Hi - Just saw this group build and was wondering if it is too late to get in with a Revell A-7A I started in mid-September as part of a building class my club was conducting?
Capn Napalm Hi - Just saw this group build and was wondering if it is too late to get in with a Revell A-7A I started in mid-September as part of a building class my club was conducting?
BK
On the bench:
A lot !! And I mean A LOT!!
14 / 5 / 2
Thanks for putting me on the roster.
How do I go about adding pictures? This is my first time posting here... Tried drag and drop, but the image appears far too big.
Cap'n Napalm try this tutorial should explain everything
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/23/p/173194/1924763.aspx#1924763
tempestjohnny Cap'n Napalm try this tutorial should explain everything http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/23/p/173194/1924763.aspx#1924763
Thanks for the link to the tutorial. Here are some progress pics I took last week of my A-7. The A-7A Navy colors didn't do much for me so I decided to try to convert it to a USAF A-7D.
I can't see the photos on the page here, but I was able to click them and make them work. Look like an A-7 alright. It also looks like you had quite a bit of body work as well. You are not far from paint and that will be pretty cool.
Hey Cap, looks like she's coming along quite well.
Thanks Gamera!
Got it masked and tried to do some preshading. If I was to do it again, I would try black basing. The colors did not turn out quite like I wanted, but I used the ones specified for this pattern, so I will press on and see how it ends up. Need to do some touching up now...
Regarding photo posting - how do I get pix to show in the post instead of links? I followed the tutorial but maybe I am missing something?
Capn NapalmRegarding photo posting - how do I get pix to show in the post instead of links? I followed the tutorial but maybe I am missing something?
When you are on photobucket.
Camo looks good and the pre-shading looks just right!
What TJ posted should work on getting the photos to show.
The camo looks great. The colors are rich in tone as if the bird was newly painted. If that's your look then you nailed it. If not, then you can post shade with a slightly lightened tone of the same colors and create some mottled fading. But, I think it looks good.
Hello there, I'll like to enter in my Revell 1/48 F-15E Eagle. Might get a weapons set to go along with it.
1 by Daniel Smith, on Flickr
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
DantheMan85 Hello there, I'll like to enter in my Revell 1/48 F-15E Eagle. Might get a weapons set to go along with it. 1 by Daniel Smith, on Flickr
Dan: Ohhhhhhhhhhh good choice!!!
Another kit I've got but who knows when I'll get around to it. Looking forward to watching you build yours.
Capn - Nice work so far! Great job with the camo.
Dan - I'm looking forward to that one. I've seen it at Hobby Lobby many times and haven't pulled the trigger.
Update for me. I've go the major paint done on the top and bottom. I won't be adding all the underwing goodies as I hope to have this one displayed at work and I don't want it to look toooo menacing lol. I used light & dark ghost gray from Model Master enamels. The canopy took a little persuading to get into place and as you can see it still isn't perfect...maybe it was more designed to be left open?? Anyway here are the pics...
Comments encouraged, critques needed Thanks for looking!
-Andy
She's looking good Andy. So, I assume clear and decals are next?
BrandonK She's looking good Andy. So, I assume clear and decals are next? BK
yes you are correct sir! I'be painted the exhaust and a few other bits. Hopefully will be clear coating this weekend!
Gamera Dan: Ohhhhhhhhhhh good choice!!! Another kit I've got but who knows when I'll get around to it. Looking forward to watching you build yours.
I appreciate all the feedback. Got the gloss coat (Future) and decals done - found out some of the colors were a bit transparent and blend in with the dark colors, but overall I'm happy with how it turned out considering I printed them myself. Did a light oil wash (my first one) and now for the flat coat. Not sure if I need to seal it with another coat of Future or just proceed with the flat...
Also, got the D model wheels and brakes in the mail. They went together much more easily than I thought they would.
Andy: That paint job looks perfect!
Capt: She's coming along great! I personally don't go with another gloss coat before the matte, others may disagree.
Capt - I 2nd Gamera that you should be able to just hit it with the flat coat. Nice job btw!
Well it happened to me again. I went to decal this weekend and they tore apart. This was an old kit I picked up from a swap meet so the decals had some age, they looked ok and I tested one of them before I started the build and it worked fine. So this one is on hold till I can get some aftermarket ones. Is there something I can/should be doing to these old decals before trying them or should I just expect to buy aftermarket?
rooster513 Well it happened to me again. I went to decal this weekend and they tore apart. This was an old kit I picked up from a swap meet so the decals had some age, they looked ok and I tested one of them before I started the build and it worked fine. So this one is on hold till I can get some aftermarket ones. Is there something I can/should be doing to these old decals before trying them or should I just expect to buy aftermarket?
What you might try is scanning your decals into the computer - if you have another image of the one that tore apart, you could replicate it with photoshop and reprint. I have an old set of Hasegawa decals that were yellowed, but I used photoshop to remove the yellow and create a sheet of the particular markings I wanted to use. Also, printed backups on the same sheet, which came in handy a couple times when the first try went wrong.
Capn, looking good for sure. And as others mentioned, just dust it with a flat coat and will be spot on.
Rooster, ooff!! I buy new decals for the older kits just to be safe, but I've always wanted to try to print my own I just don't have the time to add to my list of things to do. You'll get it done and it'll be amazing, we've got a whole year yet.
Capn, really like tha look of that. I actual;l;y prefer this scheme to the navy one.
And likethe otehrs, i don't add a gloss coat either. I usually weather first then flat coat.
Nice work on the Hornet Andy. Be nice to see the decals on and keen to see how you go with the weathering. Still need to add one of these to the collection, maybe next year.
BK, can you put me down for a second entry. Revell's 1/32nd He 162. Its part of a 3 kit build, just got the thrid and final one today, but i will just poist the one here. I should be able to put a bit more enthusiasm into this one.
Bish BK, can you put me down for a second entry. Revell's 1/32nd He 162. Its part of a 3 kit build, just got the thrid and final one today, but i will just poist the one here. I should be able to put a bit more enthusiasm into this one.
I'll join with the Revell 1/72 SR71 Blackbird.
Daniel J. Ficke
Daniel Ficke I'll join with the Revell 1/72 SR71 Blackbird.
Nice looking forward to seeing that one.
