1990-1991 Gulf War 25th Anniversary Group Build
    September 2012
Posted by GMorrison on Wednesday, August 12, 2015 11:49 PM
stikpusher
in this bottom photo the dots appear to be perhaps some kind of camo scheme on the missile?
Could be the Terex Co. logo.Devil
Weird, looks like something was layed down over the green before the sand was sprayed on.
    March 2006
Posted by simpilot34 on Thursday, August 13, 2015 4:34 AM
All work is looking good guys!! Sigh, so hope to join in, but don't know when.Sad
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    May 2013
Posted by Greg on Thursday, August 13, 2015 10:42 AM
GM, nice work on the weapons bay. I look forward to getting over the hump and finally digging into my bag of Evergreen assortment to do something like you've done.
GMorrison
So because the cabin windows are projecting fisheyes, Greg asked about hints for transport aircraft and the like. I often spray external color on the sides all around where the windows go while the fuselage halves are still separate. Then glue in the windows, join the halves, and mask both the windows and the immediate area around the side out to a panel line. Then putty, sand and paint the assembly. It's easier with airliners, mask the window stripe, We'll see here, I may not get a good match for Hemp next batch.
See if you can tell the color around the windows in this poor light shot. I shot the pieces with straight XF-57, then the window area with Morrison "Hemp".
That's just the sort of info I was hoping for as I watch you build your transport bird. Thanks!
    May 2013
Posted by Greg on Thursday, August 13, 2015 10:47 AM
Good to see another start here, castel.
Not sure what the correct term is for an undercarriage on something with 4 or more wheels (or tracks), but it surely looks nice and detailed. And I'll bet there was more to it than met the eye.
    September 2012
Posted by GMorrison on Thursday, August 13, 2015 11:00 AM
Finally it's starting to look like an airframe. Man this thing is big. If it all goes together right, my hat is off to Hornby.
The last AM stuff came in- decals. The kit still will provide what must be about 200 stencils. Final markings tbd. But that's not immediate.
Nimrod MR.2P Maritime Reconnaissance aircraft, 42 Squadron out of Seeb, Oman (Muscat International Airport) in February 1991.
    April 2006
Posted by waynec on Thursday, August 13, 2015 11:12 AM
castelnuovo
Finally managed to get some work done on the Piranha. The bottom part was quite a little project.
Cheers...
looks nice. i did the Canadian 8x8 LAV-III when i got into warwheels.  i just bought a second one because it was fun and i am a better modeler now. it's a shame no one sees the undercarraige.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    September 2012
Posted by GMorrison on Thursday, August 13, 2015 11:46 AM
Great to see you start Castelnouvo. Maybe pose it on a mirror when you are finished?
    April 2006
Posted by waynec on Thursday, August 13, 2015 12:14 PM
this has been really fun so far. got some priming done so i can start on painting the missile control section interiors. also started on the cab. the doors have sink wells on the inside as do some interior pieces so i just went nuts and puttied every one just in case. the doors will be seen, doubt the others would be but...
got the elevation assy done without breaking any handles. not sure what is going on at the rear. the instructions aren't clear and the DML instructions aren't any clearer.
First there were some sections that might be seen so i just added some "internal structure". the big hole i will explain shortly.
Obviously most of what i added won't be seen and will be black anyway and the erect missile will hide it BUT that's me. I did putty the bottom but you can still see some seam but it will be on a base so i didn't fix it. a point for not being totally obsessed with seams.
on pic 3 that shaft is suppose to go inside but doesn't seem to fit and doesn't seem to attach to anything. not clear in the instructions. i looked at where it could go and just drilled out a big hole. of course, as i don't have the mounts attached i eyeballed the path.
the missile still showed seams after priming so i tried some more sanding and scraping before repainting and maybe having to add putty. given how i do missiles, towed guns and RR guns, and locomotives one would think i have the cylinder seam thing down. HA!
    September 2012
Posted by GMorrison on Thursday, August 13, 2015 12:17 PM
And all in OTC! Dang!
    July 2004
Posted by stikpusher on Thursday, August 13, 2015 2:45 PM
Castel, it looks you are off to a good solid start on your LAV! So much easier to do their wheeled suspension than some of the modern tracked stuff!
GM, That looks really sharp with what you did on the weapons bay of the Nimrod. I look forward to seeing more progress!
Wayne, your Scud is really coming together very well and you're obviously are making rapid progress. I am really likeing this project!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Bish on Thursday, August 13, 2015 4:36 PM
Great work guys, really getting under way now.
    August 2014
Posted by Elevenbravo87 on Friday, August 14, 2015 3:57 AM
Is it to late to join the group build? If not put me down to build the Tamiya M2 Bradley I served on during Desert Storm...with C co 3/15 Inf. 24th ID. Thanks.
