75th Anniversary of 1942 (World at War)
    July 2014
Posted by modelcrazy on Saturday, December 31, 2016 11:12 PM
Here are the innards of the Takao. I will be starting this on the 1st hopefully. This is a very extensive kit and with the PE, oh brother what did I get myself into? Anyway, I will be putting her in a seascape, not calm but not too rough. I envision her bow crashing through a swell and some spray.
The PE set with its instructions are also shown
Steve
Steve
    September 2003
Posted by checkmateking02 on Sunday, January 1, 2017 1:37 PM
That's impressive--or intimidating, as the case may be.  But you're work is always spectacular, Steve, so it'll be another great experience watching how your build goes.
Posted by Bish on Sunday, January 1, 2017 2:21 PM
Got your hands full with that lot Steve. Should be interesting to watch.
    November 2003
Posted by tempestjohnny on Monday, January 2, 2017 1:46 PM
Figured on something different for this GB. Here is what I found in the stash. 1942 Leningrad
    September 2003
Posted by checkmateking02 on Monday, January 2, 2017 6:12 PM
Interesting-looking plane, tj.  Not a variant you see everyday.  Will look forward to seeing it come together!
Roster has been updated with your selection.
    April 2005
Posted by taxtp on Monday, January 2, 2017 6:17 PM
Hi CMK,
I'm definitely in, but not sure what yet. Mark me down for a 'TBD'.
Cheers
Tony
I'm just taking it one GB at a time.
    September 2003
Posted by checkmateking02 on Monday, January 2, 2017 7:42 PM
Good to hear from you, Tony.  Welcome to the GB!  The roster is updated, and I'll post your choice once you've chosen.
    January 2017
Posted by vanpelt on Monday, January 2, 2017 10:06 PM
Hi am new here I would like to join in on this. The Lancaster was introduced in 1942 and I have Tamiya's 1/48 kit I would like to build.
    September 2003
Posted by checkmateking02 on Tuesday, January 3, 2017 1:00 PM
Welcome to the GB, vanpelt.  Good to have you along for the build.  I've updated the roster with your project.
    September 2003
Posted by checkmateking02 on Saturday, January 21, 2017 1:46 PM
Progress on the Flying Tiger:
cockpit with masking tape seat harness--
interior of the fuselage--
I used MM's interior green, followed by a wash of dark brown and dry-brushed highlights.  Doesn't show up too well in the photos, it probably won't show up at all once the canopy is closed up.
I used acrylic craft paint for the instruments, and hand-brushed them.
    September 2003
Posted by checkmateking02 on Friday, March 3, 2017 6:22 PM
Progress on a 1942 Flying Tiger.
Painted the inside of the wheel wells with the lower fuselage color, MM's Aircraft Gray. Used a pin wash and some of Doc O'Brien's weathering powders--although it's not real obvious here.
Assembled the wings, cockpit and fuselage.
Attached the cockpit to the wing section.
Fit between the wing assembly and fuselage was poor, as seems to be the usual case with this molding.
Managed to make it work--sort of; still not the most desirable fit
While messing with the wing/fuselage and waiting for the filler to dry, finished up the propeller assembly.
I've gone on to the painting, and finished that, but not much to see except a lot of masking tape.
    July 2014
Posted by modelcrazy on Friday, March 3, 2017 6:46 PM
Is that the 1/72 Airfix P40B kit Check?
Steve
    September 2003
Posted by checkmateking02 on Saturday, March 4, 2017 10:06 AM
It is Airfix, 1/72, Steve.  It's boxed as an AVG Curtiss Hawk 81-A-2, but it might be identical to their P-40.
This is the second one I've built; the first was for the 1941 GB, in markings for a 2nd Squadron plane assigned to David Lee "Tex" Hill.
For this one, I wanted to depict something with the leaping tiger decal, which came into use after March, 1942.  I found a sheet from AML, obtained from Hannant's.
