lawdog114
Hey Bish, since I hit a brick wall with my Dauntless, can I jump in with this guy? I scored it off E-bay. If so, pencil me in!
Joe
Checking in from Kette 12. Well I'm at my wits end with my Dauntless and have shelved it for now. I figured I'd switching gears for a while and hanging out with youse folks in this fine GB. It should be theraputic. Thank you for having me. I spent the last hour or so catching up in here. Only thing I can say is Wow!. I also find the reference photos useful as well. Here I'll have a crack at the 1/48 Hasegawa Stuka B-2. So far, I got Quickboost seats and canopy masks from Eduard. I may get wheels, guns and exhausts too...we'll see.
I intend to do a Battle of Britain Stuka with the "Jericho Trumpet". I'm curious to why most Stuka decal sheets represent B-2s from the Russian front? Was the B-2 not used over England in 1940? I did find a Superscale sheet that has two B-1s and a B-2 from the summer and fall of 1940 (#48-0833). I'm may try to convert the B-2 into a B-1, or "fudge" it. My research said the main difference is the exhausts and the radiator flaps under the chin. I also read that "late B-1" Stukas had the exhausts upgraded to the B-2 versions? Any help here would be great for I am not Stuka expert. Understand that "close enough" is good enough for me.
Anyways, on to the build. I got alot done last nice....
I thought the cockpit on the kit was okay...not great, but okay. I've seen much worse. Lately I've been on a trend of using out of the box 'pits that are hard to see, perhaps to save time, dough and energy. The Dauntless, which is similar in design, proved this to me. Besides,careful painting could go along way right? I figured with this guy I would just replace the seat and be done with it. Its the main focal point of the 'pit anyways. There is a kit supplied decal for the instrument panel. I decided I would use that too. Here I laid out all of the cockpit pieces.
I got alot of positive feedback on my step-by-step cockpit detailing on my Dauntless WIP thread. I figured I would do the same here, except with a German cockpit this time.
I started by spraying everything XF-1 Flat Black. This allows for shadowing when the interior color is added. My research showed that German 'pits were RLM 02 during the Battle of Britain then changed to RLM 66 sometime in 1941. I used Gunze Aqueous RLM 02 thinned with X-20 for this.
Then its detail painting time. My method involves Tamiya paints dipped into 91% Isoprophyl. The alcohol makes it dry very fast and prevents streaking. Here I painted the boxes and such XF-69 NATO Black.
Here you can see that the Quickboost seat(s) are very nice. I painted the seatbelts XF-57 Buff and the hardware with Floquil Bright Silver on a fine brush. Sometimes I use a silver Sharpie for the silver.
Here's the 'pit is drybrushed with Floquil Bright Silver (Enamel) detail painted, to include some knobs and switches picked out in red,yellow, and blue. It now gets a coat of Testor's Gloss Coat for a wash barrier.
Once dry, perhaps an hour or so, it gets a Detailer wash. I use a brown and black mixed. I think this stuff is the best thing since sliced bread. Just slop it on...wait a couple of minutes.....then rinse it off with water to your liking.
After the wash has been removed. You can scrub off as much as you want. To my eye, this is about right. As a side note, I lost the gun sight and dash handle bar thingy somehow, so the replacement sight is from a Hasegawa Bf 109 and the bar thingy was scratch built from styrene (see lower right below)
Everything is then sealed with Testor's Dull Coat..
....and after a light post shading, we are finished. The instrument panel is the kit decal soaked in Micro Sol. After the dull coat, I added a drop of epoxy to simulate the glass lenses.
The nice part of out of the box 'pits......the fuselage usually closes without a fuss. Here's a test fit.
Thats were I left off. I hope some of youse find these techniques useful.
Joe
