I figured I'd drop in. Work schedule has kept me away from the bench lately.
Ajm, with the exception of RLM 65 and 76, I'
I've never had much success in reproducing RLM colors with Tamiya paints. The recommended formulas just don't look right to me. I prefer Gunze RLM colors for these, which are dead on to my eye. For reasons unknown, Gunze discontinued their Aquesous line, but their lacquers are still available. I stocked up on the Aqueous when it was still available. If interested, you could check E-bay and you could probably still find it.
Bish, I'm diggin' that pre-war scheme. Looks like it took a while. It looks like your in the home stretch.
Mustang, That snake scheme looks great! Hope to see more pics of that soon.
Gary, that cockpit is looking awesome.
I did snag some bench time over the last few nights. The landing light area is a black hole. I decided to spruce it up by adding a light (I followed someone else's example...perhaps it was in here). I blanked it off with styrene and sliced off a piece of sprue to represent the light. I drilled a small hole from the bulb and painted it silver. A blob of clear epoxy finished it off. Not too shabby eh?
I
It looks like a light yeah? Alot better than an empty hole I suppose.
A test fit. It looks like the Hasegawa wing root gaps will be on coffee break for this build, however, that engine attachment will be hurtful. Here I attached it temporarily with Blue Tac...
I started with the wing to fuselage attachment. Here is how I solve any wing root issues....works everytime. Pull the wings to the root with a strip of masking tape, Tenax it, then leave till dry.
As I expected, I had a gap where the engine piece attached to the fuselage (the diagonal panel line). Unless the real thing was supposed to look this way, which is certainly possible, this area needed work. I filled the gap with styrene rod and sanded it smooth. I them rescribed the lines back in with a sewing needle in a pin vice. What a PITA this was. Its not perfect but it looks much better than before. For future builds, Does anyone know if this area has a gap on the real thing? Everything else fit great. I built the spats and dryfitted them. These fit great. Here's where I left off.
Reference the discussion of bombs. I thought there were painted RLM 66?. Also, I have read that Battle of Britain Stukas only carried the centerline bomb, is that accurate? Any input greatly appreciated.
Almost time to paint, eventhough I still have no idea which plane I'm building....
Joe
