With all this great work going, my update is rather dull in comparison.
So, I have completed the decaling, added almost all of the small parts and carried out touch ups. I removed the PE uder carridge door hinges as they kept falling off and was closed to using a hammer on the build... I removed the filler from the early holes in the gear doors and used some .64mm round styrene tube and glued them in, job done. Sometimes adding the extra detail is not worth it, this for me was one of them.
I taped over the wing roundals, as I needed to mask the wing tips for painting after installing the antennans. On removing the tape, parts of the wing roundal decals lifted off even after a seal coat of gloss varnish. As I was not at all happy with the poor quality of the original DK Decals, I decided to remove both and used the kit versions, which are slighly darker than used on the fuselage, but the went down without a problem.
I used Tamiya Black panel line enamel with satisfactory results and AB coated the entire model with MRP Matt Varnish. This has hidden about 80% of the dust and other stuff captured in the gloss coat, which I'm happy with. The MRP Matt Varnish went down first time without a single issue and was dry within minutes to a silky smooth finish, take that Alclag Aqua Gloss!
I'm just about done, I decided some time back to make a diorama bases for some of my builds. So i have started, just waiting on some materials to finish it. I need to add the main cockpit door, remove the window masks and add the ladder and we are done.
![](http://i1262.photobucket.com/albums/ii619/damouav/De%20Haviland%20Mosquito/IMG_1097_zpsjjsttfli.jpg)
![](http://i1262.photobucket.com/albums/ii619/damouav/De%20Haviland%20Mosquito/IMG_1098_zpsg7ausxnt.jpg)
![](http://i1262.photobucket.com/albums/ii619/damouav/De%20Haviland%20Mosquito/IMG_1100_zps1em2ege8.jpg)
![](http://i1262.photobucket.com/albums/ii619/damouav/De%20Haviland%20Mosquito/IMG_1101_zps2ujo2hc3.jpg)
![](http://i1262.photobucket.com/albums/ii619/damouav/De%20Haviland%20Mosquito/IMG_1103_zpsvnrzldp1.jpg)
