Silentmodeler, mph 34 has given you a good reference site. Yes, the carriers, and most other ships as well, have their own web pages now days. As far as the weathering goes, how old/new do you want the deck to be? I assume that you are replicating the flight deck and not the hangar bay, so after the initial dark grey I would add any lines that would be on the section of deck you are showing. If your flight deck is the same one that I have, it will need to be a generic area of the deck as there are no weapons elevators, jet blast deflectors, or other areas being displayed. If you look at photos of a carriers deck you will see white, red and white, and red and yellow stripes, all of which have significance. The landing area is bordered by the most pronounced white lines, red and white are safety lines to keep folks back from the catapults when in use, and the red and yellow lines are around the elevators (deck edge and weapons) as well as around the electrical power and launch control between catapults 1 and 2. For weathering, I would use an oil wash that is dark enough to add depth then add some colored spots to resemble leaks. Just for your information, the flight decks are washed down frequently with fire hoses (water at 150 psi) and heavy duty brooms for scrubbing, so stains do not last too long. If your deck section is a parking area, the non-skid will be in relatively good shape; whereas in the landing area it will be chipped up due to tailhooks dragging across it (not every plane lands on the first attempt) and will show black skid marks from the tires. I would use a lighter grey or two just to show high points no matter how weathered you want the deck to be. The F-14 has three main wing positions. Fully extended (swept forward) is for landing and takeoff, as mph34 wrote earlier. In flight, the wings can sweep back up to 75 degrees. To reduce space on the flight deck and hangar bay, all Navy aircraft have wings that fold or move in some way to make a smaller "footprint". For this, the Tomcat can sweep its wings back to 68 degrees. If you play with the fit of the wings on the Hsegawa kit you can show any of these 3 (on mine, I went with the 68 degree "oversweep" position). Keep us posted on your progress and I may actually gert around to assembling and painting my deck section. Also, before I forget, Verlinden put out a 1/72 catapult section several years ago. It is made of a foam material for the base and the jet blast deflectors (also known as JBD's) and actuators are cast in resin. Yeah, I've got one sitting on the shelf where it has been collecting dust for quite some time, but one day... Once again, let me know if I can be of any further assistance. |
