Hey gang!
Bish: Sorry your build didn't turn out like you wanted. Don't get discouraged, it happens to everyone now and then.
Speaking of changing gears, I ended up picking up the RF-4B. Ken, I am wondering if I should add it to the roster? Did some detail painting on it:
The A-10 is alive and well:
It's getting a gloss coat in preparation for decals. I tried a different approach on it. After spraying on the colors, I buffed out the paint with my toothpaste/polishing compound to give it a smooth but flat surface. I then have been overcoating it with some "Hight Gloss Clear" I found in with Testors automotive line. Jury is still out on this one. The finish is fine but still not a smooth as I had wished for.
The F-8E is getting the most attention:
Still a few details to go in the cockpit.
Removed all the masking. The unpainted plastic gets metallic treatment: I'll have to knock down that raised edge where the tape was....
I also started a decal on the upper wing surface.
The Cartograph decals sucked down into the panel line nicely after hitting it with the Micro red. Wonder if I really even needed it though. You see I also hit up some of the panel lines and also the red lights for the wing tip.
One oddity about the decals is that they provide markings for two different aircraft, and two different numbers tail codes and numbers for each, which would actually give you a choice of 4 different aircraft to build. Also included is a couple of decals for a Marine aircraft, but no tail codes or numbers to go with them, nor are they mentioned in the instruction sheet. Just strange.....
Jim