The Airfix decals are on top, showing the difference in style between the shark mouth. I used the stenciling decals from the kit, and the AML decals for the plane markings.
You can see that AML reproduced four of the Chinese national sun marking in very light blue--too light, I think, as did Airfix with the kit decals.  Unless it has something to do with 1940's era camera film, the markings show up much darker in contemporary photos.
The AML decals were a little disappointing.  They look good, but they are quite thick and resist setting solutions--even Walther's Solvaset.  Even when they dried after applying them to the plane, they tended to crack and required touch-up with paint.
They looked OK once I sprayed the plane with flat clear-coat.
    July 2004
Posted by stikpusher on Saturday, March 4, 2017 3:22 PM
Dang it! You keep on tempting me with these GB subjects that I absolutely love...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Saturday, March 4, 2017 6:15 PM
Devil
Go on; give in.
Posted by Bish on Saturday, March 4, 2017 6:28 PM
Thats looks a pretty dodgy fit on that wing root check. Thats pretty bad. But coming together nicley.
Haven't forgotten about my build, its in the queue, should be getting to it July/August time.
    July 2004
Posted by stikpusher on Saturday, March 4, 2017 7:11 PM
checkmateking02
Devil
Go on; give in.
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Saturday, March 4, 2017 7:34 PM
It is, Bish.  I haven't been able to locate the cause for the misfit.  Whatever it is, it prevents a smooth transition from the wing root to the wing. usually leaving a noticeable step.
Hear the song of the plastic, stik!
Music
    September 2003
Posted by checkmateking02 on Sunday, March 5, 2017 3:22 PM
Before putting up photos of the finished Flying Tiger Hawk-81, here is some information about the pilot and plane.
Robert Hawthorne Neale      was born in Canada on 3 May, 1914.  He came to the U.S. with parents Joseph Thomas Neale and Margaret Osborne (nee Hawthorne) Neale in 1916.  His father was English; his mother Irish.
The family settled in Washington state, living in both Yakima and Spokane.
“Bob” Neale was a US Navy dive-bomber pilot on USS Saratoga when he joined the American Volunteer Group headed for China.  The AVG was activated on 20 December, 1941, and disbanded on 4 July, 1942.
Neale assumed command of the 1st Squadron on the death of its previous commander, Robert James “Sandy” Sandell, on 7 February, 1942.
He received the Distinguished Service Order from Great Britain for his service in Burma, and the Ten Star Wing Medal from China.
Neale was one of the pilots who volunteered to remain two extra weeks in China when the “Flying Tigers” officially ceased operations.  It seems he commanded the US Army Air Forces’ 23rd Fighter Group during that time—as a civilian, until Col. Robert Scott arrived to take over.
Neal returned to the United States and found employment as a civilian transport and ferry pilot for Pan American World Airways during the remainder of World War II.
After the war, he settled in or around Seattle, Washington, where he ran a fishing resort until his death on 29 November, 1994, while residing at Stanwood, Snohomish County, Washington.
Besides commanding the AVG’s 1st Pursuit Squadron, “Bob” Neale was the highest scoring ace in the AVG when it disbanded, having achieved thirteen officially-credited air-to-air victories (although some sources cite fifteen kills):
  • 23 Jan 1942: 1 Ki-27 Nate fighter
  • 24 Jan 1942: 2 Ki-21 Sally bombers
  • 26 Jan 1942: 1 Ki-27 Nate fighter
  • 6 Feb 1942: 1 Ki-27 Nate fighter
  • 25 Feb 1942: 4 Ki-27 Nate fighters
  • 26 Feb 1942: 3 Ki-27 Nate fighters
  • 3 May 1942: 1 Ki-15? observation plane
The 1st Pursuit Squadron in the AVG adopted as its “logo” an apple--usually green--in which Eve was depicted pursuing Adam; evidently the “first pursuit” in human history.  There were a couple of versions of this insignia--but the one marking Neale's plane was the more elaborate.
