SPITFIRE GROUP BUILD 2007-2008
    November 2006
Posted by ollie on Sunday, July 1, 2007 9:39 AM
 Daywalker wrote:
 jwb wrote:
All- Last night I was looking for Spitfire sites, and found out that thespitfire.com was available. A few clicks later..... I own it! Not sure yet exactly what I'll do with it, but it will involove Spitfires. Wink [;)]
I think you should have pics of all the Spits you are going to build, K5054 thru Mk.47. Big Smile [:D] PM inbound!
Your missing a few. How about the Type224, theres only one kit of that on the market. Or the Seafang.
www.overthefencephotography.co.uk - aircraft photos.
    November 2006
Posted by ww2modeler on Sunday, July 1, 2007 8:45 AM
Looks great, can't wait to see the finished thing.
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
gzt
    May 2007
Posted by gzt on Sunday, July 1, 2007 8:13 AM
Thanks again. It was not pretty seing something like that happening ...
I also realized how diferent some decals are. The tehcmod is thin and very delicate while tamiya is think and pretty robust - not very easy to follow panel lines though.
Greg
Flying is a thrill #2 known to mankind. Landing is #1.
http://www.rwd-6.org
    February 2006
Posted by ruddratt on Sunday, July 1, 2007 2:47 AM
Looks nice, Greg! Glad it worked out for you! Thumbs Up [tup]
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
gzt
    May 2007
Posted by gzt on Sunday, July 1, 2007 12:20 AM
So, after a moment of horror, I was able to apply decals on this bird. Thanks again for help.
Greg
    June 2006
Posted by ModelMan8 on Saturday, June 30, 2007 10:06 PM
Greg, they look really goodThumbs Up [tup]....PM inbound!
Well Guys, I am glad the GB is finally on.  Can't wait to work on my MKII.  From what I have read, the rest of the squadron is going to be off the ground before the 109s know they are coming!!Big Smile [:D]
    September 2003
Posted by Daywalker on Saturday, June 30, 2007 10:05 PM
Frank
gzt
    May 2007
Posted by gzt on Saturday, June 30, 2007 9:55 PM
Gentlemen,
I tried one more thing - set decals into water for just few seconds (about 5sec) and tried to set them on the plane ...
here we go:
 I think I just panicked but it is a good experience for me ... be patient and .. read more posts :)
Thanks for such quick help
Greg
gzt
    May 2007
Posted by gzt on Saturday, June 30, 2007 9:27 PM
Thanks a lot Gentlemen! You may realize what kind of panic attack i experienced :)
I made me realize how little I know about this business :)
Greg
    February 2006
Posted by ruddratt on Saturday, June 30, 2007 9:06 PM
Greg, I've never had much success with glosses from a rattle can. My guess would be the issue arose in the application of your main colors since you mentioned that you fine-sanded the primer. Pressure might have been too high, airbrush might have been held too far away from the surface, or the paint may not have been thinned enough. In any case, I would let your model sit for at least a day, maybe more, until the gloss you applied is fully cured, and then fine-sand it again, wipe the sanding dust away, and airbrush some Future onto it as your gloss coat. Spray it at about 15 psi, work slowly, and don't hold the airbrush more than 6" - 8" from the surface of your Spit. Your off to a fine start and I wouldn't let a small setback like this put you into panic mode. It's really not as bad as it may seem right now.
    November 2006
Posted by ww2modeler on Saturday, June 30, 2007 9:05 PM
I don't know as I haven't experienced this problem but maybe the decals were bad and microsel had a negative impact on them. Just a thought. The build looks great though.
David
On the bench:
gzt
    May 2007
Posted by gzt on Saturday, June 30, 2007 8:54 PM
HEEEELP !!
I use enamels only (MM) for my project. Primer used (White Primer from MM )
This supposed to be a project ready for decals (after applying gloss)
I set my Mk II with gloss coat (Model Master spray can) and .... it is not glossy. OK so I said, lets try ... I put a lot of microset and .... destroyed my first decal as soon as I tried to move it !
I think the problem is with the primer I used but I am not sure. The paint texture is flat. I even use sand paper to smooth the surface (after applying primer) and I thought it is OK. Now I see its not OK and I am going into deep .........
You guys know that I am a newbie and I just went into the trap I did not even see ....
So, what went wrong ??  How to apply decals in such surface - one shot only :( - I amy try it but .. it is a special set of decals and I do not have any replacements (have to wait for Techmod for at least two weeks ) so unless you will tel me what is wrong and how to fix or ... I will struggle during the task what was some fun already (P-51)
Greg
jwb
    February 2006
Posted by jwb on Saturday, June 30, 2007 6:52 PM
 wyoroy wrote:
WOW! Thanks Jon there are a bunch of pics.  More than I could ask for.
Roy
I've spent far, far too much time googling Spitfire pics.... LOL. You can go on and on and on. If you can't find a specific view, let me know and I'll look at what I have saved and see if it helps. If I tried to send all I have it would be to big to email. Big Smile [:D]
I'm sitting here in the hotel having Spitfire modeling withdrawals.....
