QUOTE: Originally posted by bobbaily
Sean-quick question regarding your weathering techinique on the pic above. Did you apply aluminium paint after the green or did you do aluminium first and then green? If the later, what method did you use to remove the green?
Thanks in advance.
Sorry for the late reply mate, just a tad flat out lately
On this one I went aluminium first, and allowed it too dry for 24 hours.
Then I got a piece of foam and dipped it
LIGHTLY into some Maskol.
Then I dabbed it onto the aluminium surfaces in a rough manner.
Then oversprayed with IJN Green.
Once that was dry, I simply rubbed off the Maskol with my finger, and voila!!!
I had to use Humbrols Maskol cause I use acrylic paints, and most other masking liquids are water based.
