Update in the Bv.238 progress. I finally got the German-languge reference book - it has a lot more photos than I was able to find online. This is good and bad - now I can tell all the areas of the kit that are inaccurate - I was blissfully ignorant before. It's been helpful in making progress on some details.
What I've gotten done:
Fixed the window locations and shapes - based on the photos I had to fill in some previously cut out windows.
Started reworking the nose shape - it's all wrong. Filled the interior of the nose with epoxy putty and then sanded the plastic (and into the epoxy) to a better approximate shape. Still more sanding and shaping to be done.
The float shape is wrong - the kit part is angled funny and has a pretty narrow taper at the bottom. I think the structure is fairly complicated but I can't tell for sure from the photos so all I did was correct the gross shape errors with epoxy putty. Wish I had before and after photos, but I forgot to take the before photos.
The engine shape is way off - too thin and wrong shape. I can fix the thinness (sort of) but can't fix overall shape without a complete scratchbuild so I'll do what I can with the kit parts. I've cast some details for the engines, and assembled one of them. I used MicroMark's starter kit for mold material and resin. This was my first time casting something, and it worked out much better than I expected.
I made master parts for casting. The prop spinner is basswood carved to rough shape and then chucked in my dremel and sanded to final shape. The exhausts are kit parts from a Hasegawa Bf109G kit:
Here's the mold:
I made 6 castings. One set is already on the assembled engine:
The assmbled engine (right) next to the original kit parts (left) for comparison:
Next up - making prop blades and finishing all six engines. The first one needs some rescribing, an access window cut out, and final filling with Mr. Surfacer. After that, I'll probably start on scratchbuilding the cockpit. I have Revell's Bv.222 kit, so I think I'll use that as a starting point for the Bv.238 cockpit since I can't find any really useful reference photos.
Thanks,
Bruce
