1946 What If GB
Posted by Bish on Friday, June 17, 2016 11:07 AM
Moff
Bish
Right, got ur. Well, at least you have the plastic one to fall back on.
Bish
The Trumpeter kit comes with a metal barrel, if that's what you mean.
O right, i was thinking it might be a solid plastic one. Even better thats you have a metal one then.
    January 2015
Posted by Moff on Friday, June 17, 2016 1:21 PM
Bish
Moff
Bish
Bish
I just fitted it and it looks great! I've attached the Trumpeter muzzle end caps to the Voyager muzzle, attached the Voyager muzzle to the Trumpeter barrel, and attached the Trumpeter barrel to the gun cradle assembly.
I was having some fit issues with the end cap from Voyager, so I decided to use the end cap PE pieces from Trumpeter. I also think the nice flat Trumpeter muzzle end looks much less clunky and awkward than the big Voyager one. And I don't know if I was just missing something about the way the Voyager piece was supposed to be put in place, but here did seem to be a fit issue...
"Gaiety is the most outstanding feature of the Soviet Union." - Josef Stalin
    July 2014
Posted by modelcrazy on Monday, June 20, 2016 12:09 PM
I starting to move on this now. I set the build in its base, mainly to keep me and the dog from breaking it. I spent some time adding the white line on the bow (not in the picture) and ordered some 1/700 scale numbers a letters to replicate the “IX-300 PRINZ EUGEN” on the port and starboard bow and stern. I ordered 1/700 due to the size of the original lettering on the ship.
I will be adding some small boat launches and then repainting the base. I really don’t care for the color and need to fill the waterline of the Eugen anyway.
Steve
Posted by Gamera on Monday, June 20, 2016 12:15 PM
Looks awesome to me Steve!
What are you unhappy with on the base? I suppose the water could be tad touch greener but it still looks mighty fine to me.
BTW: I still need to get cracking on my base. I've got all the wood and stuff and can't seem to get motivated to build the darn thing. The figures are mostly done at this point except for my kitbashed geisha. I hope she comes out ok, I've never done anything like this before.
    July 2014
Posted by modelcrazy on Monday, June 20, 2016 1:27 PM
Gamera
What are you unhappy with on the base? I suppose the water could be tad touch greener.....
That and I need to fill in where the ship's waterline meet the water. I'll add some acrylic varnish at the waterline, repaint, revarnish several coats and add just a wee bit of cotton to the waterline to simulate lapping waves.
Steve
Posted by Gamera on Monday, June 20, 2016 1:45 PM
Ahhh, ok. I thought I saw some gaps but couldn't tell if it was just the way the light was hitting it.
Posted by Bish on Monday, June 20, 2016 2:37 PM
Looking really nice Steve. When you make the base, do you do it around the ship or you you cut out the area the ship will sit in.
    July 2014
Posted by modelcrazy on Monday, June 20, 2016 2:51 PM
I cut the base first. That way I can make the base at the same time. If the ship is underway all that needs to be added is some cotton for the wake, but setting at anchor I need to fill the gap and repaint.
Steve
Posted by Bish on Monday, June 20, 2016 4:19 PM
Ok, so that stuf is easy to cut into then.
    July 2014
Posted by modelcrazy on Monday, June 20, 2016 4:20 PM
A little rubbery, but yes it is.
Steve
Posted by Bish on Monday, June 20, 2016 4:51 PM
Ok, thnaks. And just so i am clear, this is the same stuff you use for aircraft, is that right.
    July 2014
Posted by modelcrazy on Monday, June 20, 2016 4:57 PM
Yes, acrylic gel. I don't know it the same brands I use is available are England though,
either Liquitex or Golden. I rarely use thick, typically medium and varnish.
Steve
Posted by Bish on Monday, June 20, 2016 4:59 PM
Thanks again. I have found the Liquitex, i will be getting some as it looks great stuff.
