model that was planned to use the clear parts since none of the schemes in the kit have it other than being painted over.  And the internal stuff to assemble the wings is wrong to be seen through the clear.  I roughed the surface with a Scotch Brite pad to give it some tooth for the paint.  And then the upper wind ready to go.
Fuselage closed up and the tail feathers starting to “grow”.
Marc
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 10:32 AM
Wnut
That is one cool looking old bird build! Love that engine detail.Yes
    April 2006
Posted by jgeratic on Monday, September 29, 2014 10:55 AM
Guys, very impressive work,  everyone is bringing their A game to this one.  Congrats to those completed so far:
plasticjunkie - great job with the lozenge decals, and that scratch build cockpit looks pro. Yes
rocker - sweet work on the Nieuport, stunning colours. Yes  Is that a magazine cover on the upper wing surfaces?
falconmod - another fine Albatros added to your collection.   Long and delicate decals like that dragon aren't easy, but you got it on perfectly. Yes
Rob - that Roland,  she's a show stopper.  Everything looks impeccable, and that fuselage wood work is first-class. Yes
Doug - the DVII simply brilliant.   Maybe not as colourful, but those b/w stripes are still just as eye-catching, if not more. Yes
Hope I got everyone's finished builds.  If I missed someone, let me know.
My plan is still to do a bust for this one, but with all the fine work here representing aircraft, it's hard to resist and not join in with a bipe of some kind.
regards,
Jack
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 11:11 AM
Thanks, much appreciated Jack!
    January 2014
Posted by Rob S. on Monday, September 29, 2014 3:10 PM
Golly, geez, thanks Jack!!
Posted by Bish on Monday, September 29, 2014 4:36 PM
Really getting a production line going now. Another great build PJ. Love that pit.
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 5:37 PM
Thanks Bish!
    February 2006
Posted by ruddratt on Monday, September 29, 2014 10:26 PM
pj - just amazing work on the D.VII !  Hard to tell there were any issues with the build at all.  That cockpit is  awesome - some serious scratchbuilding skills on display there! Can't wait to see what you come up with for an encore. Yes
rocker - Your first entry into the world of WWI bipes is an absolute joy to look at!  Love the camo work especially and I'm happy that you found the rigging a fairly easy go.  Good stuff man!
Marc - as usual, just jawdropping work on the 'Tate.  This one's gonna be fun to watch!  Yes
Nice to see that the ship guys are still around too.  That is some intricate work we're seeing!
Work has been progressing steadily on the Roland and I'm liking what I see so far. No issues - just a pleasure to build.  The 'pit is almost done - tried a few techniques new to me and pulled 'em off OK.  Should have some pics up soon.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    November 2008
Posted by plasticjunkie on Tuesday, September 30, 2014 6:21 AM
Thanks Rratt!
    April 2005
Posted by wing_nut on Thursday, October 2, 2014 7:05 PM
A bit of progress...
While the lower wing and engine cowl panels were curing I started in on the guns.  Added the rear braces and made the cables out of twisted .003 wire.  A small ring made from lead wire was added to the part where the cable wraps around since it is actually a pulley and the kit part was flat.
And what it will look like when mounted.
Marc
    January 2014
Posted by Rob S. on Thursday, October 2, 2014 8:49 PM
Simply masterful, Marc...inspirational and motivational!
    June 2010
Posted by rocker286 on Thursday, October 2, 2014 10:36 PM
wingnut - thanks! This definitely won't be the last WWI warbird I put together- not to mention a few 1930's bipes I have lurking in my stash- an He-51 is in there somewhere...
jgeratic- Those are actually Liberty Bond posters! They give it a nice nostalgic touch I think!
ruddratt- Glad you dig the camo - I am getting better at mixing colors...the majority of them were either lighter or darker shades that I played around with to get the most accurate color possible - cant wait to see shots of your Roland!
4badges
    November 2008
Posted by plasticjunkie on Friday, October 3, 2014 6:35 AM
Wnut
Incredible details in these WNW kits! Your twin mount looks simply deadly realistic. Fantastic attention to detail.
    April 2005
Posted by wing_nut on Friday, October 3, 2014 10:42 AM
Hey guys.. thanks so much for the kind words.
Marc
Posted by Bish on Friday, October 3, 2014 12:16 PM
That's wonderful marc, those MG's look really nice.
    April 2013
Posted by SchattenSpartan on Friday, October 3, 2014 5:32 PM
There's some fantastic work going on in here! Every single model you guys are building looks absolutely perfect!
    April 2005
Posted by wing_nut on Monday, October 6, 2014 7:10 AM
OK, it's not a lot of paint but it's that, "Ahhh, finally sprayed some paint." milestone.  Masking that engine and the pipes was... interesting Whistling
One photo in the WNW instruction book show the early LG that has a metal frame and wooden fairing being wrapped with cloth to hold it together.  Dunno if this is the standard method or was unique to that bird but I've taken a bot if license and tried to reproduce that.  After trying several much thinner materials and it tearing with every wrap I ended up with Tamiya tape.  Lead wire was used for the elastic cord around the axles.
And lastly the prop.  I forgot to add some japan Dryer to the oil so I hope this dries by the time the build is done. Indifferent
Marc
    October 2008
Posted by Rigidrider on Monday, October 6, 2014 10:52 AM
Wingnut... all I can say is WOW! Amazing amount of detail so far and you still have a bit to do. Again...WOW!
Doug
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    January 2014
Posted by Rob S. on Monday, October 6, 2014 3:02 PM
Amazing use of a super common building tool...Tamiya tape..thanks for that Marc!!
    April 2005
Posted by wing_nut on Monday, October 6, 2014 5:04 PM
Doug, Rob... thanks guys.
Marc
    February 2005
Posted by 65ss on Monday, October 6, 2014 8:09 PM
The work being done in this GB is second to none!
Wingnut that is some amazing detail!
Plasticjunkie your Biplane turned out great!
Rocker the Nieuport came out great!
John the Albatross is stunning in all its colors!
Rob your Roland is simply amazing! I could stare at the pictures of the complete build for hours!
Well here is a couple of pictures of my own meager progress
Dale
    January 2014
Posted by Rob S. on Monday, October 6, 2014 8:21 PM
Big thanks 65!! Your engine looks like its gonna start up!! Great job!!
