Nice work Greg! Were you able to fix the damamged paint and continue? She looks very nice from here.
One question on the tailplanes. Are they not supposed to have any of the dark earth camo on them, or have you just not yet finished painting them? Just curious, and thought I would ask.
Bad news for my Mk.Ia. I went to remove the masking from the lower survaces this afternoon, and was horrified by what I had found. I used my handy-dandy home-made curing oven to help cure the paint between successive layers, and apparently you cannot put a model in there with any kind of masking on it. The curing temps (which I use on other models with excellent results) appears to have softened up the adhesive on the tape and softened the paint itself and fused them together. The bottom on the plane has an awful smeared look to it, and will have to be completely stripped down and redone. Perhaps this is common knowledge, but it never occured to me! But on the bright side, I get more practice painting! For those who don't know me, I have stripped and redone several aircraft in the last couple of years, so I am getting pretty good at it. The last one (my Zero) turned out even better the second time around so I guess it was worth it (in a sick sort of way!). I am going to put her aside for a bit, and pick it up again in a month or two. I'll post WIP pics of the restoration then.
