Derek,
no penalties for an early start!
PantherLehr has been doing a bit of track work, an i confess that i washed the kit a few days ago, and have begun to remove a few bits from the sprues.
i have gotten the idler arms cleaned up, and glued to the hull, joined the
halves of the drive gears. twice. once without the poly cap inside,
and then again w/ it in there where it belongs.
i even cut the first piece of PE zim from the fret and would have glued it to the front of the lower hull,
BUT . . . my CA bottle had glued itself shut and
resisted all attempts to make a new hole in the nozzle w/ exacto blade or needle.
then my girlfriend came home, and it was time to make dinner.
i excuse myself for jumping the gun as i will be losing build time running back & forth from PA to NY the holidays.
i do have a question about the road wheels:
the eight wheels that make up the 'middle' set of road wheels are comprised of two pieces.
when i was dry fitting these pieces, i could see that they will make two distinct halves.
(so there wil be a visible 'split' between the rubber sections)
i have looked over the directions, and will check my references (such as they are) when i get home,
but i take it this is how the pieces are supposed to fit?
and if so, should some painting be done before they are glued together?
Ginge,
welcome to the forum, and hopefully to our build!
the main purpose is to supply information and motivation to one another.
(and armor rookies like me can get pointers from the veteran treadheads)
ed.