    July 2014
Posted by modelcrazy on Monday, June 20, 2016 11:47 PM
Added the anchor chains, the sink markers, that white line on the bow, for whatever it does, the small boats and some acrylic varnish as a gap filler to the hull. I will be repainting after it all dries. The small boats will be attached to boat booms.
The camera added a little yellow to to picture.
Steve
    August 2009
Posted by JOE RIX on Tuesday, June 21, 2016 7:46 AM
Man! Your base and water effects look grand to me. Really impressive as a matter of fact. I really like the "at anchorage" setting. You don't seem to see that all too often.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
Posted by Gamera on Tuesday, June 21, 2016 8:08 AM
Oh wow, lookin' good Steve!
And thanks for showing us how you work your magic.
    April 2006
Posted by jgeratic on Tuesday, June 21, 2016 9:02 AM
Steve, looking to be another tremendous water scene.
I have a question about the acrylic varnish that was applied to the gaps.  Does it curve up towards the hull sides, or did it remain flat and level with the surrounding water?  I had this problem using future clear.
regards,
Jack
    July 2014
Posted by modelcrazy on Tuesday, June 21, 2016 4:51 PM
jgeratic
It curves up a little but that is to my advantage. I will be repainting up to the curve and the little curve there is will look like water lapping on the hull. you will really have to look to see anything. I will be adding a slight amount of cotton here and there to look like small whitecaps along the hull.
Steve
Posted by Bish on Wednesday, June 22, 2016 12:41 AM
She is loking really nice tehre steve, i do like the look of the water. And i will second joe, its not to see one at anchor like this.
    July 2014
Posted by modelcrazy on Thursday, June 23, 2016 10:01 AM
OK guys, I’m starting to get really excited about this one. If I work on it constantly I should be at the rigging stage in about 2 weeks. I will need to scratch the SCR-584 radar trailer strapped to the bridge roof and bow and stern boat booms.
I repainted the base and added the first coat of acrylic varnish. Note the missing 8” gun barrels from the Anton turret. These were removed at the Philadelphia shipyard for further study in Virginia.
Steve
Posted by Gamera on Thursday, June 23, 2016 11:01 AM
Looks great Steve, love the launch tied up next to her.
If I may ask the white water looks frothy or is it not dried yet?
    July 2014
Posted by modelcrazy on Thursday, June 23, 2016 11:53 AM
Not dry. I was just showing how it looks after application so if someone tries this method they won't freak out. It will dry clear in about 12 hours and be ready for another coat.
Steve
Posted by Gamera on Thursday, June 23, 2016 12:00 PM
Ah ok, thanks!!!
Posted by Bish on Thursday, June 23, 2016 12:30 PM
Coming on nicely Steve. What exactly is the purpose of those layers of varnish.
By the way, i meant to ask before, but have you considered doing an article for the mag on your water.
    July 2014
Posted by modelcrazy on Thursday, June 23, 2016 12:45 PM
The varnish coats give the water a much shiner appearance. Also the multiple layers will give the water depth and not make it look painted.
I pretty much got my method from Chris Flodberg (with a few variations of my own) who did an excellent tutorial for FSM a few months back. I have a long way to match his skill.
Steve
Posted by Bish on Thursday, June 23, 2016 12:54 PM
Thanks Steve, i'll have to have a look for that.
    July 2014
Posted by modelcrazy on Thursday, June 23, 2016 12:57 PM
April 16 issue.
Steve
    July 2014
Posted by modelcrazy on Saturday, June 25, 2016 1:15 AM
I received my US sailors from Shapeways 3D printing. Not bad looking and way better those 2D PE sailors. I have 28 of them to stick on the deck.
Steve
Posted by Bish on Saturday, June 25, 2016 1:18 AM
Thanks Steve, i will look into that.
Holy cow, your gonna paint those things. They do look better than the PE ones i have seen.
    July 2014
Posted by modelcrazy on Saturday, June 25, 2016 2:22 AM
Pretty much just blue dungree with a white dixie cup hat and black dots for shoes. I don't think I have a small enough brush for anything else.
Steve
