Tim,
That sucks about the decals. Hopefully you can find a work around.
Ernest,
Congratulations on completing the double! They look great! The frontpage will be updated shortly.
Now for my adventure. I originally started to do a double, but as I was working on one, decided to go with one build instead. The kit in question is Hasegawa's 1/72 F-104G/S Starfigher with special markings. You have a choice of three specials, an Italian bird with standard camo on one side and a cat chasing mice on an orange and white background on the other, a German blue and white bird, and a red Canadian special with white markings. I elected to go with the blue and white German bird.
Proof of unstartedness:
The cockpit is installed.
The main landing gear.
The rear half of the fuselage.
The front half of the fuselage. This is done so they can share molds with the TF-104G.
The fuselage together.
Now we have something that looks like an airplane.
Now the fun begins. I've got another one of these under construction and I had very little trouble getting the fuselage lined up right, the wings to fit, etc. I was originally going to do the German scheme on that build, but I attached the T-tail and I needed it left off to apply some decals to the vertical stablizer. So, it will become the Canadian F-104G instead. As I said, I had no problem attaching the wings to that build, other than the fact that it might have too much anhedral for the wings. On this one, no such luck. Although it's not visible in the pic, there is a step on the left side of the fuselage where the front and back halves meet. I don't know if something got misaligned in construction, but something's wrong there. I also had a problem attaching the wings. The right wing refused to even try to fit good. I thought I might have gotten something in the way of the mounting tab so I trimmed it down and the wing still wouldn't fit. So I trimmed some more until there was almost nothing left and it still wouldn't fit. I grabbed a right wing out of my TF-104G, and it fit somewhat better, but there is still a good sized gap to take care of when I get home tonight. I might try some strip stock or gap filling superglue to fill the gap. You don't even want to see the wing alignment.
The right side.
The left side. Not much better.
Right now I'm thinking about hitting them with some gap filling superglue then zapping it to cure it quickly. The only problem with doing that is that it after a certain time (usually about an hour) it gets too hard to sand. One thing I did learn from my earlier build was that canopy masks are a must as I couldn't pick out the canopy frames under my Tamiya tape masking attempt. If I can get her into primer before I hit the sack tonight, I think I'll be golden. You still have a few weeks to get a build completed before this thing of ours ends.
