work continues with the shaping of the 727-100s oval #2 intake (vs round intake on 727-200)
Original round intake show below was heated and pinched into an oval using a C-clamp. A thin strip was cut out of the top of the intake to make it appear more oval.
2015-06-20 00.12.29 by Lockon Photo, on Flickr
Since the kit intake wasn't being used a substitute had to be found - luckily a bit of clear heat shrink tubing was the perfect size. Shown inserted, glued and cut flush:
2015-06-20 19.03.16 by Lockon Photo, on Flickr
2015-06-20 19.05.35 by Lockon Photo, on Flickr
A new intake lip was made from scratch using thick Plastruct sheet:
2015-06-20 22.44.51 by Lockon Photo, on Flickr
2015-06-20 22.46.20 by Lockon Photo, on Flickr
2015-06-20 23.24.26 by Lockon Photo, on Flickr
It is glued to the fuselage and shaped:
2015-06-20 23.27.44 by Lockon Photo, on Flickr
2015-06-20 23.35.45 by Lockon Photo, on Flickr
2015-06-20 23.49.48 by Lockon Photo, on Flickr
The new oval intake for #2 engine.
2015-06-20 23.50.58 by Lockon Photo, on Flickr
Wings joined ready for 1st primer coat. The kit intake is visible in the background - aside from being round which is incorrect for the -100, it is far too small for a -200 - off to the scrap box it goes!
2015-06-21 01.30.20 by Lockon Photo, on Flickr
The wings halves where also significantly thinned prior to gluing them together in order to reduce the leading edge thickness (no photos of that, sorry!)
