Junkers GB
Posted by Bish on Tuesday, January 11, 2022 2:55 AM
Thanks gamera. I do have both of the G versions in the stash but have already built the Academy ones. I'll be useing the Fujimi kits to build other versions, probably a D-1 and D-8.
Look forward to seeing that 188.
    November 2008
Posted by plasticjunkie on Friday, January 14, 2022 4:41 PM
Man this thing is tiny! Spent several hours dry brushing and detailing the knobs and thingies in the office.
The sides are also amazing
Next will be fashioning some belts from wine foil and detailing the IP and bombardier position.
 GIFMaker.org_jy_Ayj_O
Posted by Gamera on Friday, January 14, 2022 10:25 PM
That's some sharp work PJ! Kudos sir!!! Yes
I got the last couple items the cockpit PE, seatbelts, and the replacement decals for my Ju-188 and got a little work done on her. It's been so frelling cold though I've been coming home from work and just getting under a blanket reading, watching TV, or fooling around on the PC. Guess I need to turn up the heat and try getting something done on some of the models I have in progress...
    April 2005
Posted by taxtp on Monday, January 17, 2022 3:54 PM
My Junkers F.13 has arrived, so I've made a start. It's not the sleekest of aeroplanes by any stretch.
Cheers
Tony
I'm just taking it one GB at a time.
    February 2010
Posted by 68GT on Monday, January 17, 2022 6:47 PM
Here is my 188 for now.  As soon as I get something off the bench I'll start.  Not sure which aircraft from the AIMs sheet I'm going to build yet.
On Ed's bench, ???
Posted by Bish on Tuesday, January 18, 2022 12:49 PM
Great work on the pit PJ.
Tony, Ed, look forward to seeing those.
Posted by Gamera on Tuesday, January 18, 2022 7:04 PM
Tony: Wow, now that's a new one for me. And she can't be very big- looks like a small plane and in 1/72nd.
68GT: Ohhhhhh very cool! Doing the 188E-1 here but bigger! That looks cool.
Sorry, worked on PE for the cockpit this weekend till my eyes crossed. Hopefully I'll be done and have photos soon.
Posted by Bish on Sunday, January 23, 2022 5:33 AM
Got most of the major parts fitted to the Stuka including fitting a quickboost  compass and getting the wings on once the fuselage was together. No major fit issues as i expected.
Then got the canopy on and all the sub assemblies ready. As you can see i am leaving the undercarrage off. I've also learnt my lesson when it comes to adding actuators and airelon balances to soon, have had to scratch more of those than i care to remember, so i am painting them seperatly.
It got a primer coat yesterday followed by the undersides being painted, so will be able to mask off in a day or so.
Posted by Gamera on Thursday, January 27, 2022 11:33 AM
Oh that's superb Bish- nice work!
I got to the point that I was knocking the stupid little PE levers and knobs off while installing the seat belts on the Ju-188, lost my temper and had to put the thing aside. Sorry keep promising photos but she's a bit of a mess right now. Will get some up when I've calmed down a little.
Posted by Gamera on Sunday, January 30, 2022 10:26 PM
Okay here's about as far as I go. This should be decent enough once the canopy is put in place. The belts aren't perfect but it's good enough for me. I ended up knocking off about a dozen control levers putting them in. Finally I just had to scream ENOUGH. I think only the throttle levers were red but I didn't feel like looking up what lever did what and it adds a little colour to the cockpit.
And I found these cool masks on AliExpress. They're a little on the small side so it's going to be more work to make sure the edges look right but it's probably better than I can get free-handing things.
This is what I'm aiming at:
Posted by Bish on Monday, January 31, 2022 12:36 PM
Thats looking good, be interested to see how those masks work out.
    November 2008
Posted by plasticjunkie on Monday, January 31, 2022 3:57 PM
Gamera
I can see those stencils making the task a whole lot easier! Great idea.
Posted by Gamera on Tuesday, February 1, 2022 7:30 PM
I'm crossing my fingers guys! Thanks PJ, stencils is the term I was looking for!
Posted by Bish on Monday, February 7, 2022 1:55 PM
I got the Stuka painted with the European scheme.
I started masking for the sand before i remembered to get some pics.
I then added the desert camo. Some profiles and the kit instructions have the sand right along the side. But photo's don't bear this out. My main referance, Classic Colours Luftwaffe Colours Stua Vol 2, has 3 decent pics of the left side along with a nice profile based on careful study of the photo's. This only shows RLM 79 in 2 patches under the canopy. These patches seem to match the areas where extra armour was fitted to the D-3. But many aircraft, includeing this one, don't have this armour. I am woundering if the ground crews may have removed it and patched it up with the 79. The kit instructions don't match what little can be seen of the top of the left wing. So i went with a combination of the photo's, instructions and guess work. There is no top down image of the tail, but there does seem to be any 79 there so i left that. The photo's do show the 79 is well worn on the wing. So i replicated that (first time doing weathering like this on an aircraft) by dry brushing the enamel paints and then useing 502 oil paint, there German Orchre is quite a close match. I'm quite pleased with how its looking. I also added the white tail band.
