Another update on my practice build, the 1/48 ICM Mk XVI.
This is a very fiddly kit, but it is coming together OK. Or maybe I am just in love with those Eduard color PE belts I put in today. Whatever, I feel good.
The next two photos make me wish I had thought to thin down the sides and front of the seat. Next time. This is just practice.
The next picture shows some "deviation from the written instructions".
Test fitting and other people's opinions indicated a problem with the fit of the engine mount bulhead, and even though I thinned it down and narrowed its width, things were still not going in a way that was going to allow a tight fit to the wings at the upper roots. The fuselage shells are so thin that I couldn't fit the wing without this bulkhead installed, so I went ahead and installed the bulkhead, and then the finished cockpit. Next I fitted the wing, which fit too tight, there was insufficient dihedral in the wing (the upper panels were already assembled to the lower, I think the best way to do it). I took my Tamiya sprue cutters and cut out the center of the engine mount bulkhead, and then installed the wing, flowing thick super glue in on the upper wing roots. The gap was minimal, but so was the dihedral at this point. Next, I assembled the lower cowl halves, and when well cured I assembled that to the nose. I then super-glued a piece of sprue accross the lower third of the EMB while I was holding a little more dihedral than I wanted to end up with. Seems to have worked, and I have no bad gaps to deal with. If the fuselage were not so "bendy" I probably couldn't have done it this way, but then maybe I wouldn't have had to. As it is, I haven't glued anything in without studying the fuselage to see that it was all still going in a straight line. The final result if I get it right will hopefully be an airplane with nice thin edges to things due to the kit's design.
