Knights of the Sky WWI GB The End
    March 2005
Posted by philo426 on Tuesday, January 15, 2008 8:36 PM
Thanks!I'm diggin' the group build forum!
    June 2007
Posted by Dougums on Wednesday, January 16, 2008 5:05 PM
Okay ... here she is...
    Well ... it is full of mistakes.  After assembly I kept finding seams and injection pin marks that I overlooked. A big nasty one under the fuselage. I painted it with Vallejo Model Color Carmine red.  It took some time thinning the paint to spray. It sure is thick. With light coats it turned out nice. I learned a whole lot with this build.  Mostly what NOT to do. Although I did have fun.  With that said I have decided to give it another go.  I have recently ordered a Eduard 1/48 Nieuport Ni16.  The Eduard kits look really nice.. but anythings got to be better than the Revell flash monster I recently assembled.  So Make a Toast [#toast] heres to my first completed GB Make a Toast [#toast] Cheers!
    October 2004
Posted by StephenLawson on Wednesday, January 16, 2008 5:52 PM
Very decent build of an old favorite.  If you want to add just a bit more to it overpainte the serial and datum weights so that they are barely visible.  Otherwise Very Cool! model On!
Stachel...unconfirmed by Armee means unconfirmed!!!!
    April 2005
Posted by wing_nut on Wednesday, January 16, 2008 5:52 PM
So this GB is still pumping out the butt kickin' good lookin' models.  I'm gonna have to build the 2nd Camel and get back in on the fun.
Marc
    October 2003
Posted by ModelNerd on Wednesday, January 16, 2008 11:25 PM
There are no doubt some of you who have assumed I dropped out of the group build. I'm still here, you lucky devils! And of course, there was the obligatory hiatus for the holidays. This step which I will show you here was the most mentally taxing part of the project. I can safely say this, even though I'm not finished with the project, because ANYTHING that comes after this step will be easy!
As previously mentioned, I drew up my own decals, once I discovered my Eagle Strike set did not come with lozenge. Since inkjet-printed decals are quite susceptible to water, I thought it prudent to use a color laser printer. Well, as you know, Kinko's wouldn't touch it, so I had to research and buy my own dang laser printer (I settled on a Xerox Phaser 6130). As I soon discovered, the downside of laser-printed decals is that they're brittle and chip easily. Clearcoating does help, but there will still be problem areas. The following pictures show the decalling progress. At this point, they're still glossy.
In this photo, the "axle wing" (for lack of not really knowing WHAT it's really called!) has a flat coat:
Wrapping an entire plane in decals has proven to be a tad on the tricky side, I hope I don't ever have to do this again! My next post should have the plane together and finished.
- Mark
    September 2003
Posted by Daywalker on Wednesday, January 16, 2008 11:56 PM
Dougums- You should be VERY proud of that little gem, well done indeed!  As for mistakes, none are apparent in the photos.  Really makes me want to build a Triplane! Thumbs Up [tup]
Marc- I added another Camel to the list for you, woohoo!  Can't wait to see this one. Tongue [:P]
ModelNerd- OUTSTANDING!!!  That looks just right to my eye, colors appear to be spot on.  You really are raising the bar.
Frank
    February 2007
Posted by MrDrummy on Thursday, January 17, 2008 4:02 AM
Dougums-- nice looking build!  I like that little Fokker.
Great stuff all around, fellas.  Just got back from a little trip.  Should be able to finish up on the Albatros in a few days!!
-Justin
On the Bench: 1:48 Dragon Dr. 1 1:48 Trumpeter MiG-15 Fagot B Photo Sharing and Video Hosting at Photobucket
    October 2003
Posted by ModelNerd on Thursday, January 17, 2008 10:05 AM
This looks just fantastic. What kit was this? It really looks good, you're far too critical of your work. BTW, I heard that Eduard is working up a 1:48 Dr.I, I hope it's true. It's long overdue.
Great work!
- Mark
    June 2007
Posted by Dougums on Thursday, January 17, 2008 2:31 PM
  Thank you all for the kind words of encouragement.
  Mark - It is a 1:28 Revell DrI. Your DVII looks like it's a challenge.   I have been wanting to make my own decals.  I'll give it a try one of these days.
    September 2003
Posted by Daywalker on Thursday, January 17, 2008 2:39 PM
Dougums-
I was just showing my girlfriend the pics of your Dr.I, and she said "WOW!  That really looks cool.  YOU should build one of THOSE!"  Very nice work, and I updated page one to show your finished build! Thumbs Up [tup]
Frank
    February 2007
Posted by MrDrummy on Sunday, January 20, 2008 12:19 AM
Alright fellas-- HelP?
Searching through a bit of reference material, I noticed that most of these planes have a fairly glossy finish to them.  Of course, in 1:48, I can't go completely glossy.  What do you guys that have built these before use as a final coat?
I've always relied on my flat coats to hide the edges of the decals well, and I worry that a satin finish won't do the same.  What do you guys think???
-Justin
    October 2004
Posted by StephenLawson on Sunday, January 20, 2008 2:05 AM
Always remember you are doing a specific machine at a specific time. So rely on images of that aircraft at that moment in time.  If it was factory fresh semi gloss in 1/48 is fine.  In the field gloss finished broke down and there was a distinctive concern about reflecting sunlight with these machines.  Several layers of a flat coat will give you what your looking for especially with the "Blau Maus".
