It Floats and Flies
Posted by Chatterer on Monday, May 15, 2006 10:35 AM
Thanks Aurora-7. I used Tamiya and Polly Scale paints. X-10 Gunmetel for most of the engine, XF-16 for the Aluminum on the top and the pipes were Polly Scale rust. And I just used a brush with thin coats to paint it.
David
    September 2004
Posted by lerxst1031 on Monday, May 15, 2006 11:40 AM
Only the fuselage is molded clear, which makes the window installation easy!  Tongue [:P]  I'm a little concerned about the seam on the windscreen though; there's a small gap between the windows, but it's a small one...
I'm not sure what it'll look like yet, I'm lucky since I get to see so many flying about here (I live less than a mile from the largest floatplane base in Alaska!).  Lots of inspiration.  It'll probably be something like "Fred's Air Taxi" or something a little catchier!  I just wanted the shiny natural metal finish.
Fred
Posted by Chatterer on Monday, May 15, 2006 6:51 PM
More pics
Here are the floats still need some clean up on the seams yet
Fuselage since the Albatros had a wooden fuselage I had to paint the inside Testors wood then dry brushed it with Tamiya XF-10 brown. I will also do the same for the out side when it is time to paint.
Cockpit seat sits to low I might fix it later.
Fuselage joined as you can see I have some filling to do not the best fit but not the worst.
David
    July 2003
Posted by bwr1 on Monday, May 15, 2006 9:55 PM
Got all the parts cut out and cleaned up on the Bv. 238.  I taped it together to check for fit problems.  I think when people ask me what type of kit this is once I'm done, I'll say "putty".  Anyway, a couple of shots of the test fit:
From the test fit, there are a lot of fit issues.  One wingtip will need to be reconstructed (the top part is too small in length but too large in width), the engine nacelles will need lots of work, and the tail will need some reconstructive surgery.  Plus the fuselage will require some serious bracing and squaring up (you can see in the pictures how the top of the fuselage bows downward).  I'll also need to build a spar out of wood.  My usual trick of using a straight steel rod or piece of metal here won't work since the wings have too much dihedral.  Ahh, the joys of vac kits.
I've also figured out that I need to find a supply of leftover Bf. 109 engines - the engines on the Bv. 238  are a variant of those on the 109, and I really don't want to scratchbuild exhausts and propellers for all 6 engines.  Anyone got any ideas or any source of real cheap 1/72 scale 109 kits?
Bruce
    November 2003
Posted by ghettochild on Monday, May 15, 2006 9:56 PM
Looks good David, just ordered mine today, cant wait to start it!
Nice work Bruce, that thing is a monster
-Josh
    July 2003
Posted by bwr1 on Monday, May 15, 2006 10:01 PM
I wonder if maybe using some white glue to fill that gap might work - you could dab it on and then use a wet q-tip to even it out.  I've use that trick a couple of times before - I just have to remember not to wash that part of the model in water before I get it painted (oh no, didn't learn that one from experience at all).
Bruce
    October 2005
Posted by gulfstreamV on Monday, May 15, 2006 10:31 PM
How about Microscale Kristal Kleer?   maybe?
Stay XX Thirsty, My Fellow Modelers.
Posted by Aurora-7 on Tuesday, May 16, 2006 5:57 AM
I've gotten started on the construction of the fuselage interior, floats and wing.
Posted by Chatterer on Tuesday, May 16, 2006 7:32 AM
Looking goot bwr 1 going to be a nice looking aircraft once done.
Aurora-7 your build is looking good too.
Not much to update, filled in the seams so now I dont have any thing to work on today. Expect for building the wings.
David
    October 2005
Posted by Jaypack55 on Tuesday, May 16, 2006 10:34 AM
Here's my progress: (sorry there's nly one pic, my internet is really slow, and it takes forever to upload to photobucket)  It's the Tamiya 1:48 A6M2-N "rufe". I just got this far last night.
-Josh
Current Builds: If I were to list everything I have in progress, it'd take way too long! Some notable inclusions:
Hasegawa 1:48 KI-84
Tamiya 1:48 P-51D (in Iwo Jima long-range escort markings)
4 (yes, four) Tamiya 1:48 F4U-1s (1x -1D, 1x -1A, and 2x -1s)
Posted by Chatterer on Tuesday, May 16, 2006 4:14 PM
Looks good Jaypack
More pics
got most of the fuselage sanded still needs some more yet.
here are the floats they were fun to aline.
shows were I had to drill holes to get the struts to fit in same for the wings also.