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    August 2006
Posted by wyoroy on Saturday, June 30, 2007 6:41 PM
Roy
Roy (Capt. Wyoroy FAAGB/USNFAWGB)
John 3:16
jwb
    February 2006
Posted by jwb on Saturday, June 30, 2007 6:35 PM
Dave- you'll be finished before I get back! Wink [;)] Looks good- that little Airfix kit is fun. I built the Mk. V recently, and it can turn out OK. Just something cool about an Airfix Spitfire....
Marc- Nice work on that wing.
Jon Bius
jwb
    February 2006
Posted by jwb on Saturday, June 30, 2007 6:27 PM
 wyoroy wrote:
Even with most of my stuff packed away I am able to do a bit on my Spitfire Mk2, maybe the cockpit Whistling [:-^] I was wondering if any of you could supply me with cockpit colors and/or pics of the pit?  It calls for a blue-green for the inside would interior green be OK?
Roy
I may be away from home but I ain't missing the fun! Smile [:)]
British interior green is the color you want.
Here's all you'll need for cockpit pics. Wink [;)]
Jon Bius
    August 2006
Posted by wyoroy on Saturday, June 30, 2007 6:13 PM
Roy
John 3:16
    August 2006
Posted by wyoroy on Saturday, June 30, 2007 4:54 PM
I do have 4 109s, B, E4/7 trop, F4, G6 trop Whistling [:-^]
Roy
John 3:16
    September 2003
Posted by Daywalker on Saturday, June 30, 2007 4:06 PM
 wyoroy wrote:
WOW, been gone for a few days and you guys have taken off.
Looks like someone else will be building a '109. Whistling [:-^]
John- I am really excited to see your K5054, that is one sweet looking aircraft.
Frank
    November 2006
Posted by ollie on Saturday, June 30, 2007 2:30 PM
 jeaton01 wrote:
Yea, it is at last time to build!  I will make a start on the K5054 conversion today, no matter how humble!
I have been doing research, and have an article claiming that the Rolls Royce blue (or whatever the first color was) was replaced with French Grey for a time, before the airplane was repainted in dark green/dark earth.  Unfortunately I think at that time it may also have gotten the later exhaust instead of the flush stubs.  I like those flush stubs.
 Id like to do a model of K5054 as she was when she first flew.
Posted by jeaton01 on Saturday, June 30, 2007 1:30 PM
John
    February 2006
Posted by ruddratt on Saturday, June 30, 2007 12:52 PM
Dave, that's a fine start you're off to! Keep us posted! Thumbs Up [tup]
Marc, very impressive work on the wing modification! Glad mine's a 'b' and not a 'c'. I doubt I could have pulled it off as well as you! Thumbs Up [tup]
I should have some pics of my 1/48 Mk.Vb up later today. Got a few seams to clean up, but the fuselage is buttoned up and the wings are attached. Priming and pre-shading are not too far off.
    August 2006
Posted by wyoroy on Saturday, June 30, 2007 12:09 PM
WOW, been gone for a few days and you guys have taken offThumbs Up [tup]  I'm spending most of my weekend packing, I leave in three weeks for sunny FloridaCool [8D]  From what I have seen so far I will have my work cut out for me when I get started back building.  You guys do outstanding work.
Roy
John 3:16
    September 2003
Posted by Daywalker on Saturday, June 30, 2007 11:37 AM
Off to a great start Dave!  I am hoping to start painting the office today, pics later.
Wing_Nut- PM inbound.
Frank
    September 2004
Posted by razordws on Saturday, June 30, 2007 11:32 AM
Marc, Darren nice start guys even if it was a false start.  I think you both should have to do a Bf 109 as your next build as punishment. Wink [;)]
Since this is now officially a go (even though it is still June) I stayed up late last night and got a good start on my 1/72 Airfix Mk I.  since there is not much of a office in this one she moved along pretty quick.  I did foget to put the pilot seat in before I closed it up but luckily the glue was still wet when I noticed the seat sitting there staring at me Confused [%-)]. so I pulled off the bottom wing put in the seat and reglued the wing only to find out that the thingy sticking out from where the display stand goes was banging into the seat making it go crooked.  Off came the wing again.  don't you love Airfix? Big Smile [:D]  Actually I've been working on four dragon Ar 234 and Airfix fit problems have nothing on Dragon!!!!  Anyway, pics yes there are pics.
Dave
    April 2005
Posted by wing_nut on Saturday, June 30, 2007 11:00 AM
Greg Darren... thanks.
Thta is a cool conversionset for the Messerspit  or is it a Spitschmidt?  Whatever... gotta get one.
Marc
Posted by darson on Saturday, June 30, 2007 9:28 AM
Oops forgot to mention, Marc great job on the scratch built C wing so far, it's looking great.
Frank I’ve always wanted to do that Messerspit conversion but last time I checked the conversion was going to cost me more than the kit Confused [%-)]
Cheers
Posted by darson on Saturday, June 30, 2007 9:18 AM
Well it 12:16am on the 1st of July by my poota clock so as far as the build is concerned I'm rolling in hot!!!!!
Smile,Wink, & Grin [swg]
Cheers
    November 2006
Posted by ollie on Saturday, June 30, 2007 8:45 AM
 Daywalker wrote:
How 'bout this?
Here's a link to the conversion.
http://www.dp9.com/fusion/histmodels.htm
That will do me.
gzt
    May 2007
Posted by gzt on Saturday, June 30, 2007 12:30 AM
Marc,
Nice job with the blisters !
Greg