This was painted on the access panel shown open in the photo above, and thus not visible.
Interestingly, Adam is shown in uniform, while Eve is not.  Forum protocol being what it is, I will refrain from showing the insignia here; you'll have to do a google search for it, but the 1st Pursuit's nickname was "the Adam and Eve's."
The 1st Pursuit’s squadron recognition color was white (2nd was blue and 3rd was red), as depicted on the fuselage band.  In addition, aircraft number 7 displayed white-painted wheel covers—a feature apparently unique to this plane, and not duplicated on any other aircraft in the squadron.
Below is the AML profiles from the decal instruction sheet.
    September 2003
Posted by checkmateking02 on Sunday, March 5, 2017 4:03 PM
The model:  1/72 Airfix Curtiss Hawk 81-A-2.
Undersides painted in MM's Aircraft Gray with a dark blue acrylic pinwash.  Chinese national insignia came from the Airfix sheet.
Top surfaces painted with MM Military Brown and Medium Green with a thin black pinwash.  "White 7's" individual aircraft markings came from the AML sheet.  I painted the fuselage band, since AML printed the decal band without a curvature to fit the fuselage.
Thanks for dropping in.  I look forward to seeing the other 1942 contributions to the GB.
    July 2014
Posted by modelcrazy on Sunday, March 5, 2017 7:35 PM
Wow Check, that looks really sweet! Yes Going with the painted band was the way to go.
Steve
    April 2006
Posted by jgeratic on Sunday, March 5, 2017 9:23 PM
Check, super work on this flying tiger. Yes
Great job also in filling in those gaps, and it's always to nice see some added historical context to the particular subject presented.
regards,
Jack
Posted by Bish on Sunday, March 5, 2017 10:33 PM
Great job check. Looks like you got to grips with that wing root. Nice build.
    September 2003
Posted by checkmateking02 on Monday, March 6, 2017 4:51 PM
Thanks, Steve, Jack and Bish.
That wing root is really the only drawback to a really fine kit, so hopefully Airfix will address it in the future.
I've got three more of these Hawk 81's hanging around, so I'd like to build an example from the 3rd Squadron of the AVG sometime.
    July 2004
Posted by stikpusher on Monday, March 6, 2017 10:40 PM
checkmateking02
Music
Allright, the sirens sweetly singing seduced me...
I'm in... with this oldie but goodie....
       - Plankton
LSM
    March 2007
Posted by tonka on Monday, March 6, 2017 10:45 PM
Not sure how I missed this GB, but I just started last month on a 120MM US MArine MP from 1942. If I can use that, its started though.
    September 2014
Posted by rooster513 on Tuesday, March 7, 2017 11:35 AM
Checkmate, that P40 came out wonderful! Really nice paint work!
-Andy
Posted by Bish on Tuesday, March 7, 2017 1:19 PM
stikpusher
checkmateking02
Music
WOW, i remember bulding that way way back. Looking forward to seeing that one.
    September 2003
Posted by checkmateking02 on Tuesday, March 7, 2017 6:42 PM
Andy:  thanks for your kind comments on the Flying Tiger.  I wasn't so sure when I started it that it was going to come out too well.  I'm usually pretty nervous about the paint and the decals.
stik:  welcome to the GB!  Glad you listened to the siren-song!  That does look to be a "classic" kit.  Even the box has a patina of seniority about it.  Good to have you join in.
tonka:  sounds like a good contribution.  Glad to have you join with us, and it's an interesting project I look forward to seeing.
Roster has been updated.
    July 2004
Posted by stikpusher on Tuesday, March 7, 2017 7:09 PM
Checkmate, glad to be aboard. You keep pitching these themes that I have a hard time saying no to. 1942 was the year where everything hung in the balance and could go either way. The Axis was moving ever forward and the Allies reeling from blow after blow...
       - Plankton
LSM
