gzt wrote: |
I do not have any power tools for resin work. And totally have no idea of the process - including safety procedures. Greg |
I'll jump in quickly here and then right back out. You really don't need power tools to work with resin. I've noticed lately a "fear" of resin throughout the board that seems misplaced. At the end of the day, it's not much different than plastic. Just a couple of things to keep in mind, and that's about it.
1. Wear a mask when sanding resin. Resin dust is bad for the lungs.
2. Clean and prime the resin. Since that's good advice for plastic also, it really isn't anything different.
3. Lastly, like plastic parts and PE parts, you have to be careful removing the resin part from the casting block.
Bottom line, it's just a slightly different medium. Next project, go for it and you'll probably wonder what the fuss was about. However, I would recommend starting with simple resin replacement parts like seats and tires before jumping into cockpit or wheel well replacements. There's a different skill level involved that most modelers need to work up to.
Cheers
I'm out
