Viet Nam War Aircraft Group Build
Posted by jeaton01 on Friday, February 14, 2020 6:54 PM
Looking good, PJ.
John
    November 2016
Posted by StephenL on Saturday, February 15, 2020 11:34 AM
With a little persuasion , I was able to get the True Details cockpit in. Lots of ballast for this one, I am sure you all know. I am working on the “pull” handles for the seats so I can get the canopy sorted and squirt some primer on this thing.
Cheers.
  " alt="" />
  " alt="" />
  " alt="" />
200 kits was my limit...
Posted by jeaton01 on Saturday, February 15, 2020 11:49 AM
Looks like you are doing lots of careful fitting, Stephen.
John
    November 2008
Posted by plasticjunkie on Sunday, February 16, 2020 7:17 AM
StephenL
Cheers.
  " alt="" />
  " alt="" />
  " alt="" />
I haven't found a single resin AM set that simply drops in and you are done with it. Most require lots of surgery to get them to fit.
Your work is looking great Stephen.
 GIFMaker.org_jy_Ayj_O
    November 2008
Posted by plasticjunkie on Sunday, February 16, 2020 7:34 AM
jeaton01
Looking good, PJ.
Thanks John. The 105 has taken a backseat here since the Mig is a comission and want to complete it first and send it to its buyer.
I was reading that the NVAF did not have many Mig 21s and they were mostly used as a hit and run weapon on heavy bomb loaded F-105 flights. Robin Olds developed a surprise attack tactic on the NVAF by making them believe a slower bomb loaded flight of Thuds was coming their way using the same altitude and direction the Thuds usually follwed. The NVAF sent a bunch of 21s to hit and run on what they thought to be the slower F-105s only to confront a large number of missile armed Phantoms waiting in ambush, SURPRISE!!! This was called Operation Bolo where the NVAF lost several Mig 21s during this encounter forcing them to cut back on the Mig 21's use for a while.
I figure that they were kept relatively clean so I will not go overboard with the weathering, just enough to show some use and not abuse.
    November 2008
Posted by plasticjunkie on Sunday, February 16, 2020 9:11 PM
I decided to use some Hawkeyes aluminum powder on some panels for an added metallic effect. This powder can be applied with a Q Tip and buffed out to a brilliant shine. I have no clue why this product was discontinued because it is fantastic.
I forgot where I read that MM Metalizer Sealer barely affects the metallic bling so I sprayed the plane with it to seal things up so that the upcoming Flory washes will not affect the powder. I would say that the Metalizer Sealer barely altered the tone so I was happy how it performed.
I started applying the decals and have the larger ones on. There are a bunch of tiny stencils to be applied but it's getting late. Sleep
This is how it looks so far
    May 2004
Posted by cbaltrin on Monday, February 17, 2020 3:27 PM
Calling decaling done. Washed, dried,  Mr.Color semi gloss applied. Stabs painted .  A few gear doors and wheel centers painted.  Don't think there will be any more updates until she is complete.  I am so excited, I finally get to remove the canopy masks!
On the Bench: Too Much
    May 2004
Posted by cbaltrin on Monday, February 17, 2020 6:04 PM
Looks good PJ. Metalizer sealer is good stuff.
    November 2008
Posted by plasticjunkie on Tuesday, February 18, 2020 6:08 AM
Thanks CB. Your Hun looks great and the metal heat stains look the part. Beer
I too will post again once the Mig is done needing only the two missiles and the gear legs to be attached.
    August 2015
Posted by crown r n7 on Thursday, February 20, 2020 5:46 PM
OMG !! I need to be part of this ! but with two French bulldog pups and 60 years coming up .... guys awesome builds.
 Nick.
    May 2004
Posted by cbaltrin on Friday, February 21, 2020 5:50 AM
I think you're on the roster? Surprise
    June 2014
Posted by BrandonK on Friday, February 21, 2020 9:35 AM
plasticjunkie
PJ, excellent work. The BMF looks fantastic.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    June 2014
Posted by BrandonK on Friday, February 21, 2020 9:36 AM
cbaltrin
I love the tri-tone camo, it looks steller. I'm looking forward to seeing this one complete.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Friday, February 21, 2020 6:08 PM
Thanks BK. The finish line is getting closer.
    November 2003
Posted by tempestjohnny on Friday, February 21, 2020 8:52 PM
Looks great Ernie. Will have pics up tomorrow. Got some paint on the 66 today
    November 2003
That F-100 looks awesome
    November 2003
Posted by tempestjohnny on Saturday, February 22, 2020 7:28 AM
Put some paint on the beastie last night
AK for the brown. MM for both greens
    November 2008
Posted by plasticjunkie on Saturday, February 22, 2020 8:40 AM
tempestjohnny
That looks great TJ. The fade lines look very good. Hey did you use AK Real Colors? And if so  how did it spray out?
    November 2003
Posted by tempestjohnny on Saturday, February 22, 2020 9:07 AM
Yes it was the real colors line. I like it. Sprays nice. I've got a few colors of the AK. Mostly Luftwaffe. I like the color selection
    November 2008
Posted by plasticjunkie on Saturday, February 22, 2020 12:09 PM
tempestjohnny
Hey thanks TJ. Read somewhere it sprays like Tamiya paint. I think law dog uses them too.
    November 2003
Posted by tempestjohnny on Saturday, February 22, 2020 2:11 PM
Very close. Tamiya or Gunze
    November 2008
Posted by plasticjunkie on Saturday, February 22, 2020 3:10 PM
tempestjohnny
Yes
    May 2004
Posted by cbaltrin on Saturday, February 22, 2020 6:43 PM
tempestjohnny
Thanks TJ and Brandon! Hopefully it will be done by end of month or 1st week in March. Bench time is at a premium lately and sad eyed little boys are begging me to work on their ceiling hangars!
    May 2004
Posted by cbaltrin on Saturday, February 22, 2020 6:44 PM
TJ, I was starting to wonder what happened to your build. Your destroyer is coming along nicely!
    November 2008
Posted by plasticjunkie on Saturday, February 22, 2020 6:50 PM
The Mig 21 is done. Please use the last picture for the completed build section.
Now back to work on the Thud.
    November 2003
Posted by tempestjohnny on Sunday, February 23, 2020 5:07 AM
Nice finish Ernie. The panel color is great
    May 2004
Posted by cbaltrin on Sunday, February 23, 2020 7:15 AM
Nice work on the Mig PJ. I never knew the canopy was hinged like that. Leave it to the ruskies Stick out tongue
    June 2017
Posted by jmoran426 on Sunday, February 23, 2020 10:47 AM
Beautiful work on the MIG-21. And again, that cockpit is just killer. The model does a good job of portraying how small these aircraft actually were. No wonder the F-4s had a hard time turning and burning with them. Can't wait to see the finished Lead Sled.
jmoran426
    November 2008
Posted by plasticjunkie on Sunday, February 23, 2020 10:47 AM
cbaltrin
Thanks. I read it acted as a wind blocker at ejection. It does look weird.
    November 2008
Posted by plasticjunkie on Sunday, February 23, 2020 10:51 AM
jmoran426
Thanks jm. I agree that Eduard does a great job with the pe details. Yes those suckers gave old smoky a run for their money. The darn thing looks fast just sitting on my bench.
