Alternate track controllers..
I've been finding it harder and harder to find sources of DMD-T01 (simple DMD) units, and someone mentioned the SozBots micro-controllers. These were designed for the micro-robotics combat units, and fit our bill rather well, apparently...
Has anyone really given them a workout? Willy has tried one, but its not the one I'm interested in. I know willy 'torture-tests' ones he uses, but I'd like other opinions if there are any...
I was aiming at the SozBots SozDSC-MX unit at $68.95. The SozDSCR2.3-X is only 57.95, but does ~not~ have a built in mixer.
The MX units have a jumper that can set them to run separate track (like a dozer), or a single stick/mixer mode (wish the DMD did that) It also has a third channel 128-step forward-only 'weapon' throttle (no protections) with 13 amp max (anyone for a Sherman Flail?), and a 4th channel 'invert' mode for those models that can run upside down (no use to us tankers)
The R2.3 doesn't have the mixer, but its set up as two separate ESC's, so if you burn one out, you can snap off the damaged half, and use the other solo.
These are 64 step proportional forward, 64 step proportional reverse units. Both have a 5.0 amp motor limit, 5 volt BEC's, overheat, overamp and undervoltage shutdowns, plus servo wires & motor lead screw-terminals.
Anyone using the SozDSC-MX unit? Unless anyone naysay's the MX, I'm gonna go for one for my Tiger 1... with the savings I can get a 4ch GWS 'Naro' Rx as well.
