Bushpig wrote: |
Nick. Interesting suggestion on the decals. Is this something that is easy to do, what does one need in terms of a printer, ink, paper etc. This could open up a whole new aspect to this great hobby. Tell me more, tell me more!!!!!!! |
Bushpig,
Its relatively easy, but can be quite time consuming. It requires a lot of preparation & test printing, but is really worthwhile as you'll have an utterly unique bike when youre done. I started out of necessity a few years ago, when I wanted to build bikes no-one made or made decal sets for. See this link for my first effort - all the decals are my own work: /forums/479204/ShowPost.aspx - turned out quite well and its my favourite build of all. Theres a few others Ive posted up as well if you do a search of my username.
What you need:
a PC (which presumably has MS Paint or some other drawing application),
a colour printer (preferably laser but inkjet will do also),
water slide decal paper (laser or inkjet as appropriate),
a shedload of patience ;)
So how to do it ?
1) Well, first off get as many reference pics of the bike as you can, then list all the logos, etc. you'll need for the decals. Then google for the logos - and when you find ones that suit save em as bitmaps (as .bmp files). BTW the bigger the logo, the better - you'll get much better definition that way. For decals you cant find (usually the bike number), Ive resorted to "drawing" them myself in MS Paint. If you make them big enough, they'll look fine when you reduce them later.
2) OK, so now youve your logo, paste it into a Word document, right click on the image and re-size it to the correct size - youll just have to guess at first but youll soon get fairly accurate at it, believe me. Repeat until youve all the logos sized about right. Print off a test page and check your sizes against the actual bike. This is the step that takes most time and numerous prints so dont use expensive glossy paper or anything. (I sometimes find it useful to have a 12/th scale side-on pic of the bike printed off to compare against as a secondary check. Printing your logos onto a transparent sheet can also be very useful). Adjust the size of the logos and re-print. Continue til youre happy. When youre confident youve all your logos correctly sized, fill up the page with loads and loads of them. Use every cm of space on the page to maximise the use of your decal paper. The more decals you have printed, the less it matters if you screw up when applying them.
3) A quick word re decal paper and printing. You cant actually print in white, so say if your bike fairing has a white logo on a red background youre in trouble. Decal paper comes in clear and white, so youve two solutions: print your logo on white paper with a red background and cut out as precisely as you can, or print your logo on clear paper with a red background and apply it over a white area on the fairing. Either way youre going to have to match the fairing colour to the background colour of the decal which can be extremely tricky and probably do a bit of touching up as well. I did the first approach with the white "Nescafe" logo on the TZR and it worked a treat (but the black background helped).
4) Now the tricky bit - printing them. There are different types of decal paper depending on whether you have a laser or inkjet printer. Im lucky enough to have access to a laser printer which means you can just print your word document straight on to the decal paper. Most home printers being inkjet need inkjet paper and some kind of sealing lacquer as the ink is soluble. Theres loads of companies out there that do decal paper: google is your friend :) After that, its just decaling as usual, with the warning that Ive found the ink (even with a laser printer) is a lot more fragile than Tamiyas own decals. Sometimes the paint has lifted or flaked when applying. This is why you print off more decals than the bike actually needs.
P.S. an alternative to step 4. is to save your word document onto a disk/pendrive/etc. (or just print it in colour) and bring it and a few sheets of decal paper to your local printing shop and ask if they could do it - shouldnt cost a lot. Make sure to point out its decal paper to them though !
Sorry about the long reply, but was trying to give you a good idea of whats involved (and Ive probably forgotten something !). Anything else, dont hesitate to ask.
Nick