David
    June 2003
Posted by Lucien Harpress on Tuesday, May 16, 2006 9:22 PM
bwr1-  Awesome pics.  The BVv 238 is one of my favorite aircraft (it's big and rare- what's not to love?), and it's only been recently that I realized there was a kit for it.  I totally get it when you say your kit is made of putty.  My H-4 is the same exact way.
Two more things- the cheapest I've seen a Bf 109 kit is about $4.50 for the Airfix version, and the Academy version is about $8.00.  (Of course, shipping will bump both those prices up)  Second, even though this makes no difference now, I heard that Wings Models is set to release an improved vacuform kit of the Bv 238 with resin details, including the engines, in the summer of 2007.  I'm going to wait for that one.
Other than that, keep up the good work!
FrogFoot- Very nice nice progress.  Keep up the good work.
I only have an update I already posted in other Forums on this website.  I took a few comparison pics of a mostly complete H-4 mockup with a same scale B-17, and of a foot long ruler.  Enjoy!
http://img.photobucket.com/albums/v296/LHprs/compare1.jpg
http://img.photobucket.com/albums/v296/LHprs/compare2.jpg
The only major update for the forseeable future is a whole bunch of sanding.  Stay tuned!  Big Smile [:D]Thumbs Up [tup]
That which does not kill you makes you stranger...
-The Joker
    September 2004
Posted by lerxst1031 on Tuesday, May 16, 2006 9:48 PM
Looking good guys! Mike, I'm dying to know where you're going to put that beast!
Oh, and I've gotten sidetracked... I'm building up the Modelcraft C172 on floats for my folks' wedding anny this year, since they're both lovers of the outdoors. Could I add this to the GB as well? Or do we frown upon multiple entries? Besides, if I have 2 entered, I may be able to finish one!
Fred
    July 2003
Posted by bwr1 on Wednesday, May 17, 2006 12:01 AM
Thanks!
And thanks for the info - I'll look into the Bf 109 kits.  Trouble is I need 6 kits.  I spent some time tonight cleaning up one of the nacelles, opening up the intakes and exhaust ports.  I may try to build a set of exhausts (6 - one side of the nacelle) to see how much effort it would be to make 12 sets (that's 72 total cylinders to deal with).  I found some good reference photos to work from.
Wings Models has a lot of interesting kits on their schedule, but I think the whole schedule slipped quite a bit when the owner suffered a ranching accident last year.  But if my building this kit leads to a better one being released, I'll take one for the team.  Won't be the first time.  I finished the Nimrod vac kit a couple of years ago, and now there's an injection molded one coming out.
Big is good.  I was working on an An-22 but put that aside to work on the Bv 238 and the An-225.  I also have an An-8 on the bench that's far enough along that I want to finish it rather than set it aside, so it's sucking up a fair amount of my time right now too.  That kit is also made of putty (three different kinds - I used it as a putty testbed, as well as using superglue and Mr. Surfacer on it)
Bruce
Posted by Aurora-7 on Wednesday, May 17, 2006 9:07 AM
Well, we seem to be well underway. Bruce, that Bv 138 is immense even in 1/72. But Lucien's H-4 is absolutely colossal! Dave, at your rate your gonna be done well before summer. Plenty of time to do another 'floater' Wink [;)]
Posted by Chatterer on Wednesday, May 17, 2006 10:02 AM
 I think I will start another one, once this one is done. The Rufe may get built yet or I will order up the late version of the Albatros this week.
David
Posted by Chatterer on Wednesday, May 17, 2006 3:55 PM
Here is the fuselage painted with Testors Wood then dry brushed with Tamiya XF-10 Brown
Need to glue the engine in now and the guns and a few other parts.
David
    September 2004
Posted by lerxst1031 on Wednesday, May 17, 2006 4:06 PM
FrogFoot, that wooden fuselage looks fantastic!
Fred
Posted by Chatterer on Thursday, May 18, 2006 7:38 AM
Thanks Fred.
I am going to try to mix the doped color for the wings today, so I dont have to wait four days to get a bottle. Might as well paint the floats today also, pics later.
David
Posted by Chatterer on Saturday, May 20, 2006 6:53 PM
Here is the Albatros with the wings on now and floats
Messed up on the paint on the tail as you can see in the first pic, but lucky for me a decal covers that spot.
Tomorrow I will gloss coat the Albatros and decal Monday.
David
Posted by Aurora-7 on Monday, May 22, 2006 8:42 AM
Dave, that fuselage looks pretty good. These images remind me that I've got to make sure I visit the Old Rhinebeck Aerodrome this year and see some flying Albatrosses.
I've been trying to cleans out a spot in my basement to do some airbrushing. I've got a compressor and airbrush that I have yet to use since I bought them both two years ago.
