OK FSM, one of my two is done! I knocked out the A-7. The A-4 is about 85% done. It's getting there...
OK, so while prepping for final assembly, I ran into a small problem on the Corsair. I peeled off the canopy's masking and found that Eduard's masks pulled up the paint that was supposed to represent the gasket around the windscreen's panes.
I didn't want to have to re-mask and re-paint, especially the clear parts, so I had to come up with a Plan B.
I had some very small decal strips in my pile, albeit it black.
So, I cut off a few and sprayed them the same color brown.
After very careful trimming, I was able to use the decal strips to represent the orignally painted areas.
Not perfect but from 3 feet it should look fine.
OK, so I said I was done with the Corsair. I am. Here are a couple of pictures to prove it. I don't know if it stands up to stik's warhorse, but I'm (mostly) happy with how it came out. I'm satisfied with it as a 3-footer.
More pictures are posted in the Aircraft Forum. Check 'em out!
Now...on with the Skyhawk!