I'm going to leave the oils to dry for anotehr couple of days then polish some rough areas and seal before adding the decals.
Posted by Gamera on Tuesday, February 8, 2022 6:29 PM
That looks cool Bish! Looking forward to seeing what everything looks like when the oils are dry.
Posted by Bish on Friday, February 11, 2022 4:04 PM
Cheers. I'm pleased with how it tunred out, adding the decals now.
Posted by Gamera on Sunday, February 13, 2022 7:37 PM
Sounds good Bish!
Going a bit slow here, the way the instructions show it I ended up putting the landing gear in the opposite wings. I had to yank them out and reverse them. Great to see Dragon instructions were confusing even back then... Sad
Or maybe I'm just stupid...
Notice the landing gear has to be turned around backwards to be mounted in the wing:
Posted by Bish on Wednesday, February 16, 2022 6:32 AM
Its bound to be Dragons instructions, at least you were able to remove them.
Posted by Gamera on Monday, February 21, 2022 8:31 AM
Bish: Any new photos? Looking forward to seeing how she looks with the decals on.
Still hacking away here. The fit ain't the greatest. But I really like that the kit is buildable in modules. Just like an armour kit where you can build the lower hull, turret, tracks etc in sections and then add them all together. Not sure if Dragon as a mostly armour company designed the kit that way or it's just part of being buildable as different versions of the 188. In any case I'm building the fuselage and each wing as a separate part. More photos when I have something worth photographing.
Posted by Bish on Monday, February 21, 2022 8:40 AM
Ye, took a couple of the finished aircraft last night. Just got to finish off the base and sort some figures. So should be able to wrap this up in a couple of days.
I have buil;t a few Dragon aircraft kits but only in 72nd and i really like them. It does sound like they put some thought in when they designed your one.
Posted by Gamera on Friday, February 25, 2022 9:14 AM
Sorry still not much to see since I'm still puttying and sanding, rinse and repeat but here's some idea of the modules I'm assembling the kit as:
Posted by Bish on Saturday, February 26, 2022 4:12 PM
Sound slike a lot of work going into that Gamera.
Just got to finish off some figures and i'll get the pics up of the Stuka.
Posted by Bish on Sunday, March 6, 2022 5:58 AM
I got the Stuka wrapped up this week. After some light weathering with Flory wash and exhaust staining it got the mat coat. I am very pleased with how the worn look to the sand paint came out. The instructions said to paint the spinner sand but of course it should be blue. And i used some AM decals for the wheel spats as the kit ones were white, and of course they should also be blue. The bomb load are Kora resin bombs. I was inspired by a photo of a banking D-5 on the Russian from from one of my books. It had this bomb load, SC250's with fuze extender's and the bombs were a mix of green and blue. I had to paint the white on the antenna mast as there are no decals for this.
And then onto its base with 4 figures and a Kubel.
Nice to get this done. Next up with be the Tante Ju, but that won't be for a bit.
Posted by Gamera on Tuesday, March 8, 2022 8:00 PM
Splendid work Bish! As usual I love your dioramas! Yes
Not much to show here. The Tamiya P-38 I'm building for Steve's Lockheed GB is going so well it's been dragging me off to concentrate on it...
Posted by Bish on Saturday, March 19, 2022 7:06 PM
Thanks G.
Sorry guys, not been keeping up with things the last week or so.
Posted by Gamera on Sunday, March 20, 2022 9:07 PM
No problem here.
Where did everyone go though!?!
Posted by Gamera on Monday, March 21, 2022 10:53 PM
Bish: A little off topic but I thought I'd share these with you. And apparently you can no longer send private messages so I'll just post them here.
Saw these and thought of you!
https://www.aliexpress.com/item/1005003529690402.html?spm=a2g0o.store_pc_groupList.8148356.61.522c5efc3SXXe7
https://www.aliexpress.com/item/1005003194123739.html?spm=a2g0o.store_pc_groupList.8148356.21.53c05efcpzUEbq
They've got a few other SW themed figures too.
    August 2015
Posted by crown r n7 on Wednesday, April 20, 2022 9:27 AM
P.J. That is one busy cockpit.
Taxtp. A very unique kit.
68GT. That looks interesting!
Bish. looks stunning have you built Ju-88's before? lol.
Gamera. Great job on the cockpit ! Those masks can be tricky on the eye's at least for my eye's but great idea.
as for me I'm switching to the Tamiya JU-87B-2 in 1/48 from the Airfix kit too many broken little bits for me to handle on the Airfix kit
 Nick.
Posted by Gamera on Friday, April 22, 2022 9:46 AM
Thanks Nick!
Sadly between other stuff and pollen allegies I still haven't gotten much more done on the the JU-188. I have puttied and sanded the heck out of the fuselage. There's a 1mm or so step between the cockpit/nose portion and the rear and I really don't want to sand all the detail away trying to get them to mate properly.
Posted by Gamera on Monday, April 25, 2022 8:33 PM
I did get her mostly together last weekend. I need to do a lot of work adjusting the wing dihedral before cementing everything in place for good.