Posted by Aurora-7 on Tuesday, May 23, 2006 9:19 AM
Look at this fictional floatplane fighter:
http://www.scaleworkshop.com/workshop/monsoontm_1.htm
    September 2004
Posted by lerxst1031 on Tuesday, May 23, 2006 6:47 PM
That base looks great, maybe if I'm motivated enough, I'll give something like that a go!
Check out what I found, maybe for next year's...?
Fred
    November 2003
Posted by GA.modelmaker on Wednesday, May 24, 2006 1:38 AM
ok you can put me down as a maybe. i just have to see how my other builds go, you can list for me either a martin sp5b marlin or a pby-5 catlinia.
Posted by Aurora-7 on Wednesday, May 24, 2006 8:29 AM
I'd love to see that Marlin, GA. I've got you down as a 'maybe'.
Fred, where'd you get that P-38 on floats? That'd be great to see done up as a model. Maybe for next year we should do a "What if it could Float and Fly" build.
    September 2004
Posted by lerxst1031 on Wednesday, May 24, 2006 11:39 AM
www.p-38online.com
, of course!
Float Plane
One of the most unique aircraft designs during the war was with P-38 floatplane. It never came to fruition as an operational aircraft, and never was tested. This design called for a P-38 to be fit onto large floats while its regular landing gear was retracted. These floats would then be filled with fuel allowing the aircraft to be ferried across the pacific. Early in the war, the American aircraft presence in the Pacific was woefully inadequate. Bases still were using outdated aircraft such as the Brewster Buffalo, which were no match against Japanese fighters. There were heavy bombers such as the B-17, but they were not effective against moving shipping targets in the ocean. Though the Battle of Midway was a decisive victory, the aircraft being used were mismatched. The victory would be attributed to knowledge of Japanese codes, perfect timing, courage of the pilots, and plain luck. General Arnold knew that the American forces needed a boost in available, modern aircraft to fight the Japanese. By December 1942, P-38s were being used in operations in Buna and other locations in the southwest Pacific.
As with problems getting the aircraft to the field of battle in Europe, many were questioning how to get adequate numbers of aircraft to bases in the Pacific. The floatplane design in theory would allow P-38s to be able to fly extreme distances until it needed to refuel. This idea also called for the P-38s to make landings in protected waterways, where they would be refueled and resume their flight to their new base of operations. Once the P-38 was within range of the home base, explosive charges would remove the floats, and the aircraft would then land normally. One problem that needed to be addressed was the tail section. The tail would pose problems during takeoff and landing on the water. One way to address this problem was to raise the entire tail section. Wind tunnel tests revealed minimal performance loss. However, since the Battle of Midway put the Japanese on the defensive, it would not be dangerous to ship the new P-38s to Australia, where they would be ferried to their bases of operations. This idea never got off the drawing board, but a P-38 was tested with a raised tail. Kelly Johnson was interested to see how it would be affected by compressibility. No substantial results were obtained, and no further raised tailed P-38s were tested.
Fred
    November 2004
Posted by PanzerWulff on Wednesday, May 24, 2006 1:30 PM
Hi all is it ok to do a model that is in another build? I am doing a PBY-5-A in RAF coastal command livery for the Battle of the Atlantic GB
and as for the P-38 floater heres some pics of one they actually built the F4F Wildcatfish
neat lookin lil bird huh?
ACE??? you were NEVER an ace AN ace HOLE maybe! (Lister to Rimmer on BBC's RED DWARF) Chris"Hey GRAVITY still works"Gray
    January 2003
Posted by cthulhu77 on Wednesday, May 24, 2006 1:43 PM
If it's not too late, I'd like to jump in with a Matchbox D0-18 too...
            greg
http://www.ewaldbros.com
Posted by Aurora-7 on Thursday, May 25, 2006 5:59 AM
PW and cthulhu77 ,
It's never too late. You're both in but , cthulu77, the member list post locked for some reason right after I added PanzerWulf. Something flaky must have happened and I'll contact the forum admin about it.
    November 2003
Posted by JoeRugby on Thursday, May 25, 2006 8:05 AM
Okay so I am way over committed on GB's this year.  But for about the past year I have p**sed and moaned about not having a personal connection to any of my builds.  You know like my uncle or grandfather flew this or drove that.
Well this build will solve that for me.  I want to jump on in with the Sword 1/72 Goose.  Registration number N781.  Flown by the Alaska Department of Fish and Game out of the Ketichican/Petersburg Area.  Warden Officer Ken Gilpin (my friend ad fishing/hunting buddy) is my inspiration.
I will post a photo this evening of the actual plane as well as give a breif description of the modifications done to this bird.
Check out the WW I Special Interest Group @ http://swannysmodels.com/yabb/YaBB.pl?board=WW1SIG
