Made a start on the Stuka last weekend, this is the kit, i am doing the subject on the box art, S7+AA.
The instructions say it a D-1, but the photo's clearly show the thicker armoured pilots windscreen of a D-3.
I'm useing an Eduard PE set along with a few other AM parts. The Aires resin pit designed for the Academy kit will fit in this, as i found out when i built a D-5, but as i had the Eduard set anyway, figured i would use it. The PE set is missing some detail thats in the resin one, but i'll use some parts from the spares box to fill it out.
I got the PE parts fitted painted and dry brushed. Also drilled out the hole and fitted a quickboost resin compass.
I also got the wings together, cut out the molded landing light and fitted the guns. There are 2 options for the wing guns in the kit. One with exposed barrel tips for the D-1 and another with extended fairing and covered opening for the D-3. But photo's show that both variants could have either. I am guessing the covered fairings are to stop dirt getting in to the barrels on take off, and the covers do seem to be fited more often to aircraft in dusty enviroments, such as the desert. The photo's of the aircrfat i am doing are not that clear, but it does look more like the covered option so thats what i fitted.