27th FEB. 1991... THE VALKYRIES CARRIED MY BROTHERS TO VALHALLA
For the Everlasting Glory of the Infantry.
    September 2012
Posted by GMorrison on Friday, August 14, 2015 10:11 AM
Oh I am sure it's fine. Love to have you in the campaign. Our leader will respond.
Posted by Bish on Friday, August 14, 2015 11:20 AM
I know its jumping the gun a bit, but welcome aboard.
    July 2004
Posted by stikpusher on Friday, August 14, 2015 12:17 PM
Elevenbravo87
11B, you are most welcome to join. I will get you and your kit aded later today when I am home on the desktop.
       - Plankton
LSM
    August 2014
Posted by Elevenbravo87 on Friday, August 14, 2015 12:37 PM
Thank you.
    May 2013
Posted by Greg on Friday, August 14, 2015 1:37 PM
Welcome 11B87.
    July 2004
Posted by stikpusher on Friday, August 14, 2015 3:16 PM
OK, 11B, you and your kit have been added to the front page roster. Welcome aboard.
I presume from your screen name that you went thru Benning in 87? Sand Hilton or Harmony Church? Wink
       - Plankton
LSM
    August 2014
Posted by Elevenbravo87 on Friday, August 14, 2015 5:26 PM
Sand Hill A 1-50.
Thanks again for adding me to the build, and all the welcomes. I have just started modeling again last year after a 15 year hiatus, so I am rusty but getting better at it...sort of like riding a bike, you never really forget techniques.
    September 2012
Posted by GMorrison on Friday, August 14, 2015 5:41 PM
Nice to meet you. Thank you for serving our country.
One thing about this particular group of idiots is that we like questions, lots of questions. So that the rest of us in the gallery can hear answers to questions WE don't want to ask.
But seriously, there's scary knowledge here.
    July 2004
Posted by stikpusher on Friday, August 14, 2015 5:49 PM
Elevenbravo87
Sand Hill A 1-50.
Yeah, it will come back to you prtty quickly I am sure. I and the good folks here will help your skills really progress. They did for me.
I was Harmony Church, D 10/2... a few years before you, once upon a time.. Always good to meet a fellow alumni of what one buddy called the University of INF Wink
Looking forward to that Bradley.
       - Plankton
LSM
    April 2006
Posted by waynec on Friday, August 14, 2015 6:22 PM
Elevenbravo87
Sand Hill A 1-50.
as you are an 11B, some of us will type slowly because we know you can't read fast
like GM said ask lots of questions and some of us will be picking your brain too. Given 2 new M60A2 kits are due out, i am going to have to dig deeply to remember my time with them.
C/3-33AR, 3AD
    July 2004
Posted by stikpusher on Friday, August 14, 2015 6:28 PM
Careful now Wayne, with 11B & me here, now there's more Grunts than DATs now in this place... Wink Especially since Rob decided to pop smoke a few months back...
       - Plankton
LSM
    April 2006
Posted by waynec on Friday, August 14, 2015 6:35 PM
stikpusher
don't forget Bish he drove FV-432s  IIRC.
more Grunts just evens the odds for you guys. actually i ran a 4.2" mortar plt for 18 months too and taught small unit tactics for INF and AT, AR, CAV, and ADAduck hunters during numerous MILES NETTs
    April 2014
Posted by B_one fixer on Friday, August 14, 2015 6:41 PM
Man I guess that makes me the only Air Force guy here then
    August 2014
Posted by Elevenbravo87 on Friday, August 14, 2015 7:14 PM
waynec
Elevenbravo87
Sand Hill A 1-50.
C/3-33AR, 3AD
Thanks for the welcome...
I am working on Tamiya's M60A3 at the moment. I like to build Cold War/Gulf War armor, as well as WW2 armor...planes, well I have some kits from years ago in the closet I might build if I need a change of pace from armor.
    August 2014
Posted by Elevenbravo87 on Friday, August 14, 2015 7:26 PM
1st question...where to find PE upgrades for a M2A1...loads of upgrades for M2A2/A3's but I cannot find anything for a early M2.
    July 2004
Posted by stikpusher on Friday, August 14, 2015 10:52 PM
MAYBE... Eduard doid something for their old Tamiya kit. Hoard hard to say...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Friday, August 14, 2015 11:12 PM
Guys, I seem to be having some serious problems with the site here. I can not even see teh words that I am typing in as I type them... I may have to bow out of here if this keeps up... flipping ridiculous....
       - Plankton
LSM
    September 2012
Posted by GMorrison on Saturday, August 15, 2015 12:51 AM
Just stop it. Really. Come back tomorrow, If you pop smoke too, I wouldn't know what to say.
