QUOTE: Originally posted by tomzag
well, the set I got are willys. and I do not wnat to state who pass the set to me. I had hard time line up the holes to mount them onto gearboxes. but I did. It is not the biggest problem. the products from garage factory are not perfect, you have to work a little to make it work.
But the noise was my big concern, it sounded like small scale turbine engine from M1 tank. the tank was running, but it make me feel unsafte. I do not know if I would break the gears or not.
i have been building rc tanks for people or me. I have at least built 50 tanks already. I have tried different gear reduction products, armorconcept, bob's, etc, they work differently, only willys one make me feel that way.
i can not speak for all other people. i can only state my own experience. LIke in early post, "personally, I do not like willys reduction kit". only me, do not like it.
Please go ahead, order, use and leave positive feedbacks if you like them. so other people will know.
Is it still Toyota even I did not buy it directly from Toyota factory? :)
Tom ,
that you had a hard time to line up the mounting holes , that tells me right away ,
that these type gear-reductions you got , are not for that particular gearbox ,
you are using them for ........
my gearreductions do fit right away , no messing arround required ....
what other people do with my gearreductions and then sell them to somebody else ,
I have no controll about that ...
since you know me ,
why didn't you ask me in the first place what the problem may could be ,
insteed posting such statements .......
even if these gearreductions look like mine ,
doesn't mean they came out of my shop ...
my stuff is machined very precise ...
I know that quite a few people trying to do the same thing ,
but they don't seam to get there gearreductions accurate enought ...
I tell you what , send me these gearreductions you got ,
let me know for what tank and gearbox-style you are use them for ,
and I can tell you if these have bean made for that or not ....
if these gearreductions truley came out of my "garage" ,
I will send you a set what fits .....
if you tell me from whom you did get your set ,
I can tell you for what application they have bean original build ,
since I keep track on who gets what ....
I don't see the reason for keeping it secret from whom you did get them from ...??...
Willy
CustomRCmodels
