Secret Santa- WWII Aviation GB
    May 2003
Posted by DrewH on Friday, February 23, 2007 12:52 PM
Well, here is the fun part Whistling [:-^]
This fus has a nasty warp in it that I could not correct. I tried every trick in my book to fix it, but that is the best I could get it.
So, the solution is to cut the fusalage at the twist point. I thought about forcing the two together, but that twists the whole plane to where the wings are not level and the tail has a noticable bend in it.
It's not going to be without comprimise mind you, I won't be able to open up the detailed gun bay. The shim I will need after I won't be able to hide inside. It's the worst warped piece I have ever seen.
I'll post pics of the completed interior when I finish it. For now, it's off to cut this beautiful thing in half Boohoo [BH]
Take this plastic and model it!
    December 2004
Posted by Hippy-Ed on Saturday, February 24, 2007 11:10 AM
Man that SUX Drew!!Yuck [yuck] Hopefully you can fix it... wanna use my Bat?!Evil [}:)]
If you lose your sense of humor, you've lost everything
    May 2003
Posted by DrewH on Saturday, February 24, 2007 11:30 AM
LOL, I thought about it Ed. But I think if I cut it along the black line it will work.Any remaining twist will be no problem. I have the interior painted now. It's done in the transparent blue/green that the Japanese used. I took a tip from an article on another site on how to paint that color. It looks pretty good. I will try and finish the cockpit in the next couple of weeks and post some pics then.
    December 2004
Posted by Hippy-Ed on Saturday, February 24, 2007 10:33 PM
Sounds good Drew! I know when I worked in a woodshop doin' spiral  staircasings we steamed the railings & had "peg boards"  we set them in as they cooled. Have you thought of something like that with this twist?
Lookin' foreward to some pics of your Cockpit colorTongue [:P]
    July 2003
Posted by sidure on Saturday, February 24, 2007 10:38 PM
WOW!!!!, Drew you have your work cut out for yourself there with that warpage, I am sure you will solve the problem though. I think cutting the fuselage is the best way to go. I am looking forward to seeing how it works out. Good luck with it.
Steve
    December 2004
Posted by Hippy-Ed on Tuesday, February 27, 2007 12:16 AM
Not much of an update but, I gave my P-51B a bloody noseMischief [:-,] and painted the landing gear and, I had intended on painting the white stripes on the wings today but, My father came into town  & had other plans for me which took up most of the dayBanged Head [banghead]
    October 2005
Posted by gulfstreamV on Tuesday, February 27, 2007 12:39 AM
Still here and sorta put the TBM on hold. Need to finish up at least 2 GB builds that are close to done. Then spend some focus on this nice AcMin. kit. I'm a SnailCool [8D]
Stay XX Thirsty, My Fellow Modelers.
    August 2004
Posted by cj95 on Tuesday, February 27, 2007 8:52 AM
Howdy from Texas.
I know its been two months since Santa visited, so I figured I better get a move-on with my P-40 Chop-Chop plane.
Not too much done at this point and its kinda a bad photo, but progress is being made on the pit.
Trying to make my own belts from masking tape for the first time, but could not get a good photo.
Just proving Im still here.....
    December 2004
Posted by Hippy-Ed on Tuesday, February 27, 2007 5:55 PM
Glad ta see yer still here... NOw Git 'er Done!!!Mischief [:-,]
    August 2004
Posted by cj95 on Tuesday, February 27, 2007 8:41 PM
Aye aye capt.
 Spent most of the day on the Chop Chop.  (with one break to Hobby Lobby for the 25% off sale)
I'm about 90% pleased so far, but there are some minor fit issues.  Note the killer gap at the wing root.
Not sure about Hasegawa's decision to seperate the fuselage into two halves, but some more putty work should work out okay.
As mentioned in my last post, I tried making some masking-tape seatbelts with mixed results.  I think I need to add some sort of buckles or something, they also look a bit stiff, but then again this is my first effort in belts.  Ideas?
(Satisfied for the moment Hippy?)  Wink [;)]
    December 2004
Posted by Hippy-Ed on Tuesday, February 27, 2007 8:53 PM
Now 25% off  is a good reason to go to the Hobby shopApprove [^] I see what ya mean about that gap in the wing root.Shock [:O] Looks like some shims are in order thin strips of styrene tucked in there.
andto be honest with ya, those belts look abit thick for that scale.
Not bad for your first go aroundThumbs Up [tup]
Yes, I am satisfied for the momentWhistling [:-^] Doin' good so far & that I.P stands out nicely!
    May 2003
Posted by DrewH on Tuesday, February 27, 2007 10:25 PM
Hey CJ, not bad at all. Yea, maybe a bit wide in the belt, but nothing wrong with not wanting the pilot to fall out. A bit of silver paint on the ends replicated the buckel ends very well.
As for the wing root, I have used .005 (5 thou) card with great results. 10 thou looks like it may be a bit thick, but give some a try. If it fits in, superglue it and sand smooth.
Looking very good. Can't wait to see it painted.
    October 2006
Posted by Mist086 on Wednesday, February 28, 2007 7:20 AM
Looking good CJ.  Always wanted to try the masking tape seat belt trick, but was was afraid to.  Hmmm maybe i can now
    December 2004
Posted by Hippy-Ed on Wednesday, February 28, 2007 9:22 AM
Thanks for steppin' in DrewBig Smile [:D] knew someone would  clarify thingsWink [;)]
    April 2005
Posted by wing_nut on Wednesday, February 28, 2007 11:33 AM
Cj...how is the dihedral on the wings?  If the bottom half of the wing is too flat...you may be able to get away with flexing the wings up, gluing the seems and holding it with tape from tip to tip 'til the glue cures.