    March 2005
Posted by philo426 on Monday, January 21, 2008 2:22 AM
How about a 1/48 Sierra Scale Models vac-form Moraine Sauliner Type N?
    February 2007
Posted by MrDrummy on Tuesday, January 22, 2008 4:34 PM
Well, here she is in all her "glory."
There are a couple of rough spots (nothing you guys can see, thanks to a sly photographer,) but I'm pleased with the way it turned out.  Thanks to all you guys for the encouragement, the tips, and the research!!  I appreciate it!!  I don't think that I'd have gotten through this one without some of you guys!
-Justin
    March 2005
Posted by philo426 on Tuesday, January 22, 2008 4:46 PM
Looks great!The weathering is subtle and very effective!
    June 2007
Posted by Dougums on Tuesday, January 22, 2008 5:59 PM
    Fantastic job.  The pre-shading really paid off. I am going to try that technique on my next build.  Great job! Thumbs Up [tup]Thumbs Up [tup]
Posted by jeaton01 on Tuesday, January 22, 2008 7:43 PM
Super job, Justin.  That one is going to look very good indeed in my your display case!
John
    September 2003
Posted by Daywalker on Tuesday, January 22, 2008 11:23 PM
OUTSTANDING work Justin!  That one came out even better than I had expected. Bow [bow]
I'm not sure what it is about that color, but it really strikes me.  Visually, it is so intense!  Wheels look just right, what color did you use for them?
I updated page one for you!
Frank
    February 2007
Posted by MrDrummy on Tuesday, January 22, 2008 11:31 PM
Thanks, guys!!!
I appreciate the words!  Without some of you guys pushin' me onwards, I'd have never finished this thing!
Frank- thanks man!  For the wheels I used one of my favorite colors-- Gunze RLM 66.  I've found lots of uses for that wonderful color! :)
-Justin
    October 2004
Posted by StephenLawson on Wednesday, January 23, 2008 8:05 AM
Nicely Done Sir!
Posted by waikong on Wednesday, January 23, 2008 8:26 AM
Justin, she looks fantastic. Everything from the paint job to the wooden prop just looks spot on. The subtle preshading is really nicely done.
    February 2007
Posted by MrDrummy on Wednesday, January 23, 2008 1:34 PM
Stephen-- A "Well Done" coming from you means a ton!  Thanks for the help along the way, my friend!
Waikong-- Thanks for the words, buddy!  I appreciate it.
I tried to simulate the blue paint wearing off on the fuselage by spraying a bit of a wood color on there.  Do y'all think that it turned out ok?  It KINDA looks like the wood peeking through, huh?
-Justin
    January 2004
Posted by mkhoot on Wednesday, January 23, 2008 4:20 PM
Justin That looks great. The weathering and rigging look just right.
When in doubt just build it. Mark http://www.ipmslivonia.org/ipms/
    January 2006
Posted by sirdrake on Thursday, January 24, 2008 4:26 AM
Justin, that looks great. The weathering is fantastic.
sd
    October 2003
Posted by ModelNerd on Friday, January 25, 2008 12:36 PM
Justin, great job. Looks excellent. Nice weathering, too.Thumbs Up [tup]
- Mark
    February 2006
Posted by ruddratt on Friday, January 25, 2008 8:27 PM
Justin, that is really excellent work, my friend! One I would be proud to display in my own collection. You nailed every aspect of that build. The weathering looks great, the wings look to be aligned perfectly, and the rigging (one of the most tedious parts of building these birds) looks to have been done by someone with quite a few of these under their belt. Just an awesome build in every respect. Thumbs Up [tup]
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    January 2004
Posted by mkhoot on Saturday, January 26, 2008 10:15 PM
I was finally able to get some work done on my Hannover. I've got the cockpit done. The fuselage closed up painted and decalled. Painting that lozenge pattern on the fuselage was a pain.
    September 2003
Posted by Daywalker on Saturday, January 26, 2008 11:06 PM
Lookin good mk!  I bet that was a PITA to mask and paint the fuse, nicely done though! Thumbs Up [tup]
Frank
    October 2004
Posted by StephenLawson on Sunday, January 27, 2008 3:57 AM
Greetings mkhoot!  Very nicely done!  I would like to offer one small comment that often the fuselage lozenges were muted by the application of an over all colour.  This was very thin and served only to take the hard edges away from the hand painted lozenges.  Note there are images of Hannover CL.IIIa types with and without this muting.
    October 2004
Posted by StephenLawson on Sunday, January 27, 2008 4:16 AM
I have been  very busy lately with several projects.  One involves the application of the "New Lozenge" sheets I have to test.  These are going on 2 - 4 Fokker D.VII kits for use on their website.  The first two are almost finished.
The second are the four 1/48 SE 5a types I had discussed here earlier. Cockpits are ready to close and next comes the top wing, rigging and etc.  Hint if you build these kits do not forget to blank out the engine compartment at the side  view or you will get a see "through view" where an engine should be.
Thirdly, the two large 1/32 scale Roden kits (SE 5a & Fokker D.VI) are being readied and the reviews are in progress.
Fourth on the list are two newly arrived 1/48 kits. The new Gavia Alb. D.I and the reissued Eduard Alb. D.II are being previewed at this time.
I was also been convinced to head up a "Between the Wars Group Build" over on the Aeroscale site. I have been tinkering with several ideas for my contibution.  I recently found the kit I wanted to use.  Though it won't have anything to do with WWI it will be a 1927 design.  Did I forget anything? Well if I did, I will catch with it later.
