Ok you can now count as officially completed my (first) build for this GB.
Here is Heinz "Pritzl" Bär's Fw 190A-7 which started out life as the Tamiya A-8 kit. The modifications needed to backdate an A-8 to A-7 spec are as easy as you can get, all that was required was
- With the introduction of the A-8 the ETC carrier was moved 8 inches forward, so I moved the rack mounting points about 2mm behind the indicated positions and shortened the rear section of the rack by the same amount.
- The outline of the large MW50 access hatch was filled and sanded smooth on the bottom of the fuselage was filled and sanded smooth. This hatch provided access to the MW50 gear and was not present on the A-7.
- Another panel was removed from the starboard fuselage side, the fuel filler hatch was relocated, and a further hatch filled and smoothed on the port side of the fuselage. All the hatches were filled with Mr Surfacer 500 which really did the job nicely.
- I filled and sanded the outer wing gun ports as my references stated that Heinz Bar preferred the extra maneuverability at the expense of extra hitting power. I also filled and sanded the shell ejector ports for the outer wing guns as these would not have been present with no outer guns fitted.
- The Pitot tube was relocated from its position on the wing tip to mid-wing.
As for the man himself, Heinz Bär is the 8th ranking air Ace of all time. He fought on every German front throughout the entire duration of World War II in Europe and Africa. His 16 aerial victories acquired while he flew the Me 262A place him as the 2nd ranking jet ace of WWII. Almost all of Heinz Bär's assigned combat aircraft were numbered "Lucky 13", as his own preference regardless of his position within a respective unit. Postwar, Heinz Bär would eventually become an aviation consultant. In 1957, while performing aerobatics in a light plane on the anniversary date of his 200th aerial victory, Heinz Bär was killed instantly when he suddenly spun in from a low altitude.
This is a shot of Bär after his 200th victory wearing his favorite U.S. flying jacket.
Here are a couple of shots of the finished model, unfortunately I really made a hash of the lighting and the kit looks quite glossy in some of the shots, which it doesn't in real life.
Thanks for looking