Marc
Posted by Anonymous on Wednesday, February 28, 2007 4:47 PM
i couldnt get the chilean markings decal sheet, so i think i'll be doing a plain soviet-marked Yak-3
    December 2004
Posted by Hippy-Ed on Wednesday, February 28, 2007 9:19 PM
Man, that's a bummer!!Sad [:(] would it be too difficultt for you to have a set of decals made in those markings? There are a few people here who can do something like that.
    July 2003
Posted by sidure on Sunday, March 4, 2007 12:51 AM
Hey Guy's, been kinda quiet out here lately so I hope it's because of all the building going on. I have been making some progress on my C-47 and have the fuselage buttoned up and the wings completed with all the other major assemblies also done. Some sanding to come next and then priming.
With all the work on the interior it's a shame most of it can not be seen. There is some nice interior parts to this kit and the fit was excellent. Oh well, at least I know it's in there. Now for the major problem that I just discovered. On dry fitting the wings to fuselage joint, there is a gap on both sides like the grand canyon!!!!!.
I guess I will now get a chance to do my first shim job and see how that works. I think it's too big to fill with putty.
Steve
    May 2003
Posted by DrewH on Sunday, March 4, 2007 11:59 AM
Looking good Sidure, get shimmin buddy Big Smile [:D]
 I have got the hardest part over with. I cut the thing Boohoo [BH] It was hard to take that first slice with my razor saw, but I did it. The cockpit is now complete, and the forward fusalage is glued together. Here's the pics you dawgsTongue [:P]
    June 2003
Posted by Avus on Sunday, March 4, 2007 12:29 PM
It's been quiet arond here and now I see why: everyone's been busy on his model and everyone's made great progress.
Me, too. So here's a pic of a dry fitting:
Klaus
Thanks to ImageShack for Free Image Hosting
    July 2003
Posted by sidure on Sunday, March 4, 2007 7:52 PM
DrewH, what a wonderful looking interior, great job. Comming along nicely.
Avus, good looking cockpit and as a dry fit it looks like it will be a good looking aircraft.
Steve
    August 2004
Posted by cj95 on Tuesday, March 6, 2007 10:57 PM
Marc,   You know that was a pretty good idea about checking the dihedral of the wings.
 While they were pretty much in alignment, a simple 1 mm shove in the right direction made all the difference between a simple putty job, and filling the Grand Canyon....thanks.
The rest of the builds look great, Drew, your seatbelts make me sick.  Mine look so silly by comparison.
    May 2003
Posted by DrewH on Sunday, March 11, 2007 1:37 PM
Well, progress has been made slowly. It is getting together bit by bit. The gear and details have been painted a base of floquil old silver. The lower wings are now on and the last of the nasty warp issues is about to be dealt with. It is so isolated not it has become nothing. The cannon bay has helped in keeping the rear fusalage in alignment and the correct width. Thanks Tamiya for the superior engineering! It would have been a real bear ir the cannon racks weren't there.
    July 2003
Posted by sidure on Monday, March 12, 2007 9:17 PM
Drew, it's comming along nicely. Very nice progress, keep up the good work. Good luck with the fuselage
Steve
    June 2003
Posted by Avus on Monday, March 26, 2007 1:56 AM
Time for a little
BUMP ...
It looks like the "surgery" on your aircraft went well, DrewH.
Looks good.
My progress is not worth being show as you'll hardly notice it. I've been puttying, sanding and twiddling around with PE in the last week-ends.
Actually I was ready for priming yesterday but found out, to my horror, that my Maskol was completely dried out ... will have to wait till next Saturday to get a bottle.
Klaus
    February 2005
Posted by RadMax8 on Monday, March 26, 2007 3:34 PM
Avus, thanks for waking this one up. I, too have made some progress on my kit- it's nearly ready for paint!!! I'm waiting to get a good coat of future on the canopies and then masking and piriming can commence!! I'll post pictures soon, I promiseAngel [angel]
    May 2003
Posted by DrewH on Monday, March 26, 2007 8:41 PM
Thanks Steve and Avus. IT's getting there. I tried to paint it last weekend, and had a couple of things to sand out and fix. So I applied a second coat yesterday and something went drastically wrongBanged Head [banghead] The first glossy coat turned flat after. Taped Shut [XX]Censored [censored]Censored [censored] Wha!?!?!?  I have no idea why, I'm using the same bottle of paint as the first, same thinner etc, just something didn't mesh.
 So.... a stripping I will go, a stripping I will go.......
    July 2003
Posted by sidure on Monday, March 26, 2007 11:03 PM
Sorry to hear of your painting wowes Drew. Same thing happened to me a while back. Best explination that I got was the difference in humidity!!!!!!.
I have been slaving away with a seam problem that just wont go away. ''Fill, sand, and prime over and over again and I still see itSigh [sigh]. I have the invasion stripes on the wings of the C-47 and have started on the fuselage. They are proving a little more difficult to get straight and am on my second attempt. I will prevail though.
Hope everyone else is progressing well.
Steve
    June 2003
Posted by Avus on Thursday, April 12, 2007 8:06 AM
Time for another
BUMP!
... and a progress pic:
Primed and preshaded the "Tank-Killer"!
Next WE the paint will go on ... I hope.
Klaus
    April 2005
Posted by wing_nut on Friday, April 13, 2007 6:21 AM
Looking good Avus.  Those are the straighest airbrushed lines I have ever seen.  you have quite a steady hand.
Marc
