Thats the set I got for this model. I used the WEM set on my 1st
Bismark but didn't want to spend the $$ on this Minicraft kit.
This PE set is still tops. I started the radars 1st and, being a
newb with PE, they went together without a hitch. The hangar
doors are pretty thick if you glue them strait to the hangar sides, I
cut out the plastic on the originals and glued the PE sides in place
and it looked a lot better.
My funnel screen was too large, but again, on this Minicraft kit,
nothing seemed to fit right. The aircraft details on this PE fret
will make a big differnce to the kits planes.
The Tamiya has a lot of detail, the Minicraft kit has nothing on the
sides of the superstructure, so the door and window set was a must.
I have begun putting the railing around the maindeck and will use maybe
half the fret. I too was concerned at first about running out,
but now it looks like there will be enough rail for the whole
ship. If not, it doese hurt to order extra railing frets, you'll
used them on other projects.
Scott
